1993 ford ranger Regular cab
  • 1993 ford ranger Regular cab
    Well I have st started the process of installing a PC into my new(to me at least) truck and thought I would get some thoughts on the screen location so here are some pics
    Thanks for looking
    sorry for the delays guys here are pic of the test fit of the LCD just did it this evening I have the system build and will be installing it in a couple of days I will post pics of it soon
      How's it coming? I'm curious as to where you're placing the computer and any periphials, as I got a '90 Regular Cab as well
        I will post some pic in a day or two as the remodeling of the house has kept me away fromt eh PC.
        as to where i put the pc i picjed up a old house alarm box and used that behind the drivers seat is a perfect fit I will get a couple pic taken and post them as soon as i can
          What the heck is the speaker behind/beneath the gear shift?
          Did you install that yourself, cause I don't recall that being on my brother-in-law's Ranger.
            LOL that was wear I had set it when i took the pic that was one of the blown speakers i removed from the mounts behind the seats
              here are the pics of the box installed i will get wsome more after the holidays in the bos is the m2 the motherboard a wifi router 2 usb hubs and 2 harddisks.
                If you got a list of parts and more pics thatd be much help since I might do one in my truck. Now that I got a GPS for christmas i'll wait a little longer
                  well the list of parts was fairly simple I used a FlexATX motherboard running a 866P3 with 1GB ram a M2-ATX for power a 4GA amp install kit(already had one from another project) a 7in touchscreen the wireless router is simply there as I do alot of tech calls in areas without High speed internet and it allows me to easily share my cellphone net connection without having to install software and drivers into clients PCs I will get hardware pic posted some time tomorrow oh and 2 4port USB hubs
                    here are the pics of the start of the install when i first started with the dash
                    starting to cut the hole
                    here are the rest
                    ok here are some pics of the lcd being molded in would love to get some of you guys thoughs on it I hope to get it primed in the morning
                      Looks pretty good.
                        here are couple of pics of the inside of the case I will get some better ones taken when I pull it out as well as I hope to get some pics of the bevel primed it looks pretty good mabe this evening
                          Here are some pics of the first primer still have some more sanding and all to do but it came out better than i thought
                            Here is a better picture if the last 2 I hope to get some of you fab gurus thoughts on it thus far
                            Here is a pic of the second sanding and and filling I figure I have about 2 more thoughups to go to get it where I want it
                              well here is the last coat of black primer all applied
                              here is the full view after I applied regular grey primer
                              Here is a close up of the screen molding
                              since everything here is closed today I will go tomorrow and have the paint mixed to match my interior
