2003 VW GTI 20th AE Work Log
  • 2003 VW GTI 20th AE Work Log
    here is a pic of the car = )
    started this project a few days ago, and this shows what i have done so far, in order
    next week, ill get my hardware, and install it, ill add more pics then.
    the computer setup i have coming, is
    Albatron KI51PV-754
    AMD Athlon 64 3200
    wd scorpio 60g
    dvd rw
    ram 512
    m2-atx
    i alredy have the xenarc screen as u can see from the pics
    i also alredy have some other components, wifi esc.
    im still not sure how exactly im going to do the sound, the monsoon system might have an isue with volume, id like to atealst make it loud and clear.
    after i cut the screen, and was positioning for fitment so i can epoxy it in
    after epoxying it in, and did some bondo work
    back of the screen
    after painting
    after piting trim back on
    VW .:R32
    VW GTI 20th AE BMP
    looking good, love the car
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
      thread moved to the work logs sub forum.
      once you've inished, follow the sticky at the top and it will be moved back!
      Jan Bennett
        started putting together all the components, went to Frys and got all the missing parts
        now let the assembly begin
        VW .:R32
        VW GTI 20th AE BMP
          started and just to install windows i put it in an old case, untill i get all parts ready
          and some more assebaly
          and finaly windows installation yay
          VW .:R32
          VW GTI 20th AE BMP
            finished putting the dvd berner into the glove box
            VW .:R32
            VW GTI 20th AE BMP
              finished testing, and installed the mobo into the radio cage behind the screen, its a tight fit, but it works just fine
              VW .:R32
              VW GTI 20th AE BMP
                i got my psu yesterday, but i forgot to get a p4 to p4 connector, and a 20 to 24 pin cable, so ill have to wait till they come to be able to finish.
                i did finish the audio though, i followed the instructions to connect the monsoon, though i dont know if i need a ground loop isolator, with the laptop hooked up i didnt have a problem, though with the psu, it might be differant.
                ill have to see when i get the 2 missing part to continue.
                for those of you who have the monsoon and are thinking of conneting a car pc to it dispite some of the things i have read the sound is fairly good, although it could be louder, but its loud enough. i made my bod with 6 inputs, for a 5.1 system, but i disconnected the center channel, well because it was causing interfearance with the front channels, making them quieter. so im just useing the 4 inputs for now, and the all connect together, with a 5v voltage regualtor on the neg side of the left channel, its bleeding though to the right channel too, but only becase of the damn spliter, and the common ground in the 1/8 connectors. i hope ill be able to get some good grounds, and wont have any interfearance when the computer is on.
                VW .:R32
                VW GTI 20th AE BMP
                  i was able to get one of the parts today, and did most of the instalation, id finish it, but id have to take it apart to install the last missing part, a 20 to 24 pin wire.
                  anyways here are some pics of the progress
                  the dash 1/2 taken apart, so i can run wires, and connect power = )
                  where im sticking the USB wireless card
                  everything but the glove box is install, so i can install critical part tomarrow, and finish up in 10 min = )
                  VW .:R32
                  VW GTI 20th AE BMP
                    ah yes, the final day, everything is put together and running. there are still some glicthes, but will work them out over time.
                    i hope you guys like it !!
                    tell me what you think !!!!!!
                    VW .:R32
                    VW GTI 20th AE BMP
                      Moved to SOYP.
                      How about the Wiki?
                        looking good, how do you like it?
                        New System in progress:
                        M10k
                        Phaze TD1500 ~> Seas g18rnx/p
                        Zapco Ref 500.1 ~ 12" tc-9
                        Transflective Xenarc
                        My Car Pc Install
                        My Boat Pc worklog
                          it works quite well, dispite some glitches, im working on fixing them
                          :glitches
                          - right and left channels cant be on at the same time, ground loop though y ( need something that allows voltage to only go one direction, not sure what its called )
                          -slight fuzzyness, might need a ground loop isloator
                          -posable overheating ( might move computer to trunk )
                          VW .:R32
                          VW GTI 20th AE BMP
                            i was able to fix the problem with the ground loop causeing interfearance, and the left channel cutting the amp power, all with a ground loop isloator. i didnt need to put in a diod. i saw that other people with the monsoon had the isloator cut in after the 5-6v was indused, but i put it in befor, and i dont have any noise. also didnt have to "cut" anything.
                            VW .:R32
                            VW GTI 20th AE BMP
                              some new pics just taken a few min ago
                              the monsoon connector and ground loop isloator
                              hidden inside
                              driver seat, car off
                              car on at desktop
                              car on running roadrunner (for music)
                              roadrunner home
                              VW .:R32
                              VW GTI 20th AE BMP
