1998 Volkswagen Passat
  • 1998 Volkswagen Passat
    We'll, new car means new carputer =D
    When I got the car it had a 1-din stereo in it, but as I wanted it to look as OEM as possible I got hold of a 2-din module and "just" (some adjustments) swapped it.
    I've built a 2-din module for the Xenarc in 4mm plexi, will upload better photos of it later.
    Carputer hardware is as follows:
    Xenarc 700TSV
    Epia M10000
    512mb ram
    Opus 120w
    60gb 2.5" HDD
    BU-353
    Netgear WPN111
    D-link DBT-120
    Most of it it from my old carputer, but wlan and bluetooth has been added.
    I'm using standard WinXP Pro (swedish) with standby. I'm running FreeWay as frontend, and FreeDrive for gps.
    The carputer itself has been mounted in the sparewheel compartment, together with my amps. It has one vga and one usb cable running to the front. I had to rip everything out...
    Mounting of Mobo, HDD and PSU.
    "Finished" mounting of amps and carputer. All cables has too be shortned thou. All of it is 10mm plexi. The 400w amp drives 4 1/2" tweeters and 4 6.5" midrangers (placed in the doors). The other amp is 2x400w, bridged to 1x800w, and it drives a 12" MDS X-MAX sub.
    Finished:
    My carputer
    Old one
    Very clean....
    How about the Wiki?
      nice oem look
        more proto of the computer install
        Plan for project = 100%
        Part the project. = 100%
        Built...................= 99%
        Finish.................= 99%
        Install ...............= 99% -50%
        Ditail at 4u2n.dk
        Here
          Yeah, have added some now =) When I first posted this I noticed I didn't have any of the finished install, so I took some today.
          My carputer
          Old one
            tjena
            Hur klarar sig skärmen under vintern i kylan? Det är ju ett jätte stort problem att lösa. Jag kör med avtagbar skärm, det är ju ett måste!
            Vart hittade du kartorna över sverige? har du köpt dom eller "hittat" på nätet? Ge gärna länk om du "hittat" dom
            tack
              tjo!
              Den klarar sig utmärkt. Har kört med den två vintrar redan, och det funkar perfekt. Den är dock lite långsam innan den blivit varm, men det tar högst några minuter.
              Kartorna hittade jag för länge sedan, så har tyvärr ingen aning om var de går att få tag på. Det är typ 2001 års kartor eller nått sånt :P Haha...
              My carputer
              Old one
                Har du en plan af dit beslag? altså med mål, overvejer at lave noget ligende til min passat http://www.bilgalleri.dk/html/gal_visbil.asp?ID=57519
                  tyävrr inte =/
                  My carputer
                  Old one
                    whered you mount your GPS receiver at?
                      Look at the photo just below the sentence "I had to rip everything out...". I've mounted it right behind the left wheel housing. It sits behind metal, but it locks on 8 / 10 satelites thou, so it works pretty well. (upgraded to a bu-353 last week)
                      My carputer
                      Old one
                        that double din converion is a right mission to do, took me a day in all
                        2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
                          how is your fan getting fresh air?
                            The fan blows the hot air out of the sparewheel compartment. It gets in from pretty much everywhere... Here is a better pic:
                            My carputer
                            Old one
                              But arent the carpet covering for the fan hole?
