2003 Honda Civic Hybrid Install Worklog
  • 2003 Honda Civic Hybrid Install Worklog
    I think now is the time to start this as I have most all of the information I need to get started with this install.
    Let me get started by defining the system I am installing.
    Main System:
    Case: M350 from www.mini-box.com
    CarNetic CNX-P2140 DC to DC Startup / Shutdown Controller
    PicoPSU-150-xt 12V DC-DC ATX power supply
    Zotac GF9300-F-E
    Intel Core 2 Quad 3.0Ghz
    4Gb DDR3
    120Gb OCZ Agility SSD
    Black Double DIN Mounting Kit
    Momentary switch for ACPI line to laptop (manual shutdown and start up)
    Kill switch for main power input
    USB Peripherals include:
    Lilliput EBY701-NP/C/T Transflective Optically Bonded Daylight Readable
    BU-353 GPS Device - Complete
    BoomzBox HD Radio controlled AM/FM Tuner
    Belkin 7 port USB hub powered by 5.0v 3A remote mounted PSU
    Software:
    Windows 7 Profession x86
    Rohos Login Key for automatic login - Used with 32Gb USB Key
    Gamin Mobil PC
    iTunes (for iphone4 network drivers)
    OpenMobile 0.7
    Audio Equipment:
    120A Line Filter - Complete
    Rockford Fosgate V4004 1200w 4 channel amp - Complete
    Alpine Speakers Front X 2 - Existing
    Alpine Speakers Rear X 2 - Existing
    Equipment to be removed and FOR SALE!:
    Dell M1710 laptop w/BluRay drive
    2003 HCH Work Log
    - Official OpenMobile Builder/Tester
    Here are some initial Pictures of the car and what is installed:
    Main Dashboard
    Lower Dashboard
    The momentary button to the left was used to turn on the inverter and the toggle switch on the right was used to bypass the ignition power to the head unit.
    Backseat - Outlets
    Trunk - Amplifier
    Trunk Right Side - Battery (Secondary)
    The fuse to the right is for the inverter, so the input lines to the inverter do not get too hot.
    Trunk Left Side - Inverter
    Engine Bay - Main Battery
    The two red fused leads that are attached to the battery positive terminal are for my HID circuits. The third red line is for my air horn circuit.
    Left Fender - Main Fuse
    As you can see the car is in need of some attention.
    This work log will detail how I resolve the install issues I have and hopefully finish up with a clean install that looks close to factory.
    2003 HCH Work Log
      This is the design layout I had in mind for the trunk
      This is the mounting board for all the equipment in the trunk
      Now that most of the planning is done, it is time to start fabricating!
      EDIT: forgot about the docking station!
      2003 HCH Work Log
        It looks as thought I will have a bit of a setback as I have a few problems that need to be ironed out before I start my carputer install.
        Going to make a list here so when they are complete I can then get started.
        Current list of repairs needed:
        Replace front lower motor mount (Repaired 3-22-2010)
        Replace drivers side power window switch (Repaired 3-22-2010)
        ......blows passenger window fuse
        Replace HID ballasts (Replaced 3-27-2010)
        ......mauled left high beam ballast
        ......defective right high beam ballast
        ......defective right low beam ballast
        Replace 12,000k HID lamps with 4300k brighter lamps(Replaced 4-02-2010)
        Replacement Ballast:
        http://www.hidcountry.com/product2.php?pid=19
        2003 HCH Work Log
          Now that I received my CarNetix CNX-2140, I am ready to do some power supply testing.
          First I double check the laptop brick output at 19.5v with 130W.
          Using a spare power plug, I sliced the wire to find there are 3 conductors in the cable, Ground, V+ and ID wire, from left to right respectively
          Checking the main power input voltage:
          Finding out what the ID wire voltage is:
          When the computer gets 19.5v on the main V+, it returns 3.3v back to the AC brick via the ID wire.
          Error screen when ID wire is not connected to the AC brick:
          The circuit that is contained in the power supply will have to be fitted to the laptop when it is installed in the car so I don't get the annoying verification messages when the computer boots up.
          So now I have to find a way to integrate the brick ID circuit.
          I apologize for the poor photo quality, as it is only a iPhone camera.
          2003 HCH Work Log
            So it was pretty easy to put together a power circuit that would feed the correct voltage to the laptop and provide a power check circuit to the laptop telling it that it had the right power supply connected.
            I first connected the primary red output of the CNX-P2140 to the laptop plug V+, then old brick ID to the laptop plug ID, and finally connected the laptop plug ground, brick ground and CNX-P2140 grounds together.
            From top to bottom in this picture (ID, V+, and Ground)
            Here is a picture of the brick and all
            The test was a success, the laptop boots all the way into windows even without the battery installed and does not error. The next step will be to remove the existing components in the car and mount the laptop with docking station and amp to the base board.
            EDIT: The AC Brick will NOT be connected to an AC source in any way when it is installed in the car
            2003 HCH Work Log
              Question for ya about the wiring.
              So you're using the 2140 as the primary power, and the to take care of the ID wire you're just connecting the centerpin(ID) to the adapter ID and then grounding it like so?
              ACPlug + -------- 2140 19.5
              ACPlug GND ------ 2140 GND
              ACPlug ID ------- Adapter ID
              Adapter GND ----- 2140 GND
              Are you powering the adapter in any way?
              03 Hyundai Elantra GT {Worklog}
              HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
              RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
              cmdRR tall skin creator
              86 Pontiac Fiero SE 2m6
              possible carpc install
                I do not power the AC Brick with any AC power at all, as I am removing the inverter from my car. I am strictly using the Carnetix CNX-P2140 DC to DC regulator. Also I would like to note that I do not connect the CNX-P2140 primary output red line to the AC Brick at all, I only use the ID and ground wire from the AC Brick.
                2003 HCH Work Log
                  Awesome.. that's just how I was thinking, and trying to type. I'll have to give this a try with my HP, cause if that works that's an awesome find for anyone using a barrell plug unit
                    The best way to check to see if this will work for you is to check the voltage on the ID line with reference to ground when the AC brick is plugged into an AC source.
                    The next step would be to find where this voltage source is coming from, if it is coming from the laptop then your OK but if it is coming from the AC brick then this technique will not work, and you will have to find an external source that supplies this voltage from an external source.
                    2003 HCH Work Log
                      Cleaning out the trunk and installing a wood bracket support so I can mount hinges above the spare tire.
                      Location of the 150A power line filter
                      Installing the base board
                      Picture of the baseboard installed
                      I still want to organize the wiring and routing so it is all cleaned up even under the base board. I will need to get some adel clamps for this, but that is for another time
                      2003 HCH Work Log
                        Nice work.
                        I ve a Civic but with only one battery :-(
                        Rafa
                        Project Civic - Brazilian
                          nice to see a budding project... and that's one huge trunk!!
                          Thanks to you I've changed my power setup to something a little more stable.
                          I figured out how to get the adapterID to work along with the carnetix... similar to you, but different.
                          I don't mean to hijack or anything, but in case someone searches and gets here. I'm also going to update my worklog too.
                          I was using 2 adapters for my testing, one for the power and the other for the ID. This weekend I'll put the setup in the car. I had to run the power back to the adapter or else I wouldn't get any ID signal.
                          Thank you!!
                          Now back to your build!
                            I got an error when I entered the actual OS (Vista 32 Ultimate).
                            The pop up error was produced by the QuickSet application written by dell, so when I upgrade to Windows 7 Pro, I will not be reinstalling that application.
                            I finally got all of the wiring into the car and had a chance to do an in car test.
                            I am also upgrading the computer with a full install of Windows 7 Pro.
                            2003 HCH Work Log
                              After upgrading to windows 7 Pro 64 bit I now have an issue with the CNX-P2140 PSU. The Power supply turns on with ignition but the 2 second ACPI pulse is too soon after the initial power up. The laptop power light turns on and the HD spins but then the HD turns off and the power lap goes out. So I wanted to attach the PSU to the USB port and upgrade the firmware. When I installed the PSUmoni2140 v1.8.3 software, the software seemed to load ok, but if i check the drivers in the Device manager it says the driver has not been loaded.
                              So off I go to search for a 64 bit driver for the CNX-P2140...
                              I came up with this:
                              http://www.carnetix.com/forum/showthread.php?t=1963
                              In the directory "C:\Program Files (x86)\P2140 Monitor\Microchip USB Device Driver" there is the appropriate files to load for the device driver under 64 bit systems.
                              When I try to launch the original PSUmoni2140 application I get "The program has stopped
                              responding...."
                              So I can not upgrade the firmware on the CNX-P2140 or adjust the sliders in the software to change the timing sequences for the start up.
                              The only other conclusion I can come up with is downgrading my software to 32 bit and try everything all over again.
                              2003 HCH Work Log
