Project Double Vision - 2003 Honda CR-V Carpc
  • Project Double Vision - 2003 Honda CR-V Carpc
    After lusting those CAR PC installs - I told myself I MUST have one in my 2003 Honda CR-V!
    So, here goes my first carputer installation.
    Please be gentle as I may not have the skills on what other's have achieve on their project.
    Removing the lower cubby hole
    MDF frame to house the touchscreen
    HondaSUV.com
    Dremeling and light sanding
    The Lilliput 7 inch toucsreen
    Test fitting - looking good in my opinion and getting excited
    HondaSUV.com
      Test fitting MDF frame to the cubby hole
      touchscreen mounted on dash
      another shot
      HondaSUV.com
        Spray painted the mdf frame
        another shot
        Sorry for the poor quality of this photo --- over-exposure!
        HondaSUV.com
          I'm now sourcing a suitable fascia to cover the MDF and the gap between the aircon controls
          Or I could try fabricating from an aluminium sheet.....whatever easier to work on.
          HondaSUV.com
            hehe I like it ,but I may be partial to the SUV you are installing it into.
            My new install
            D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
            Visteon HD radio w/mitches cable, BU-353
            2 Punch 150 amps, 1 Kicker ZX 400.1 watt
            4 Boston Acoustic Speakers,2 Pioneer 10 subs
              Cool!
              Not many around here!
              HondaSUV.com
                I tried to cover the MDF frame the second time with PVC vinyl
                a bit better looking now than just spray painting it - still not perfect though.
                I've got to move -on and start with the carpc and other stuff.
                First I need to remove the center cup holder/table - you have to remove the seat to gain access on the bolts
                I forgot to take photos of the seat removal - should be straightforward and nothing to it
                Just make sure you disconnect the battery first before disconnecting the airbag sensor under the seat and wait a few minutes.
                Once the cup holder/table removed - lift the carpet and locate the holes on the subframe - see photos
                I've inserted a 10mm bolts to check diameter
                The Center cupholder taken-out from the CR-V
                HondaSUV.com
                  Next up, I cut a piece of MDF in-between the front seats
                  This will house the pc and will gain storage and additional cup/drink holder
                  HondaSUV.com
                    The Carputer by ZOTAC
                    ZOTAC IONITX-D-E Intel Atom Dual Core M350 Car PC System
                    This barebone Car PC kit includes the Zotac IONITX-D-E Fanless Mini-ITX motherboard (With NVIDIA ION chipset and Intel Atom N330 1.6GHz dual-core CPU), 2GB of DDR2 memory and a M3-ATX automotive power suppy all enclosed within the M350 Universal Mini-ITX enclosure.
                    This kit comes fully assembled and tested.
                    The kit includes:
                    1 x Zotac IONITX-D-E Fanless Mini-ITX Motherboard (60mm CPU fan included and installed)
                    1 x 2GB 800MHz DDR2 Memory
                    1 x M350 Universal Mini-ITX Enclosure with wall-mount brackets included
                    1 x M3-ATX 125W DC-DC ATX Mini Automotive Power Supply
                    1 x All product manuals and documentation and driver CDROM
                    Zotac IONITX-D-E Mini-ITX Motherboard
                    Experience fluid and vivid high-definition video playback with the ultra-compact ZOTAC ION platform. The Mini-ITX form factor ZOTAC ION combines a high-performance NVIDIA ION graphics processor with a power-efficient Intel Atom processor for the ultimate eco-friendly platform that has no troubles handling regular web browsing, e-mail, productivity and HD video playback tasks.
                    NVIDIA PureVideo HD technology harnesses the power of the ION's 16 high-speed stream processors for high-definition Blu-ray playback capabilities. PureVideo HD technology decodes HD video formats and enhances standard-definition videos with the ION GPU for flawless HD and superior SD video playback. HDMI, DVI-D and VGA output for a host of different display options.
                    This motherboard includes an internal 802.11n (up to 144Mbps) MiniPCI-E WiFi Adapter (installed) with external antenna.
                    Lastly, with longer-than-standard warranty periods, (Lifetime for USA, Mexico, Canada, Latin America), enjoy peace of mind in the longevity of your system.
                    The M350 Universal Mini-ITX enclosure features one of the smallest footprints to date taking Mini-ITX kit miniaturization to a whole new level. Please note that with the 60mm fan installed on the Zotac motherboard, only 1 x 2.5" storage drive can be installed inside this enclosure. Wall-mount brackets are included with this kit for easy car cabin or trunk installation.
                    The M350 enclosure also features a unique hideaway compartment which houses a special power switch and 2 x USB inputs in a unique layout. The power switch has two functions not found on other enclosures: (1) Switch disable with jumper (to prevent accidental or unwanted power-offs) and (2) Auto power-on after power failure (for ALWAYS ON status) with jumper. The layout of the USB inputs allows you to "hide" 2 USB devices (such as Wi-Fi adapters or Flash drives for booting) behind the front panel.
                    You can find more in-depth information on the revolutionary M350 Universal Mini-ITX enclosure here: http://mitxpc.com/proddetail.asp?prod=M350CASE
                    Car PC Connections
                    Video Output
                    Use the VGA output for an analog connection (use a VGA to composite adpater for your composite video display device [RCA]) or you can alternatively use the HDMI or DVI outputs for digital image output.
                    Audio Output
                    If you have an audio receiver with AUX-IN you may use the rear 3.5mm audio jack and a standard stereo audio cable and make the connection for audio in that matter (just like plugging in an iPOD or other MP3 Player). Also, if you are using a subwoofer and external amps and would like to protect your speakers from the "thump" which comes when the Car PC is turned on from an off position, you can utilize the anti-thump function on the M3-ATX power supply to protect your audio equipment.
                    Network Connectivity
                    With the built-in Wi-Fi adapter, you can easily connect to a wireless network without any need for additional adapters. The built-in Wi-Fi adapter supports 802.11b/g/n technologies (up to 144Mbps).
                    Motherboard Specifications: Manufacturer P/N: IONITX-D-E
                    Processor: Integrated Intel Atom N330 Dual-core @ 1.60GHz
                    533MHz FSB
                    Chipset: NVIDIA ION
                    (MCP7A-ION)
                    L2 Cache: 512KB
                    Memory: 2 x DDR2 667/800MHz Memory DIMM Slots
                    4GB Max Capacity
                    Graphics Interface: NVIDIA GeForce 9400M processor
                    Graphics engine clock: 450MHz
                    Shader clock: 1100MHz
                    16 Stream Processors
                    Microsoft DirectX 10
                    OpenGL 2.1
                    NVIDIA PureVideo HD Support
                    NVIDIA CUDA ready
                    NVIDIA PhysX ready
                    Serial ATA: 3 x SATA 3.0Gbps Ports
                    1 x eSATA 3.0Gbps Port
                    SATA RAID 0, 1, 0+1
                    Expansion Slot: 1 x Mini PCI-E (occupied by WiFi adapter)
                    Back Panel I/O: 1 x PS/2
                    1 x HDMI (w/ 7.1 Audio)
                    2 x Digital S/PDIF outputs (1 optical, 1 coaxial)
                    1 x VGA Connector
                    1 x DVI Connector
                    1 x RJ45 10/100/1000 Mbits/sec (Gigabit LAN)
                    4 x USB 2.0 Ports
                    Audio: Line-in, Line-out, Microphone
                    Onboard I/O Pin-headers: 4 x USB 2.0
                    1 x Audio I/O
                    1 x COM
                    1 x Fan Header
                    Form Factor: Mini ITX 170mm x 170mm
                    Motherboard Warranty: 5-Year Warranty (Europe, Middle East, APAC)
                    Extended Warranty (India)
                    Lifetime Warranty (USA, Mexico, Canada, Latin America)
                    *Requires immediate registration @ www.zotac.com
                    M350 Universal Mini-ITX Enclosure:
                    Model No: M350
                    Case Dimensions: Size: 192 x 210 x 62mm
                    Volume: 2.5L
                    HDD Bay: 1 x 2.5" HDD
                    1 x HDD Bracket included
                    Front Panel: 2 x USB 2.0 (Hidden)
                    2GB DDR2 800MHz SODIMM Memory:
                    - 2GB Capacity
                    - DDR2-800MHz
                    - 200-Pin SODIMM DDR2
                    M3-ATX Features:
                    - Plug-In Smart Automotive DC-DC PSU
                    - 125 Watts (150watt peak)
                    - 20pin ATX, 6-24V wide input range
                    - Programmable timing settings
                    - Intelligent shutdown controller
                    - ON/OFF motherboard control
                    - Survives vehicle engine cranks
                    - Battery deep discharge prevention
                    - "Anti-Thump" Amplifier remote control
                    - < 0.5mA standby current
                    Not high-end but good-enough for my needs!
                    Everthing's on-board - meaning less cablings
                    HondaSUV.com
                      A few shots of the CARPC in the flesh!
                      HondaSUV.com
                        Had some spare time today and conitnued with the installation
                        Painted the MDF and installed the brackets to hold the carputer
                        I didn't put extra effort on painting the board since it will be hidden and wil be mostly covered
                        with bits and pieces and cablings
                        Here's a photo of the Gravity Screw to hold the mdf board on the subframe
                        HondaSUV.com
                          VGA and USB to connect to the touchscreen and screwed on the subframe- a bit of camera shake!
                          test mounting the carpc
                          HondaSUV.com
                            I still need to run the Line-out for audio and the remote trigger to control the pc from the Kenwood head-unit.
                            and Microphone for Voice command recognition.
                            HondaSUV.com
                              I can't wait to see where you are going with the center console. Did you see mine ? Here I am jealous of the 2 screens, but I think I am going to put one in back for my kid.
                              My new install
