bramlet attempts to build cavalier carputer
  • bramlet attempts to build cavalier carputer
    I have just about finished buying what I need I have spent nearly $650 and another $100 on some new tools I probably needed anyway.
    Here is what I have bought:
    Opus 180 watt DC-DC - $50 used on ebay
    foxconn 45csx atom 330 mobo and 2 gig ddr800 ram- $112 newegg
    infinity ref 4 channel amp 75 watt rms per ch - $56 ebay
    shark brand 7 in vga touch screen - $130 on ebay
    bu-353 usb gps module - $40 on amazon
    griffin powermate $33 on ebay
    wd scorpio black 320 gig $70 on axiontech webstore
    wifi usb stick $9 on newegg
    4 gauge amp wiring kit
    vga cable and gender changer
    usb extension cables
    lengths of 8 gauge cable
    a couple distribution blocks <-allthis=$145 lots of leftovers tho
    a few types of fuse holders
    standoffs and screws
    rca splitters a few different types
    sata cables
    I have cut a piece of plywood to match the back of the backseats
    half of this has a plexiglass plate cut out
    the amp will mount on the other half
    I need to drill the standoffs into the plexiglass and attach the plexiglass to the plywood next.
    GL on the build! got some pics?
    98 Chevy Astro AWD
    1969 Cadillac Deville
    2009 HHR LS.... DEAD PROJECT!!
    '97 Seville STS - SOLD ~_~
      Sad news, the shark brand 7 inch touchscreen from gooddeals18.com does not work at all. It doesn't even power on. It sparked when I plugged in the dc wall adapter for the first time, and just never powered on. I guess I will try to power it though the 12volt batt line next, but I will try to exchange it. Guess I will see how good gooddeals18.com customer service is.
        the shark does not work with regulated 12 volt either. Its going back. I have 30 day money back so might try another unit or get a different brand.
          I got my refund from gooddeals18, and completed the next step in the build process. I'll let the picture speak for themselves here. sorry first time with photos not sure this even worked
            i tried attaching it this time
              ok good that worked...I got everything in the picture except the ten foot VGA cable and gender changer. Thats a 320 gig WD scorpio black in the bag and cheap wifi stick in the middle. all I need is the screen, I'm leaning towards the double din lilliput. thats 1/4 in plexiglass but I'm not sure I can take it off if I wanted to. that was my plan but i made the holes to small. thats the 4 ga amp installation kit in the big bag on the right and I've got 4 male to female usb cables and the 3.5 mm to 4 rca adapter path. the griffin powermate and bu-353 gps are on the upper right.
                the mobo and powersupply standoffs are installed in that picture nothing else is attached yet.
                  how should I mount my hdd?
                    where is that thing going to be mounted? i would definately use rubber grommets between the hdd and the wood... or even possibly getting an actual case to protect the components
                    98 Chevy Astro AWD
                      the carputer is installed. I am running windows 7. I have got a 701 lilliput in a double din frame for a screen. I got it used with the extension cable for 200 bucks. My hdd is inserted into a "jam jacket" for a 3rd gen ipod and screwed into the plexiglass with a screen door handle. works great. I also glued some rubber between the plexiglass and the jam jacket rubber for double rubber goodness. although the bottom rubber is very stiff.
                          Creative use of the screen door handle! Great idea!
                            I thought thats what that was!!!!!!!!!!!! Im not a fan of the handle, but i do like the idea of you wrapping the HDD in a iPhone case to cushion the HDD.
                            1X Ainol Novo Flame Tab
                            4X MK808b
                            3x Perixx Touchpads
                            3x 7 inch Screens
                            1X 7 inch motorized Screen
                            1x Win 7 PC
                              How has it been working out for ya?
