2005 Chevy Tahoe Z71 - Complete! (Lots of Pics)
  • 2005 Chevy Tahoe Z71 - Complete! (Lots of Pics)
    I have been in the computer industry for over ten years and I have always had dreams of what it would be like to integrate a computer into a car. It was not until I found this forum that I had any clue that this idea of mine not only existed but has been around for many years!!! Well I am very glad I found this site when I did (my first attempt was using a PocketPC). I would like thank everyone who has beat down the path for me and for providing the motivation and inspiration. I could not have finished or even got started without the info contained in this site.
    Anyway, here are the specs for my setup. My primary goal was to keep the factory look and make it user friendly enough that my wife would even use it!!
    Car: 2005 Chevrolet Tahoe Z71 with 5.8 liter Vortec V8, 4wd towing package, Sun roof, full leather, 3rd row seating.
    Carputer:
    SP-716 Motorized 7" Touchscreen……………………….......…...….$286
    PAC GM Factory Adapter…………………………...........………..………$80
    VIA EPIA SP13000…………………….............……………………….……$200
    PQI 512mb………..…………………………………………...............….……$25
    Hitachi 160gb 3.5" SATA…………………………………………...........…$30
    Targus DVD/CD-RW combo USB Drive…………………….........……$53
    Opus 120…………………………………………………..............….…….…$100
    Level1 802.11g USB Adapter…………………………….………...........…$1
    Wireless Keyboard with mouse…………………….…………........….…$30
    Bluetooth and IR Dongle ($5 Each)……………………….….......….…$10
    Inverter with Game port………………………………..……...........…….$10
    USB 2.0 Hub…………………………………………………...............……….$10
    Switches, Distro block, Wiring, LEDs, USB Extension cables…$150
    TOTAL:……………………………………………………….………$985
    Software:
    Windows XP Professional
    Arkon MobiNavigator (IGuidance clone)
    RoadRunner for the front-end with LSX Void skin (THANKS LS!!)
    VNC
    EasySync
    10,000+ MP3s
    There are a few things that are not working yet. I still have to get PhoneControl and voice control up and running and for some reason I was never able to successfully use Xport to split the output for the GPS.
    Overall, I am very happy with how things turned out, but I do have a few future improvement planned. First I want to add a review camera. Then I would like to improve the sound quality by either adding a sub or a sound card in place of the on board sound. Later on I plan to add monitors in the front seat headrests.
    And now the pics:
    There is a full album at: HERE but here are a few highlights:
    The Car:
    Original. I decided that I would keep the amount of dash cutting to a minimum. I was able to install the flip screen, status LED;s and USB ports in this one piece. This way I only have to replace this one piece if I sell the car:
    Front-end:
    The Dash. This location works very well, not much glare but also in easy reach.
    The console:
    Keyboard:
    Off and IRDA + Bluetooth adapter:
    On:
    Motherboard. The motherboard is located in a cavity on the drivers side of the center console next to the center compartment. This worked very well and I still had room for wiring and a USB bracket and for the inverter in the rear panel of the console. There is a TON of room in there!!!
    Armrest compartment. I was able to locate the slimline USB DVD/CD-RW drive at the front of the compartment. Just to the left of the drive is the reset switch. In the rear of the compartment is the auxiliary power port and RCA connectors. To the left of that is the master switch.
    Under the cup holders. I was easily able to locate the full size hard drive, the receiver for the keyboard, the Opus 120 and still had room for a USB hub.
    Opus. The Opus is secured to area just in front of the center compartment. Just below that is the USB hub.
    Mic and GPS:
    very nice install, i like how you have a place to plug in av cables and power
      Images no work
        Thanks for the heads up...Images are now fixed.
          Nice install...i like your taste in keyboards LOL !!!!!!!!!!!!!! hope you will change the istallation of the mic..... i would integrate it into the A-piller cover
          http://www.sounddomain.com/ride/856246
          Please visit my new site http://www.Gigabitcustoms.com
          My worklog http://www.mp3car.com/vbulletin/showthread.php?t=52720
            Nice install man, very clean....
            Just out of curiosity, what made you keep the factory HU?
            Carputer Progress
            [||||||||||] 100%
            Finally Installed!!
            Everything is in the car and working.
            I painted the cilpboard mount and it looks good.
            Shutdown/Startup is working excellent!
            View My Progress Here
              everything is ran throught the radio in the car.
              like warnings sounds and onstar and the interface box is like 200 bucks to have a seperate modual for the onstar and warning sounds.
                So does the factory radio still work... you hit a switch in the center console and the PC turns on?
                I will be more then likely buying a '06 Tahoe, and I was wondering about the factory HU coming to play with the Onstar system.
                Sorry if I sound like a newbie but I am .. or at least to the Tahoes..
                Moody Moodz
                  Question for you.
                  I have a 05 Avalanche, and I am fighting to find a place to put my 1300. I am a little confused on where you mounted yours. Do you have a couple of other pictures or a layout of the cab and can point it out?
                  Is this correct?
                  Looks great, like the stock look.
                    Your stock HU seems to be the perfect spot to mount a screen - why did you decide against that? Glare? - It would've looked wicked stock up there!! - You could've then put an aftermarket HU where you currently have the Flip-Up -
                    I dunno how it is when sitting in the driver's seat, but the location seems a lil' low for the vision - or am I wrong? Just concerned with safety -
                    Very nice work altogether and I LOVE how you managed to hide the PC under the console - I have an SP13000 too and that's pretty much what I did with mine - Great work!!!
                    VER. 3.0- Check out below:
                    車コンピュータ 3.0
                      Originally posted by Fraychild View Post
                      ...It would've looked wicked stock up there!!...
                      lol I like that term, Wicked Stock!
                      Carputer Progress
                      [||||||||||] 100%
                      Finally Installed!!
                        ha... i bet he's from the eastcoast!
                        New System in progress:
                        M10k
                        Phaze TD1500 ~> Seas g18rnx/p
                        Zapco Ref 500.1 ~ 12" tc-9
                        Transflective Xenarc
                        My Car Pc Install
                        My Boat Pc worklog
                          i need software for my carputer
                          hi friends
                          i really need a good software for my Carputer
                          I have a Pentium 3 1Ghz with 512MB RAM and 40GB Hard Drive, with touchscreen, but is HARD to use Windows XP with the touch screen
                          Please share to me any good software to hear music, use the GPS, and see videos with my Carputer,
                          Please help me
                          Bye !
                            Originally posted by alejandroborja View Post
                            hi friends
                            Please help me
                            Bye !
                            Check the FAQ man if you search you'll find it.
                            The old setup http://flickr.com/photos/ilyassx
                            The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
                            Jetway J7F2WE VIA C7 1.5 GHz
                            512 DDRII 533
                            3.5" SATA2 H.D.D 200GB
                            M1-ATX
                            ELM327MS OBDII
                            Creative Audigy 4
                            PROGRESS:[########-]90%
                              Flip out screens in the stock HU location hit the shifter don't they? The install looks pretty nice, but I don't know how well I would like lookin' down that far for the screen.
                              When did they come out with a 5.8L Vortec?
                              Play with it, 'til it's broke.
