1999 Acura TL
  • 1999 Acura TL
    I used a Metra kit and cut up the useless stock cd holder and used bonda/glazing to flush everything. Under the screen is my radio. Its an Alpine, its off so its face is folded in.
    you are probably using the same paint as i do, metallic textual paint KRY101. U should used flat black paint to match your rest of the oem look
    2006 Camry
    Compaq Laptop
    Holux GPS Iguidance 3.0
    7" Xenarc Touch Screen
    Carnetix 1900 Power Supplied, Wireless b/g
      Ive used flat black in many of my projects and it always looked like crap. flat black isnt a great "finish" paint IMO. so i was thinking of painting the rest of my console the same metallic black.
        Umm, try a semi-gloss or satin finish, which are both widely available (which means HD, Lowe's, or Wally World)...there's not much in a car interior that's truly "flat" with the exception of rubber trim.
        An amateur built the Ark. The Titanic was built by professionals.
          i tried those already, many many times. not a big fan of those finishes. i guess because ive used them so many times before. i came to find out that when i used this metalic finish, it kinda hides the inperfections. thats why i like it.
            You have any working progress pictures? I have a 02 TL and I'll be doing the same thing...moving the HU down to the ashtray area...I would like to know how you cut the piece and how you mount/secure the HU
            BTW....looks very nice!
              use flat black like you normaly would. Then for your last coat, mist the flat black from 2 feet away. You'll get a percet OEM look.
              Installed
              Asus A7N8X-VM - AMD Mobile Athlon 2400
              512 Ram - 60GB HD - Opus 150w
              Lilliput 7" - Rikaline 6010
              [00000000000001100010-] 98% Completed
              Check Out My Install!!!
