2000 Dodge Durango - Car PC/New Audio/Complete Dash Fab.
  • 2000 Dodge Durango - Car PC/New Audio/Complete Dash Fab.
    I've finally decided to start my project. I drive a 2000 Dodge Durango SLT and I love it. I've been a lurker on the forums for around a year now and it's always interested me.
    My full customization will include:
    STAGE 1
    • Research/Design/Construct custom dashboard
    • Build/Install Car PC
    • Install 4ch amp and new door speakers
    STAGE 2
    • Build custom sub box for 2 (hopefully 4) 12" Subwoofers
    • Design/Construct new center console to house Car PC
    STAGE 3 (If Possible)
    • Find/Buy Grey/Black interior of 2000-ish durago to replace stock tan
    • Design/Construct Digital HVAC
    For the dash customization, I need to work around the passenger-side airbag, any thoughts on how to do this?
    Wish me luck!
    Front Mockup
    Heres a rough mockup of what the dash will look like. I plan to do a MDF/fiberglass build with brushed aluminium accents on both the dash and center console. It's designed similar to the Chrysler 300 and the new GMC Yukon that I've seen
    How should I work with the passenger airbag? I hope it doesn't go off while I'm working!
      Where are you located?
      Setup:
      Dynaudio 240GT
      PPI PC4100, PPI PC2350
      Zapco DSP6
      ADS DAC
      Testing new board (Albatron KI690-AM2)
      "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
        Good ol' Michigan
          Here's a revised version of the dash mock up. I relocated the air vents to separate the driver and passenger air.
            I've decided to revise my order of attacking this project. I'm probably going to do most of the audio work first. Then I'll start the custom fabrication of the new center console before I attempt the dashboard and doors.
              A cheaper way is you can hackoff part on your 1.5 din to make an 7' lcd fit. That what I did with my 2000 durango. good luck
                I am planning a custom project of my own. Did you ever finish your project?
                T...
                  To help keep your airbags from blowing up in your face, disconnect the negative terminal off your battery. Sure you will have to reprogram the presets on your radio when you are done but its better than getting your head taken off by your airbag
                  For those who serve, life has a special flavour the protected will never know.
                    T...
                    Talk about thread revival.
                    Anyways here is my Durango. i simply had the radio slot made to a double din and intergrated the screen fully built so it looks like a head unit.
                    1X Ainol Novo Flame Tab
                    4X MK808b
                    3x Perixx Touchpads
                    3x 7 inch Screens
                    1X 7 inch motorized Screen
                    1x Win 7 PC
