Ford Ranger Truck rebuild UK based & sound system install
  • Ford Ranger Truck rebuild UK based & sound system install
    Welcome to my truck rebuild and computer install
    For those that know me on the RideRunner forum , you will notice that my skin is of the same name , it was the truck that prompted me to build this skin.
    Lucky for me I am a panel beater and sprayer , so all the work so far has been done by myself , no external help, also lucky is that i have a sound off stereo shop in my town , who was a 3 times class3 UK winner, so I have had alot off advice to the equipment I'm useing for the system.
    The truck is a 2000 Ford Ranger UK spec, was a total right off when I brought Her, the front end was totally smashed in , so far i have now finished the exterior of the truck images below , this week as i'm off for holiday will be the computer and sound system install. I will be posting images and updating through out this week .
    Body repairs
    New front panel , Wings , Bonnet , complete front bumper , Tailgate , dents and scratches repaired down the sides,
    Added chrome (bling)
    Bull Bar , rear bumper , side steps , 2 x bars on sports lid
    Images
    Before
    New front panel
    After
    Alarm system
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Reserved for sound system install progress , Updated all this week
    To do before install of sound system
    Cut back of cab behind rear seat and extend to fit sub box,
    Plan monitor install
    remove roof lining for easy access to run the wires,
    Make new plinths (collars) for front components.
    Embed tweaters into door mirror rear covers.
    plan placement of 2nd battery in engine bay.
    fit split charge isolator.
    well as promised heres a small update of the system install.
    What i'm trying to do is use the interiour as is , without having to make up or cut the dash in anyway , 1 reason i don't think i can give the finish i would like no matter how long i take, 2 if i have to be in a position to sell or remove the system from the truck for any reason, i have not screwed up any of the equipments houseing .
    todays work includes
    Fitted New Headunit Fujtsu Ten , which has 3 RCA outputs and 1 RCA AUX input. and all can be controlled separately . also from image below you can see the lilliput Backlit screen mounted (not totally sure that this will be its final home)
    RCA output cables these are all connected to the headunit awaiting for channeling under the carpet to the amp.
    Embeded the tweaters into the rear door mirror covers and wired up the crossovers
    finished the new collars for the mid-bass cones, and mounted
    Offering Amp to the back of the cab to get and idea of room space, also started the box for the Sub, which will go through the back of the cab , extendong it by 3" which will allow the rear of the seat to fit back on its origanal mounts.
    HD tuner being offered to its mounting point behind the clove box, and now wired up.
    Start of the pc install
    finally had time off to get this started
    Superbeam mic
    PC Argito A100 , 1TB Ext HD, Carnetix P2140 PSU
    Amp finally mounted with power cap all wired in and running
    Sub Extention now in place awaiting the sub to be fitted
    Hardware Links
    PSU
    PC
      Ok finally manage to find time to get back on this , updated images in 2nd post
        Well PC system now mounted and installed , i mounted the whole system on a board 15" x 9" , so you get the idea how small everything is , in the image left to right
        1TB ext HDD , Artigo PC , above , 13 port USB hub, Carntix P2140 PSU, and Fuse block for the system inputs
        while i was in the buying mood i also brought 1 of these from the Mp3car store , very nice bit of kit
          bit more work done , I love Xmas ,, still at work but no work to do , so its Truck time lol....
          everything is now wired up sound wise , still alot to add to PC side of things , but at last progress made , just shame i left the sub at home ,,, now to make a cover to inclose all the nasty looking areas...
