2005 Acura RSX Type-S
  • 2005 Acura RSX Type-S
    Installed pics!!! scroll downHeres a couple shots of my setup...its not quite done yet...i just need to get it installed.
    sorry for the 3 big pics, let me know what you guys think.
    that is amazing that it turned out so nice, congrats......you really made that look easy with those progress pics
    did you use ABS in that first shot, if not what is that?
    PC Components:
    My work log
      btw, the system im running is a miniatx biostar M7VIG 400, with an AMD 2200+, 512 or a gig or ram (i havent decided yet, probably just stick with the 512). 40G Hitachi 'deathstar' HD, Onboard S3 UniChrome graphics, onboard sound and an Opus 150W PS. I washed my car this evening, so ill get pics up of that tomorrow when its light out
        Thanks, i appreciate it, im really glad it turned out the way it did. Haha, yeah the pics dont really do justice on how much work bondoing and sanding time goes into a project like this. The first pic isnt abs, i used this glue that i found at my house, its technically not a "superglue" but on the tube, it said "BOND"...i used that to secure the faceplate in and then went out and bought some KrazyGlue brand superglue and went over the back and front seams with it.
          Very nice, now lets see it in the car!
          2003 Durango Install
          2003 Matrix Install
          2004 Escalade Install
            That bezel looks absolutly amazing! What were the exact steps on doing that?
            I can tell it was a lot, but, what sand paper grid did you use?
            Renault Megane...the OEM look
              we demand pics of car!! :P rsx type-s *drulleee* nice install man good work!
                It looks really good! Nice work! I wish I could get my trim piece to look that good... (even after 3 tries...)
                The only thing I'd be afraid of is that Bondo cracking in the differing temps....
                The Bondo-glass is much stronger...
                Good luck!
                Project "Media-Z" : 99 Camaro Z28 (Click to View)
                  I was just wondering if you can tell me th process in which you do this. I am planning on a project in the near future and would really like to do what you have done there. Do you just use Bondo to fill in the cracks and then what grit of sandpaper do you use? Any help would be grealy appreciated! Thanks!
                  -haryy
                    Excellent work. Paint job turned out flawless. What paint did you use? The semi-gloss looks great.
                      thanks everyone, i promise to get pics up tonight. I use bondo regular body filler. I first used 100 grit to get that bondo down and used fine 400...it seemed much finer, b/c i bought more 400 (not the same kind) and it seemed rougher than the stuff i was using....so a very fine 400 grit (3m, tan in color). I took my time with the sanding and the bondo. I used probably about 5 layers of primer with sanding 2 times in that process and sanded 1 time before the black semi gloss. after 2-3 coats of black, i sanded 1 last time and applied the final 2 layers of black. The last layer i kind "spritzed" the paint to try to give a oem look to the surface and turned out pretty good. The surface isnt as smooth as the picture depicts.
                        very nice! i wish mine was half as good
                        02 Accord Coupe EX V6
                          Alright, some pics!
                          above, i used a usdm type-s emblem for my front grille and have since installed the jdm type-s emblem:
                          and my hid's
                          let me know what you think.
                            b-e-aaauutiful lol i love rsx's type-s' even more ;P nice ride
                              looks great!
                              New System in progress:
                              M10k
                              Phaze TD1500 ~> Seas g18rnx/p
                              Zapco Ref 500.1 ~ 12" tc-9
                              Transflective Xenarc
                              My Car Pc Install
                              My Boat Pc worklog
