2000 Chevy Suburban install
  • 2000 Chevy Suburban install
    I moved my install to the truck from the Corvette. Thought I'd post some pictures, as the only people to see any of it are TruckinMP3 and dingofarmer in January. I wasn't finished installing at the time.
    I ran 4 guage wire from the engine bay, under the truck and into the cabin under the rear drivers side door. I used a fairly hefty amp install kit from walmart. The PC sits underneath the second row passenger seat on the drivers side. Notice the switchbox I hacked together at the front to turn of power & control whether the PC come on with the ignition. The cables for screen etc run under the floormat and then underneath the center console. Hidden underneath the center console is a gyration keyboard wireless receiver, a USB 2.0 powered hub and a 3-way cigar-lighter adapter. The lilliput screen sits in a plinth that fits in the console cubby hole.
    It looks quite good, though I may look into moving the heating controls to the center console and puting a non-motorized in-dash in their place. It performs really good and has no problems with video or iGuidance.
    I'll happily answer questions anyone may have :-)
    Here is the truck, and the pc under the 2nd row passenger seat:
    Here it is with the seat lifted. There is enough clearance for the lit fan to extract properly.
    Also a picture of the screen mounted with the RAM mount and the trackball (touchscreen isn't as accurate as I'd like):
      A closer picture of the RAM mount and trackball. The cigar lighter with the light has a switch that controls power to the screen, the USB hub and my radar detector. I fabricaated a shelf that sits in my cupholder area to sit the trackball onto.
      The wires going under the door will hook up to either my PSP or the Apacer USB-to-go hard disk I transfer files with:
        Frodoplayer 1.10 with brightlife skin:
          iGuidance embedded into FP. Loads at system startup & FP GPS button switches instantly:
            FP playing video. Goodies hidden under center console:
              XP desktop & GPS puck in place:
                What case are you using for the carputer???
                Nice setup!!!!
                  Thanks, its one of these.
                  Take the AC power supply out and the Opus 150 just fits in its place...on its side...with the case removed....and a teeny bit of modification to the case.
                  I'll add a picture of whats inside soon.
                    Sweet! Nice case too. What do those buttons next to the case do?
                    Renault Megane...the OEM look
                      Damn! That is the blurriest screen i've seen!
                      PowerVoice v1 | NaviVoice Source
                      GammaControl v2.4
                      SKINbedder v3
                      1995 Lexus SC300
                        Red Dwarf fan?
                          Hey Pip...
                          We just upgraded the 97 suburban to an '02 with second row captains chairs. Thinking of following your example on the location of the case
                          Nice to see the pics. Should we plan a spring meet in '06?
                          Cheers
                          TruckinMP3
                          Read the FAQ!
                            Camera was out of focus
                              Originally posted by stuseed
                              Red Dwarf fan?
                              Absolutely, Red Dwarf rocks!
