My 2002 Nissan SE-R Spec V Carputer
  • My 2002 Nissan SE-R Spec V Carputer
    It's late, so I'm mostly just reposting from my thread on B15sentra.net. I've been working on this for a while, there's still more I want to do with the car and carputer (like a back-up camera, wi-fi, etc. Always looking for ideas and suggestions). I've seen a few projects on this site and used them for inspiration and ideas, so thanks to those folks. If you have questions, suggestions or opnions please share.
    -Boris
    -outside shot. the rain finally stopped, so I washed her up real nice like.
    -front grill shot...if you could only see all of the road rash. Oh it hurts!
    -Wide shot of the interior dash
    -shot of the screen. I'm running microsoft streets and trip, it's not bad but there's a list of features I wish it had. I'm going to try iguidence after reading some of the posts here.
    -Side view of monitor. I want to get some sort of shroud to cover the sides, but the gap is so small it would get pinched when closing. Any ideas or suggestions?
    -Stock looking while parked. You can also see the mic, right next to the temp gage.
    -extra usb port (blurry picture not your eyes)
    -Keyboard in the glove box
    -New din panel. Dvd-Rom eject (flush when closed), toggle on the right is for aux input on/off. Button and led on the left is for laptop.
    -Old din panel
    The Carputer has been my biggest project on the car, since I had some of the major components and figured it would be cheaper than getting some of the other performance mods I want. I knew I could take advantage of it on a daily basis. My major guidlines for all mods are: I must be able to return the car to stock at anypoint (so no cutting, drilling or damaging stock parts) and I want to be able to do it myself or with the help with a friend.
    I started with a compaq PIII 1Ghz laptop that I already had and then got a touch screen, and other compenents. My goal was to run the audio from the laptop through the stock HU. My first setup was used 4 toggle switches that interrupted audio from the HU to the amp with audio from the laptop to the amp. This worked but wasn't my favorite since I had to control the levels from the laptop and had to toggle four switches to change inputs. I eventually found the CD changer pinout and made an aux. input from it that is controlled by a single toggle switch on a panel in the spare din. On the panel I also put a DVD-Rom, on/off for the laptop and indicator led.
    The laptop was originally going to be under the passenger seat, but I then decided to relocate it to the trunk. The touch screen tucks away for a stock look when parked to avoid extra attention. Finally I put a flexiable keyboard in the glove box and a usb port in place of the second 12V outlet by the e-brake. Part of the setup includes the ability to switch the aux input from the laptop to any audio device with a 1/8" mini socket (like an Ipod). I have a gps reciever and I'm also running voice recognition software. I haven't had much luck with microphones and the road noise ratio, but when parked it works great! I'm going to try a bluetooth mic (those cellphone ones) see if that works better. I just bought a wireless nic and since SF is getting free Wi-fi throughout, maybe I can stay connected while driving. I'm using winamp with my own "touch-screen" skin for audio and video controls.
    Next step is to add a webcam to use either for security (get the license number of the bastards that ding your car when you're not around) or just as a back-up cam.
    Well I think that's about it. I can do a write up on the monitor mount if anyone would find it useful.
    '02 Molten Silver SE-R Spec V
    K&N CAI Car-puter
    What about some type of cloth material (something that does not wrincle as bad), it would not look perfect, but it would eliminate the gap.
    Your setup looks good though. I like the setups that get tucked away when not in use.
    2003 Durango Install
    2003 Matrix Install
    2004 Escalade Install
      Im still new to carputers but how did you get connection behind the slot dvd to the computer, are there longer ide cables if so I've been searching with no luck
        Matrix 24: I thought about a cloth solution...I think that's probably the only way to go, I just need to find something that pulls in behind the screen (stretchy material?). Otherwise if you look at the pic where it's closed, it would get pinched between the lid and the outside wall, with part of it sticking out. I don't want to have to tuck it in manually each time.
        Husalah5150: Here's the DVD-rom I ended up getting: http://www.targus.com/us/product_det...?sku=PACMB010U. It's a Targus USB 2.0 slim drive, I found it for $127, which is still a bit pricey. The reason I got it is that it uses one USB port for data and another for power (you can still use that second port for a keyboard or mouse, so you don't lose a port). It saved me on haveing a sepearate power adapter or tapping into another power source from the car.
        K&N CAI Car-puter
          On the escalade install I did we were going to use fabric and some elastic. If you make the elastic draw to the center it will not get pinched. We can talk more through PM if want some more info.
          2003 Matrix Install
            kudos on the stealth install, i am planning on undertaking something similar myself. i'm curious to know what else you did to get the factory head unit to "see" the audio coming from the computer through the CD changer harness. I have a copy of the FSM but i'm sure it's not as simple as tapping the left and right audio channels that lead to the HU? any details would be greatly appreciated.
            Sedtc
              So you might be in a diiferent situation since you have a 2005. Although it might not be the cleanest looking solution, I think your HU has an aux 1/8 in the front (right?). You definetly have a different Changer connection at the back of the 05 HU.
              On the 02 HU I used the harness pinout to identify the L/R + - cable and the power cable. I spliced the audio cables to plug into the stereo out of the laptop and the power to a 12v source in the car. I think the setup would benifit from having something like a pre-amp or some converter between the laptop and the HU unit to balance out the signal and put it into a better range for the HU.
              I don't know enough about audio to know what that unit is and haven't done anything yet. Still searching. But the audio levels are fine, the quality is exceptable to my ears (depending on the mp3 or movie audio quality, ofcourse). The only thing that I've noticed and wish I could fix (this may just be an issue with the sound card in my laptop) is that most of the bass is played by my speakers rather than my sub. I'm guessing this is an issue with the laptop sound card since CD playing from the HU have plenty of hit on the sub. It could also be the fact that the stock amp doesn't have a dedicated subwoofer ouput, but rather splits off from the two rear channels. Since the CD changer input is only stereo (as is the ouput from the laptop) the HU, which spits out 4 channels might not put as much to the rear 2 channels as the front ones.
              Anyways, there's more about the actual audio connection and setup here:
              http://www.b15sentra.net/forums/showthread.php?t=123232
              K&N CAI Car-puter
                heres my computer screen.....in my 02 spec v molten silver..
                  molten silver must be a popular color. Serena [read: my car] also wears a silver dress.
                  thanks for the info daspiderboris i believe that a similar setup with the relay may work in my vehicle as well. you mentioned that you weren't too keen on the low frequencies of your setup, have you considered ditching that puny sub on the back deck and running the speaker level signals to an aftermarket amp and sub? this will most likely be my next step after i get the computer together (of course in a fiberglass enclosure that i plan on building )
                  utley3specv, correct me if i'm wrong but didn't i see you posting over on the vboard in the audio section as well? I like your screen install although i have opted to go for the stealth setup over the fixed display [damn thieves and vandals are everywhere!] what are the specs on your system?
                  sorry for the novela; so much do say, so little time...
                    definetely a clean job on the screen (great job on the reflection of yourself taking the pic ). I like that it's set in a little, should help with glare when the sun is straight up. I've been thinking about adding a little something for that as well.
                    But I must also agree that I defeinetly didn't want it up all the time, especially when parked. Less attention the car draws to itself, less likely someone will break into it. I never keep anything out on the seats or in clear view (except the car itself).
                    I think Silver is the "safe" color. It looks good, doesn't look dirty as fast as black or white might and scratches/swirl marks aren't as visible. When I picked mine up, the dealer only had this one on the lot. At first glance I actually thought it was a little too much, the seats the wheels and I still hate the back of the car like nothing else. But the price for the "features" and power was better than any honda or toyota I could afford and it's my first manual transmission. When I rode in it, I fell in love. I drove it right after a carolla, just comparing the exhaust note of the two around 4-5rpms, I knew I wasn't getting a carolla
                    Back to the audio...I actually think the stock rockford fostage package I have sounds pretty good. It's got enough kick for my tastes, plus I'm pretty picky on what I spend my money on. I think before I do audio, I'd want to get some of the performance mods onto the car. I also want to finish the carputer, get a reverse camera and maybe an infared forward one. I also need to finish Bluetooth enabling my phone and voice recognition.
                    K&N CAI Car-puter
                      I like how the screen folds back into the dash.. That's neat.
                      CAR INFO HERE
                      "He who dies with the most toys, wins".
                        Need more info!!
                        Hey daspiderboris!
                        I've got a Spec V too, and I've got a couple questions for you.
                        1. Where did you find the aux in adapter, how much you paid it, and how did you install it?? I'm asking that because I searched a lot about it, and my results were that you can only find an adapter like that for the 2004-6 head unit models...!
                        2. The dvd drive you installed on your din panel, is it a usb extenal drive?
                        3. Is your carputer still in the trunk? How did you installed it?
                        4. Can you post pictures of it?
                        Thank you!!
                        Phil
                        The Car : Nissan Sentra SE-R Spec V 2003
                        The CarPC : Via M10k - 256mb - sb Live 5.1 - lilliput 7''
                        Media Center status : 33%
                        Car Installation status : 33%
                        WorkLog : http://mp3car.com/vbulletin/showthread.php?t=77258
                          i was curious if you had to do any major modification to get your monitor in the top bin. one of the ideas i've been entertaining involves using rails to guide the opening and closing movement and a hinge at the top of the moniter. (borrowed the idea from another sentra install here; i lurked here for nearly six months religiously before signing up for an account)
                          by the way, i know what you mean by road rash. everytime i detail Serena i think that i find a new knick in the paint. [rolls eyes] Nissan should have considered adding another layer of clear coat on our cars, seems like the paint might scratch if someone looks at the car too hard!
                            Aldaris, I checked out the thread on your car, I like where you're going with screen. I'll post some questions for you over there.
                            So you're right in the sense that the 04 and up models have an aux. input (1/8" stereo jack) right on the front of the HU. But the stock HU has always had a port on the back for the CD changer. I found a cable (8pin Din) that plugs into that port (I think it was the same as an Alpine M-bus cable, let me know if you're having trouble finding it, I'll try to get the details on it) about $30 at a car stereo install shop. I used the diagram from djr1specv's thread on b15sentra.net (I'm sure I've seen it here on this site too, but the b15 link is above) to get the right pinout.
                            Now the only problem, and I mention it in the link above, is that the 03 HU is slightly different from the 02. I think you acutally have an aux. button on the front or the CD toggles between aux and cd. Is the right? I think that's because in the 03 they made it so the HU controlls the CD changer, while in the 02 the changer had it's own controls on the faceplate. If the back of your HU doesn't have the round 8pin din, you'll have to do some more digging. I also found that you can see part of the circuit board on your HU and it has the pinout (which is easier to read once you already know what they are ).
                            The DVD drive is an external Targus drive. I picked it because it uses 2 usb ports, one for data and one for power. Made it cleaner to install since I didn't need an additional power tap to the battery. But it cost $127 which is a bit pricey for a DVD drive. But since the one on the computer died anyways, it's the easiest way to install software from disc.
                            I'm using an old laptop for the actual computer (I already had it, and wasn't using it much and it was free rather than buying compenents to put a pc together. Only thing I bought was a port replicator for it).
                            I still haven't gotten around to taking pictures of it in the trunk, but I will. I found a case that it "fit" into and that case is velcro-ed to the trunk floor. Keeps it from sliding around and stays with one of my main goals, easily returning it to stock.
                            One thing I should have done, that you did, is hit up a junk yard. If I had a spare bin where the screen is I would have been open to other ideas for mounting it, since I could cut and drill into the spare bin.
                            K&N CAI Car-puter
                              I've seen Tony's thread and the way he's doing his install. That is originally what I wanted to do with mine, because it seemed as though it would fit better this way. It also creates an oppertunity for motorizing the display. But again, going back to being able to return the car to stock, since I think I'll have less trouble selling it without the car-puter and other mods (I think people are skeptical when buying used cars, and seeing that someone has already pulled the dash apart, run cables, installed monitors, etc. doesn't help. Plus a dealer wouldn't give me more money for it having a computer in it).
                              My install is very simple...All you need to do is take out the top bing, remove the bottom potion of it (just 4 screws) and then seperate the inside of the lid from the outside (again, just 4 screws). Then I got a piece of alumnium from Home Depot (very similar to the piece that Aldaris has a picture of on his thread. It was thin, light and durable. Very easy to work with for cutting and drilling.
                              One piece you can see in the monitor side view pic above. It stretched across the top bin and mounts into the two holes that held the bottom lid insert. Into this piece I added a simple gate hing that allows the screen to swing in and out.
                              The other piece stretched across the top of the air vents and uses the mounting holes that hold the vents to the console. In the middle of that piece is a screw with a round head, the monitor has a 90 degree angle that slides over the round head to hold in place while the screen is open.
                              I'm sure some of that doesn't make sense, I'll take some pics to show you. Things are busy at work, but should slow down in a week and I'll have some more time to mess with the car.
                              K&N CAI Car-puter
