96 Lexus SC400 Install
  • 96 Lexus SC400 Install
    The top picture shows the monitor and how it was installed into the factory radio's cage. I disassembled the broken factory radio and embedded the monitor into it. Came out OK for a first time. Others show it installed in my car.
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    nice stock looking setup. did you put the computer in yet ? didn't see where.
    Ride Runner RR's Myspace
      I did put the computer in. It isn't totally mounted yet (i'm going to construct a mount from plywood. I'm using the spot the cd changer was mounted to. Here's a pic so far. I have a carnetix power supply from mp3car.com and it powers the computer and lcd. It's mounted behind the trim panel on the driver's side whereas the computer is on the passenger side. No wires dangling. The usb soundblaster is mounted over the wheel well behind the trim as well.
      512M ddr memory
      Mimo 7" USB Display
      XM Direct Tuner
        Sweet, another SC400 owner! I should post up pix of my setup, haven't done that ever since I finished installing it years ago...
        Lexus SC400
        Subaru WRX Wagon
          Do that. I'd like to see. The SC400 has the perfect opening for a monitor.
          512M ddr memory
          Mimo 7" USB Display
          XM Direct Tuner
            Here's some more pix of my project. Still need to add gps, but it is pretty much done. Cleaned up the trunk and mounted computer behind the partition in the trunk.
            512M ddr memory
            Mimo 7" USB Display
            XM Direct Tuner
              Here's a picture of the screen complements of JohnWPB. Very nice graphics (I removed the clock and replaced it with a lexus logo I created in adobe photoshop 7. . .didn't need the clock, already have one in my car). Nice, fast skin. Its called BlueDevil and is used with roadrunner.
              BTW, notice the line on the screen above the Lexus symbol. My radar detector fell off my window and scratched the screen. Actually it gashed it. Seems to work well still, but made me sick after all the work I put into it. The radar detector is now mounted below the mirror with a strap that goes through its bracket in case it somehow falls off the window again. That way it will hang from the mirror.
              512M ddr memory
              Mimo 7" USB Display
              XM Direct Tuner
                nice clean set-up.....question, what is that to the right of the LCD? cup holder that pops out?
                My First Carputer
                  Yeah, it's a weird cup holder like that.
                  Pics.
                  On another note: I strongly agree with your avatar pic!
                  For Sale: Carputer (CarPC) & RCA Y-Adapter
                  Newsflash: Take a look at my unsold stuff above, thanks!
                  Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
                    Here's how my 2nd try on my center console...
                    1st try had it mounted where you have it now, back seat passengers had the "dildomatic" shifter blocking their view.
                    2nd try, relocated A/C unit down below and molded the screen up top, I like it a lot, my 3rd version might move the screen up even further to allow a slot load dvd below the screen.
                    Lexus SC400
                    Subaru WRX Wagon
                      Very Nice
                      I am about to start my sc 400 carputer project
                      You guys are giving good ideas and this forum a priceless resource.
                      ACleanSC your pic looks good. How in the world did you Fab the center trim molding for the screen and move the CC?
                      Have you guys seen the picture of the soarer on this site? This guy incorporated his pc in the original cd changer housing!!!!!! *which is pretty much useless after a carptuer install)
                      Has anyone considered installing a slide-in cd/dvd where the vertical cup holder is?
                      Anyway keep up the good work I will be working on mine in the coming months and will put up picks. I am sure I will bother several of you picking your brains cause I will NEED HELP!!!!
                      Brent
                        Hi miwise. What screen is that? Make and Model?
                        Thanks.
