2004 Toyota MR2 TTR Spyder
  • 2004 Toyota MR2 TTR Spyder
    Here's some pics of the car:
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Some pics of fixing a broken liliput that has been sitting in my room for a while, making an mdf case for the carputer and showing how the m4 atx sits in my case (attached to a hinged lid). Now if only if the M4 ATX would actually work.....
    Fox Mulder
    2004 Toyota MR2
      You can see the LCD Shroud in the first 2 pics, the other pics you can see my dodgy hacksaw skills in cutting out holes for the fans and the painted case.
      Fox Mulder
      2004 Toyota MR2
        Trial Run of Destinator 7:
        I'm dissecting a broken bluetooth speakerphone system I got for free from work. I've added in a 1 watt audio amp to boost the signal to send back to the carputer's line in input, and an RC circuit to make it automatically turn on.
        Here's it all being fit into the same original case
        Finished Product (minus 5v power cord)
        I'm placing my GPS reciever in the screen housing as well. Here you can see the auto on modification to the lilliput, the addition of a fan and the extension of the existing IR sensor.
        I extended the wires to that USB socket on the left as the housing doesn't fit if I plug the usb connector for video in there.
        This is how the circuit boards are stacked on top of each other, using some pcb spacers I had lying around.
        Installation of the Screen:
        All the tools lol
        This is behind the dashboard where all the cables come out from the screen housing
        Finished installation pics:
        Some pics from outside the car
        Time to lay some cables, taking apart the interior of the car:
        This stuff (looks like the power antenna relay) will be underneath my carputer.
        The yaw sensor and transmission computer, not much room to spare down there!
        Running Power and Ground wires
        Taking apart the middle console to run vga,usb and sound wires up to the front dash.
        Some Pics of the computer in operation:
        Fox Mulder
        2004 Toyota MR2
          nice but im a bit confused do you have 2 motors in your car i have never seen a car like that before and thought at first that the engine was in the trunk and now i'm not sure....
          LSX Void 3.3 Gauges Mod
            It's an MR2. The motors are in the rear on MR2s.
            I've got one as well.
            Hey fox, thanks for the nav pod dimensions. I did get them.
              thanks that sums up a bit of confusion..
                Actually it looks like its a mid engine car.... so all the liquid containers are in the front? Looks like all the relays are too. What is the large hatch in the front, the battery? Wow the MR2 is a funky car.... I mean its similar to a Porsche, but Porsche has a trunk in the front. Doesnt look like the MR2 has one at all.
                1X Ainol Novo Flame Tab
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1X 7 inch motorized Screen
                1x Win 7 PC
                  The hatch you see is kind of a trunk.
                  The spare tire is in there. There's room for a backpack too, but not much else.
                  From the factory they have two storage bins behind the seats. You could fit 1.5 duffle bags in the bins, but where the hell do you find .5 of a duffle bag?
                  I got rid of my bins and stuck two 12" Alpines in a fiberglass box there.
                  I can deal without the storage space.
                    now i understand...
                      Yep mid engined car - liquids are store dup the front. Glad to hear you got the navpod dimenions 02mr2, wasn't sure with all your posts going away at spyderchat.
                      Not much room in terms of bootspace, as said before the hatch in the front is only good for a backpack unless you remove the spare tire. The hatches behind the seats are probably the only place you can really put anyhing in this car hehehe.
                      Fox Mulder
                      2004 Toyota MR2
                        strange ... the car on the pictures is gray, yet the subs are installed in a red one. Which one is yours?
                        btw any pics of the navi-pod installed in the car ?
                        '03 BMW 320d (E46)
                        Carputer progress : [#----------]
                        Gathering information ... currently using my phone connected through BT as carputer
                        '99 BMW Z3 coupe 2.8
                        Carputer progress : [-----------]
                        No work done yet
                          The Apline subs are in my car. Mine is red.
                            very nice choice in project car
                            [-------------] Hardware Status
                            [-------------] Software Status
                            [-------------] Fabrication Status
                              Havent got the navpod installed yet, yep mine is the gray car.
                              Fox Mulder
                              2004 Toyota MR2
