1993 Volvo 850 GLT Install
  • 1993 Volvo 850 GLT Install
    Here are a few shots of my nearly completed install. Sorry about he low light shots, I will take some tommorow in the sun, and update the page.
    This is the LCD placement. To fabricate this I took the existing cage from my stock radio and cut out the front buttons. I then cut out around the bezel from the lcd and bondoed the two together. The flash makes it look a lot worse then it is. It was also my first time working with the stuff.
    Here is the computer set-up. I took an old dell case and painted it all black and screwed it into my subwoofer. The subwoofer was actually my parents but the amp inside died, and they gave it to me. I then put a panel over the hole where the amp was, soldered speaker cables to the sub and now power it off a 100 x 2 profile amp.
    Here you can see my two amps and the inverter screwed into the back of my seats. I still have not found an easy way to hide all my cables, computer and amp, so any suggestions would be appreciated.
    Volvo 850 GLT
    what low light shots???????
    http://www.sounddomain.com/ride/856246
    Please visit my new site http://www.Gigabitcustoms.com
    My worklog http://www.mp3car.com/vbulletin/showthread.php?t=52720
      Sorry it doesnt like webshots links I guess.
      Volvo 850 GLT
        Ok the pictures are all fixed.
        Volvo 850 GLT
          You should get some of that wiring tubing to hide the wires or at least keep them a little bit organized. Are you goign to put your amp or anything like under the carpeting?
          ___________________________________
          1996 Accord Ex Carputer
          Soon to come 2008 WRX 5-door Mac-carputer.
