95 Civic Hatch: relocated a/c + 6000 watts and 300hp *tons of pics*
  • 95 Civic Hatch: relocated a/c + 6000 watts and 300hp *tons of pics*
    *new pics and update page 5*
    I've been a long time lurker and finaly decided to post. I have actualy been running my setup for over a year. Some of the pics are outdated, some new and some of the text is as well. I am copy/pasting from an old post from one of my forums I frequent. If you happen to catch me in mid post please be patient while I gather all the old pics.
    Specs are:
    Performance Modifications:
    1.6l 16 valve single cam VTEC D16Z6 engine.
    Bored to 75.5mm
    Wiseco 8.8:1 forged pistons
    Block posted ( to prevent cylinder walk) stock sleeves.
    Eagle Rods
    ARP Head Studs
    Line honed and polished crank
    Balanced rotating assembly
    T3/T4 T04B .48/.60 Turbo
    31x6x2.75" Boost'n Front Mount Intercooler
    TurboXS RFL Blow-off Valve
    Manual Boost Controller
    DIY homemade turbo manifold, charge piping and exhaust.
    Ostrich realtime romulator
    Crome Pro tuned
    Techedge 2.0a Wideband controller
    Driveline and Suspension:
    Quaife Limited Slip Differential
    Lightened steel 12lb flywheel
    Clutch Specialties 400ftlb TQ holding capacity Stage4 clutch
    Gator Axle Stage2 Racing Axles
    Cross-drilled and slotted front rotors
    H&R Sport lowering springs
    Front Strut Bar
    Interior:
    Complete color change from blue to black.
    Relocated A/C controls from center to left side of steering wheel.
    Custom fabricated 8" Touchscreen monitor
    Overhead roof console with control switches
    Boost, Temp and Oil pressure gauge
    Flush mounted Wideband O2, and Voltage displays
    Audio:
    Controls:
    CarPC 1.3ghz, 200GB Hard drive, Digital surround sound, 128mb Gforce4, Wireless Bluetooth, DVD
    Windows XP Pro
    MediaCar software - all MP3's WMA's etc. stored on harddrive
    Lilliput 8" Touchscreen Monitor
    Sherwood DTS decoder ( digital 5.1surround sound )
    Pioneer Headunit
    Power:
    2 Batteries fed by a 170amp Alternator through Stinger Expert 1/0 guage wire
    2 Merlon Audio 3000 watt Class D mono block amplifiers ( 1800 RMS per amp )
    US AMPS 4x80 USA-442 mids and highs amplifier
    Kenwood 25x4 bridged to 2 channel running centers
    20 Fared Tsunami Hybrid capacitor
    Sound:
    Front - 2 x 6.5" Kole Audio Compenents
    Rear - 2 x 6.5" Rockford Fosgate coaxial 2 x 4" Rockford Fosgate mid drivers
    Center - front dash mounted 3" fullrange, rear overhead console - 3" fullrange
    Subs - 2 Orion H2 15" dual 2ohm voice coil subwoofers tuned to 44hz
    155.6db termlab
    Security:
    Audiovox 997a Alarm
    Power door locks
    Remote start
    LCD two way paging system
    Built in Turbo Timer
    The Numbers:
    297whp at 20psi ( Built to withstand 375-400hp )
    Best 1/8 mile to date Immokalee Regional Raceway
    7.80 @ 89mph 22x8x13 M&H Racemaster slicks. Full interior at 16.5psi minus subwoofers ( 273whp )
    0-60 in 4 seconds ( On drag slicks )
    48mpg when new at 70whp
    30mpg at 16psi daily drivin 50+ miles
    On with the setup!
    Dewiring the beast. Man I have enough wire to go around the world! I bet if I wasnt into my luxory I could go a tad faster lol. **** adds up in the ol weight department.
    Testing fitment of the console and DVD clearence.
    First stage of power switches before final fit and paint
    Hardware. Went with a FULL ATX motherboard for now lol. Its my old PC and is a pretty badass gaming system for the most part (for a car I mean). Runs Doom3 quite well some vinyl still to do. No wait I mean ****LOADS to do.
    Same thing just looking from the inside.
    My carpc post: Relocated a/c + 6000 watts and 300hp *tons of pics*
    http://www.mp3car.com/vbulletin/show...highlight=6000
    http://img214.imageshack.us/img214/2...burnoutzf6.jpg
    a/c wire harness extended
    USB ports under dash
    Dash trimmed ready for a fill. Get out of the way you damn wires!
    test run and fit
    I decided to do a full interior color change (from blue to black/gray). Man let me tell you talk about some serious work!! I have the doors to redo, front seats to dye, backs look awesome btw, carpet to replace and thats about it. Some fine tuning and tweaking and its DONE!!! Its basicaly installed and working. I'm really loving it just two problems...no ashtray for my spare change and no more cupholder uh oh The final pics will be coming in the next week or so as I finish up the interior.
    Monitor bezel mounted
    Sanded primed and ready for paint.
    A/C controls going in
    First layer of filler.
    Primed for paint
      A/C control head circuit board cut and rewired.
      COLOR CHANGE!! Remember to wash, dry, rewash, dry, scuff, wash, dry before painting this badboy. You don't want it to peel or scrape.
      This was done in 2 weeks time working to 2-3am and getting up at 6:30am. Yes 3-4 hours sleep for nearly 2 weeks solid. I think I missed a few nights because I was flat beat. I only worked on it a few hours a night doing what I can after my family goes to bed. Time is hard to come by and there just isnt enough hours in a day
        Doors recovered. Vinyl can be a major PITA! So much better than that ricer white crap hah.
        Interior parts:
        Seats dyed using RIT dye.
          Much has changed since these photos but here goes anyways. The stereo system has also changed 3 times I will try to post them all up to current.
            The second phase. Audio system change for a show.
            Specs are:
            CarPC
            8" Lilliput touchscreen - DVD, mp3's, wma's, Crome Pro, Datalogging etc all stored on 200gb harddrive. Runs on windows XP Pro.
            Pioneer DEH P9300 headunit
            Sherwood DTS processing controller for 5.1 surround sound.
            2 - Autotek 750.1 amps for the subs (flush mount on either side in the pics)
            1 - 6 channel (5.1 surround) Sherwood DTS amp running mids and highs (flushmounted on rear seat backs).
            2 - 12" TM Rush comp 12's in custom "shorty" tubes (14" tubes tuned to 60hz)
            2 - Kole Audio 6.5" and 1" tweeter components in the front.
            2 - 3.5" Pioneer center channels ( 1 in the front dash vent and 1 in the roof console for rear center)
            2 - Infinity 6X9's in the rear soon to be replaced with 4 - 6.5" in custom enclosures.
              work in progress here. This is my roofconsole. It has all my system and pc switches, rear center channel speaker sunglasses holder blah blah.
                Phase 3: Yet another show and it was time to go even bigger. 2 Orion 15" H2 subs. The carpc was relocated to the side panel like the US amp pictured. I will try to get some newer pics soon.
                ****ty pics off a ****ty camera along with my somewhat incomplete setup. This was built literaly overnight for a show. I wound up taking 1st place in 2 classes (spl and street beats). I have a few minor details to take care of, side panels for the carpc and my USAmps mid/high amp. New rears to go in as well. Yes the subs are facing up. But Biz dont ya know they will sound louder facing back? Yes and no. This was the only way to get enough airspace and still be removable. The box was built to Orions specs and it does sound friggin great. I love it.
                  Looks good. We should race - I have the Ford version of your car, with 302 hp.
                  Do the subs affect the carputer at all - vibrations, etc...with the subs right on top of the carpc?
                  www.mobile-effects.com
                  Free file hosting, picture gallery hosting for installs, PM me.
                  Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
                    For an added bonus a few engine shots It made 297 hp to the wheels at 20psi of boost. The engine bay wiring has been cleaned up quite a bit. I seriously need to get some recent photos sort of embarassing :P
                      Last but not least its all I could find http://media.putfile.com/derekdyno2
                      edit: didnt see your post. No the sub (kicker) or the TM rush tubes didnt effect it at all. I did have some early problems of the video card popping out but after some hot glue its been rock solid. Like I said its going on over a year and still running good even with the 15's hitting 155db.
                        The work is sweet man.. but get rid of the rest of the white interior...the paint job has to go. Go full class man...loose the rice!!
                          All I can say is WAWWWWWWWWWWWWWW
                          car: skoda octavia 2006 just started my project but i dont' have anything for the moment
                            holy crap. 300hp out of a 1.6!!!!! i would love to get my french POS up to 150!
                            For your seats what colour where they and do you have any more details about dying them? I am tempted to dye my green ones black/charcoal as i cant afford to replace them
                              Thanks for the comments. All of the white is GONE! As for the paint, I know but many people like it. I've owned the car for 11 years and its been painted like that for...11 uears. Back when I was younger and it was new, it was very cool lol. Lend me 5 grand and I'll paint it. No cheapy maaco jobs for me.
