2001 Dakota
  • 2001 Dakota
    Well i figured i would go through some of my photos and stick some of them up here, they are all from when i was installing the system so they are a little old. I hope to have a few up here from now soon.
    I built the system to mimick the center seat of my truck. Other than the 8" screen mounted to the dash, you can't tell anything is diffrent about the seat, it even is still cushined (not as soft as stock, haha).
    The system is running a P4 1.6Ghz CPU on a Commel LV-670 motherboard. 512megs of 2700 RAM with heatsink. Linksys WMP54G PCI Wireless-G Adapter with external antenna on top of truck. Built in 5.1 sound and Intel Graphics on MB. 60G Hard Drive mounted in a HD Cooler were are flows by constantly. I took a 3 bay case and cut out the metal cage to use the two bays. In the center console i have a USB Hub with a Trigger Mouse stored inside for random use. GPS is Microsoft USB reciver running Microsoft Streets and Trips. I am running XP Pro useing old skool MediaCar as the front-end, best one for how i use it so far.
    Let me see your comments and questions.
    P.S. Sorry for the Type-O's.
    Running Winamp befor I found a front-end I liked.
    Have to add these photos in so you see what this system is installed in.....
    2001 Dodge Dakota ClubCab
    Running MediaCar
    Commell LV-670
    P4 1.6Ghz
    Corsair 512Mb
    60Gig 7200rpm 133
    Linksys PCI Wireless with External Anttena
    8" Touch
    Microsoft USB GPS Reciever
    Audiobahn 600w 4ch Amp
    I knew there were some Daks around here somewhere. I should have mine in soon. Just waiting on the screen fab to be done. Everything else is ready to go.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
      Are you on any forums? Dakusa? I'm with Dakotausa.com and SOVA--dakotas.com
      Running MediaCar
      Commell LV-670
      P4 1.6Ghz
      Corsair 512Mb
      60Gig 7200rpm 133
      8" Touch
        Very nice work!!
        2003 Durango Install
        2003 Matrix Install
        2004 Escalade Install
          Originally posted by Matrix_24
          Very nice work!!
          Thanx, i like your install you are working on. I wish i had the room you have in the back of your durango. Under my rear seats are Strobe Paks useing the space.
          Running MediaCar
          Commell LV-670
          P4 1.6Ghz
          Corsair 512Mb
          60Gig 7200rpm 133
          8" Touch
            Im on Dakotausa/DFWDakotas/Dodgetrucks/bionicdodge and probably a couple others. My sub/console is in the place of your case/console.
            Heres a couple pics...
            The console houses a singe 10"
            Another pic of the console.
            Heres one of my truck
            ...and the start of the amp rack.
            Setup:
            Dynaudio 240GT
            Zapco DSP6
            ADS DAC
              no computer? but that looks great!!!
              Running MediaCar
              Commell LV-670
              P4 1.6Ghz
              Corsair 512Mb
              60Gig 7200rpm 133
              8" Touch
                Its in and out till I get the screen mount made.
                Setup:
                Dynaudio 240GT
                Zapco DSP6
                ADS DAC
                  Off the PC subject, but do you have a lift on your Dakota xGROMx ?
                  2003 Matrix Install
                    naa, i cranked up the torsion bar to lvl out the truck, and those are 32's
                    Running MediaCar
                    Commell LV-670
                    P4 1.6Ghz
                    Corsair 512Mb
                    60Gig 7200rpm 133
                    8" Touch
                      (psst... start your own thread)
                      nice work onthe case! it looks very professional. it was nice to see the angles and not just a big *** cube. good job!
                      New System in progress:
                      M10k
                      Phaze TD1500 ~> Seas g18rnx/p
                      Zapco Ref 500.1 ~ 12" tc-9
                      Transflective Xenarc
                      My Car Pc Install
                      My Boat Pc worklog
                        (psst... kill yourself)
                        XGrom are you going to mold the screen in?
                        Setup:
                        Dynaudio 240GT
                        Zapco DSP6
                        ADS DAC
                          I am thinking on it.....i want to put a cd player back in and run the system through it......I like how Matrix did his install down low....the bottom line is i don't want to destroy the dash.
                          Running MediaCar
                          Commell LV-670
                          P4 1.6Ghz
                          Corsair 512Mb
                          60Gig 7200rpm 133
                          8" Touch
                            That was my biggest item to get past. I have all the confidence I can pull it off, but I would still have to mount the radio somewhere. I prefer to keep the radio because I do not want to always boot a PC for small trips. The other big reason for mounting it low is to elimate a lot of screen glare, that was my biggest issue with my Toyota install.
                            2003 Matrix Install
                              I drove around testing the it down low and didnt like the idea of looking low to see the monitor, but its less work. I also use the receiver for all crossovers, and minor eqing and time alignment. So I'll have to relocate the receiver to the glovebox, or something. You guys are so lucky to have the space down low though. I have a manual so its not that easy. Just remember you can get a replacement dash panel for probably 20$-$30s. Just good to see another Dak/Rango puting.
                              Setup:
                              Dynaudio 240GT
                              Zapco DSP6
                              ADS DAC
