Finally installed my headrest monitors
  • Finally installed my headrest monitors
    I finally decided to install my headrest monitors myself instead of paying someone else. I am not an installer so I was hesitant to cut up my headrest but after some research on this forum and a couple of beers I said "_uck it!"
    I had to go with some 6.5" headrest because anything else would be too big, I'll upgrade them later when I install my Katzkin leather but for now these will do.
    some pics
    http://www.printroom.com/ViewAlbum.a...lbum_id=215827
    Not the best but it will do for now. Only ones sitting back there are my two daughters
      question regarding headrest monitor in general: When you run the wires, how clean are you running them, meaning, if you decide to lift the headrest, what will you see?
      I suppose the cleanest would be to drill through the metal posts holding the headrest in and running wire through them...
      Any pix of the wiring?
      Progress:99% not 100% because theres always something to do...
      Centrafuse on XP (lited)
      EN15000
      120GB 2.5" SATA HD
      1GB DDR2 Ram
      M2-ATX PS
      Slot-Load DVD
      BU-353 GPS w/Mappoint 2k6
      DWW-700M
        Sorry don't have any pics of the wiring but in response to your other question, I did not drill into the post because that would be more work and I was really pressed for time (only had about 2 hrs to do everything while the wife and kids were out of the house )
        If you lift the headrest you will see about 1" of wire which is fine because we never move the headrest anyway.
        The monitors have two inputs; I have one going to my headunit which is also a DVD player and the other will be going to the game system. Each girl can watch or play whatever they want to at the same time
