Yet another WRX install.
  • Yet another WRX install.
    here are some pics from my carputer install in my 2002 WRX. the system used is is a PIII 800mhz, 256mb ram, 9gb laptop hd, onboard video, USB audio. i wanted the computer to be tucked away somewhere so i can't see it... so i decided to stick it under the passenger seat. i had to build a custom box for it so i had soem acrylic professionally cut. i'll start with pics from building the computer.
    testing the system
    the pieces of acrylic
    i used the regular stand-offs to attach the motherboard in place
    i drilled small holes in the acrylic and forced the stand-offs in with pliers
    motherboard mounted
    to glue the pieces together, i used weld-on acrylic glue, applied using a syringe
    first side on
    other sides
    motherboard in place with the cutout for the i/o plate
    go away protective paper1
    a hole saw was used to cut a hole on top to mount the case fan
    hole cut out for 80mm fan
    drilled holes for the case fan screws
    case fan mounted
    acrylic hinges were used for the cover
    hinges glued on
    system in the box with fan and hard drive mounted
    cover open
    the lilliput 7" touchscreen LCD
    lcd housing for lilliput
    had to take the lcd apart to put into the in-dash housing
    lcd inside the housing
    TIME TO INSTALL!
    tearing apart the car
    stupid radio antenna was too short, had to buy an extension
    center console, shift knob assembly taken apart to run wires
    video wires running through center console
    lcd in its new home
    head unit was relocated to the top of the dash. eveything put back together.
    perfect fit under the passenger seat
    direct power from the battery for the 150watt opus PSU
      ran power cable through the center console as well
      i grouded the psu on the bolt that supports the passenger seat
      initial power-on test. everything's a huge mess
      running windows XP
      testing sound and video
      "where's my air bag?!? WHERE'S MY AIRBAG?!?!" had to disconnect the airbag in the passenger seat to remove chair
      running centrafuse
      playing a music video
      wow that was quite lengthy. questions... feel free to ask.
        FIRST BLOOD!
        I like the cool box, makes me want to redo mine... keep up the good work
        2005 Ford Mustang GT <- - - UPDATED PICTURES
        2003 KAWASAKI Z1000 - CUSTOM MODZ
        MBK (AIM = IllMBKllI)
          awesome work man. I have some questions.... How did you screw in the standoffs like that? Also, how did u screw in the hinges... everytime i try it starts to crack. Awesome work
            for the standoffs... i drilled holes that were a little bit smaller than the thread. then i just used pliers and forced it into the hole.
            the hinges weren't screwed on. they're glued on using the same weld-on acrylic glue. it's actually stronger than you might think.
              Hey, Awesome work.
              One word of advice, you might want to clean up that nasty *** fan.
              Peace,
              Rafster
              Post # 3000
                Who cut the acrylic for you, and where did you get the glue?
                Michael
                  the acrylic place is called paragon plastic. they're in el monte. they also have the glue, hinges, etc. they have pretty much everything.
                    Did they cut it for you also?
                    Michael
                      great install and thanks for the great pics of the progress and final installation...
                      btw -
                        this reminds me of the "NSX to FERRARI" threads. A LOT of pictures.
                        good job. no bondo job for me to critisize!
                          THat case is awesome! From one scooby to another, nice work.
                          A car without turbo is a car with perpetual lag.
                          My Ride
                          My New Page
                            Excellent work! That case is just awesome, too bad you put it under the seat where nobody can see it...
                            Did you find your airbag btw...?
                            Renault Megane...the OEM look
                              yes, they cut the acrylic for me also. i got 9 pieces cut (3 were spares but i didn't use them) for about $38. give them a call. they give discounts for students of the art center.
                              a lot of people have been telling me that i should put the case somewhere that people can see... or at least the trunk or something so it gets shown every once in a while. but... i still prefer it hidden somewhere. after all, that's why i built it, so i can put the computer under the seat. i guess i'll just settle for having it seen in pictures only.
