2003 VY SS Holden Commodore Carputer
  • 2003 VY SS Holden Commodore Carputer
    I finally got my car a month ago and I wanted to get a stereo installed. My cousin gave me the idea of a carputer and I though na, silly idea, that will never work. I was curious about that whole idea so I started researching. Then I came across this site and was enlightened. Now I'm so obsessed with the idea that it is the only thing I think about atm. I've been doing a bit of planning and now I would like to get some feedback and hear what you guys think about my plans.
    Here is some pictures of my car. Sorry if they don't turn out correctly, I'm not sure if i did it properly.
    If got sort of a list happening about what I need to buy and how much it will cost.
    7" touchscreen $325 http://cgi.ebay.com.au/Lilliput-7-EB...3286.m63.l1177
    Motherboard and processor $150 http://www.gamedude.com.au/prod_show...=mbINd945gclf2
    Power supply $50 (I think i still might need a startup/shutdown controller) http://cgi.ebay.com.au/120W-Pico-ATX...|39:1|240:1318
    Case $80 http://www.gamedude.com.au/prod_show...S1007_8_silver
    120GB Harddrive $60 http://www.gamedude.com.au/prod_show...ddSA120nb_sata
    USB CD/DVD drive $80 http://www.umart.com.au/pro/products...2=20&sid=34713
    GPS BU-353 $75 http://cgi.ebay.com.au/GlobalSat-BU-...|39:1|240:1318
    Anything I missed? Let me know what you think. Thanks!
    My Worklog http://www.mp3car.com/vbulletin/work...-carputer.html
    Planning 100% Ready to start buying! As soon as the flood waters recede XD
    Purchasing 0%
    Building 0%
    Mounting 0%
    Welcome aboard. Looks like you did the pictures just fine.
    You might look around at comments on that power supply -- it may be a little light. It looks like the equivalent of the M3-ATX, which I believe has been troublesome in some applications.
    With the case you're buying, you end up paying for a 300W power supply you can't use except for testing in the house. If you don't mind a little shop work, you could probably modify a "project box" from the Oz equivalent of Mouser, and get a tighter fit. Refer to the first few post in my worklog for a similar idea.
    You might spend less overall if you disassemble a 7-inch netbook PC (you can find them with 120GB drive and XP installed), add a touchscreen, and build it into the double-DIN area of your dash.
    One consideration, though, is that most netbooks come with only two or three USB ports, where the motherboard you've chosen has eight onboard USB ports. That means you may might not need a powered USB hub for your peripherals, so that's an advantage.
    You're off to a great start, Nosajs. You did your background research before asking questions, and you added pictures and links. That's what we like. Document everything -- we'll be watching.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
      Thanks for the kind words rdholtz, you gave me some good ideas too.
      I wasn't too fond of that power supply anyway because it didn't have a startup/shutdown controller built in. I found a M2-ATX PSU like the one in you netbook on ebay for $75. Is 160watts enough power for this setup or how much do you think I'll need? Also I would like a way to run the Carputer without the car, like when I'm installing new programs and testing ect. Now would I be able to run it from the normal house power?
      http://cgi.ebay.com.au/M2-ATX-Car-Co...|39:1|240:1318
      I love the idea of building my own computer box and I found some project boxes i could modify here. http://search.dse.com.au/electronics/Project%20Box
      I had a look at your worklog and I like the computer you've shown on post 363. I looks like its even cheaper than any netbook and move powerful for its price. If I can find one here I might get that instead, or I might find one on ebay or something.
      Omg I forgot memory... Shame for me lol. 2GB DDR-II RAM $40 http://www.umart.com.au/pro/products...id=5&sid=29416
      And here is something I found to mount the touchscreen in. $33 http://cgi.ebay.com.au/HOLDEN-VY-VZ-...|39:1|240:1318
      Purchasing 0%
      Building 0%
      Mounting 0%
        I have come up with a very dodgy diagram that shows how I plan to set up my system.
        I have the PC in the boot and a 7" touchscreen mounted in the double din space in the dash where the stock stereo is atm. I still want to be able to put in DVDs/CDs so I thought that the drive could go in the centre console along with some extra USB ports between the two front seats.
        Purchasing 0%
        Building 0%
        Mounting 0%
          It appears that the M2-ATX should be plenty. You're only pulling 8W max with the Atom 330 Intel board. But it's best to do a complete assessment; add up the power consumption of everything you'll power through that PSU, and make sure you have lots of margin.
          Well, we bought two; they're good little units. But there's no touchscreen built in, so they're not really cheaper than a netbook. And there's one downside to the netbooks: once you crack the case apart, the warranty is gone. When you buy discreet components, your warranties stay in effect.
          Nonetheless, buying a netbook gives you a touchscreen with 1024 x 600 resolution, where the Lilliputs and the like are still only 800 x 600.
          If you have a double-DIN space, take a look at Blk02si's cases. His original thread is here, and his new thread about the revised model is here. If you add the Intel board, the M2-ATX, and the hard drive in that case, you'll still have room to spare. Put the DVD unit and remote USB slots down below, and you have it all in your dash. Those cases have quality, flexibility and decent price; I like them so well that my next installation will probably use one.
            Wow I never thought of that, it's a fantastic idea! Will save heaps of wiring through my car. I think I'll be able to make something like that fairly easily. Will I need ventilation holes and/or a fan to keep it cool or will its low energy usage combined will the properties of aluminum be enough even after hours of usage?
            I think I might be ready to start finalizing my plans and start ordering parts soon. Its just been a bit hard lately because we have major flooding atm. All the streets are under and there is half a metre of water under my house. I've been having lots of fun taking the tinnie around town though lol.
            Purchasing 0%
            Building 0%
            Mounting 0%
              There's no back on the unit, so it's pretty open. I think I'd still like to add a small, quiet fan, although it may be unnecessary. I'd bet Blk02si would be happy to advise about his and his customers' experiences. I've never met him, but you can tell by his threads that he's very willing to answer questions.
              Now a question for you: is a tinnie a metal boat?
              I like your attitude -- other people are seeing half a metre of tough times, and you're seeing an opportunity for fun.
                Yeah I think I would like a fan as well, just for insurance. I'll talk to Blk02si though and see what he thinks.
                Yep a tinnie is a small metal boat perfect for going up creeks and in this case streets. Our tinnie is 13ft long with a 40hp outboard motor on the back. Haha thanks, we have just had to bring everything upstairs and relocate all our cars to higher ground so its not too bad. The waters gone up to 75cms atm, we still have electricity and water though so it isn't too bad.
                Hopefully the water will go away soon so i can start ordering parts!
                Purchasing 0%
                Building 0%
                Mounting 0%
                  Hmmmm . . . 40 hp on a 13-foot boat. That ought to be plenty of power, even if the bottom is flat and the bow is square.
                    Haha yeah it goes good XD. Most people have 25 on a boat that size, but why settle if you can go faster?
                    Purchasing 0%
                    Building 0%
                    Mounting 0%
                      I have found a touch screen that seems perfect, I think it might be too good to be true, it just seems too cheap. But its from jaycar and I think its a fairly reputable store. AUD$200 aka USD$130 Here
                      Ok time to total everything up:
                      7" Touchscreen $200
                      Hard drive $60
                      M2-ATX $100
                      DVD Drive $ 80
                      2GB RAM $ 45
                      GPS BU-353 $75
                      Total $710 or USD$460
                      Wow I must be on of the few people where is turns out to cost less than you thought it would. I will most likely buy more parts in the future like OBD-II and I'll probably need to buy wires and stuff to mount in it etc....
                      Purchasing 0%
                      Building 0%
                      Mounting 0%
                        Be cautious here -- it's a repaired item with a 90-day warranty that cannot be returned, only repaired. I see no brand information. And I see no information about resolution; it appears to be VGA -- 640 x 480 -- rather than 800 x 600. Lilliputs, Xenarcs and Sharks are 800 x 600 native resolution, capable of 1024 x 768 if you can stand a bit of softness in the image.
                        To see the difference resolution makes, get the smallest CRT monitor you can find that's capable of 1024 x 768. Run whatever front end you plan to use at 1024 x 768, 800 x 600, and 640 x 480. It's surprising how much difference it makes.
                        Another factor is brightness. Some monitors are just plain dim.
                        If you can get to a Jaycar store, see if you can look at one of these before you buy it, or at least ask what brand they are and then look for comments.
                        Maybe that monitor is good. But you might also take a look at this Shark sold by Goodeals18 for USD$168. I know that's more money, and I'm not saying I outright recommend it, simply because I haven't done any feedback research. But it's new, max resolution of 1024 x 768 (native -- crispest -- resolution is probably 800 x 600), and some MP3Car members have bought them. You could MP3Car for feedback on Shark and Gooddeals18 (you can also find Gooddeals18 on eBay, but the prices seem a little higher, probably to account for the eBay fees).
                        The company is in the USA, and I haven't checked on shipping cost to Oz. If your research shows Shark to be okay, maybe you can find Shark monitors there.
                          Thanks for that, maybe it would have been a good idea for me to read the bold read text... Experience has taught me that situations like that don't often work out. Well looks like its back to the drawing board. I'll just keep searching, something will pop up eventually.
                          Purchasing 0%
                          Building 0%
                          Mounting 0%
                            Hey Nosajs, I'm in Australia as well. I'd second rdholtz's motion: if you want to be sure, go to Jaycar and check out the unit. Not only is it a repaired item, it also has a CCFL backlight, which means it won't be very readable in sunlight (I inquired about this a few weeks ago at my local Jaycar, and subsequently ordered a Lilliput 629 GL from eBay). The good thing is your radio isn't very high up on the dash (unlike my 07 Camry), so sunlight probably won't affect it as much. Just something to consider though.
                            The Lilliput 629 with LED backlight seems to be a good option for those on a budget wanting a sunlight-readable LCD. I'll let you know how mine is when it arrives ... one of these days now ...
                            Sorry to hear about the floods ... it's been on the news. Hopefully it'll subside ASAP
                            2007 Camry Altise In-dash Car PC
                              Thanks MeeM, Ive decided against that screen though I knew it was too good to be true. I had a look on ebay for a 629 and I could only find one. Its $776 or $1009 buy it now, thats well out of my price range lol, or did you manage to find a cheaper one?
                              I have found two more that might be good: 1 and 2
                              1 is bigger and cheaper (when including postage) but has no brand name. 2 is a lilliput and I won't have to modify my dash as much to get it in.
                              Purchasing 0%
                              Building 0%
                              Mounting 0%
