Modified Xenarc MP-SC3/Sumicom S350
  • Modified Xenarc MP-SC3/Sumicom S350
    Well, I have been lurking these forums for awhile so i figured I would let you in on my setup.
    I purchased a Xenarc Barebones MP-SC3 and a usedf P4 2.4ghz HT CPU. I noticed that while running this at 1.5ghz the temp was idling around 63degrees celcius, a bit too hot for my liking so i decided to do some modifications
    I had a Video Card cooler (Vantec Iceberg pro 5) that I was no longer using and discovered it fit prfectly into this pc. I cut a large blow hole and also added mounting feet and a fan filter and then painted it flat black!
    It now idles at 47 degrees celcius and looks pretty cool!
    Nice litte box you have. look forward to see the rest off the instalation
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
      Well, Back in August I finished my install, and figured I would show you guys the rest of the install!
      My only concern was the temperatures here in Canada with the hard drive, but so far we have hit -10C And it started up no problems
      enjoy!
        looks good!
