1999 Malibu Wakesetter VLX (boat)
  • 1999 Malibu Wakesetter VLX (boat)
    I'm about to drop my boat off for a full reupholstering and I got the itch again...
    Immediate system design goal:
    seamless control of non-vital functions
    integrated media
    --mp3, video, xm, ipod control
    ballast control
    -- 6 pumps 3 ballast bags (future plans to add one more bag and two more pumps).
    -- each ballast will be controlled independently by touching the corresponding spot on the boat icon
    -- option to fill all, empty all, and to stop all pumps via independent master controls
    non critical systems
    -- amp turn on
    -- lighting
    -- engine bay vent/blower on a timer
    -- touchscreen engine start
    future additions:
    rear view cam/dvr
    -- helps the driver keep an eye forward while monitoring the wakeboarder
    --dvr will be useful to critique runs
    integrated gps based speed control (perfect pass) to be adjust via ballast 'fill state' presets
    -- would like 3 skill level presets. one button would fill the ballast and adjust the speed accordingly
    code based engine start
    --punch in the code and crank the engine. (with hidden key override)
    System specs:
    mobo - ASRock A330ION
    hd - 60 gb solid state drive
    ram - 512mb
    os - win7
    front end - ride runner
    i/o integration hardware - (4) usb-io-1's
    i/o integration plugin - modified Sonicxtacy02 plugin (see skin design below)
    rearview cam - undecided
    soundcard -- usb dac -> jl audio rlc volume control/line driver
    Install info.
    -- install transreflective 7" xenarc in the insturment cluster. sealing the touchpanel to the newly designed abs facade to protect the xenarc lcd.
    -- aux sony RMX11M control of the pc. installed in the glove box lid or the rear seatback
    -- adding led accent/interior lights to the cabin
    that's the plan. im sure it'll grow as time goes on. but i'm going to try to keep my sights focused this time around.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    to simplify my life and assure getting my boat on the water by the end of may, i've decided to use the elite skin and modify it for my needs. here is a simple skin that i'll modify:
    the boat has a gps guided cruise control called 'perfect pass' the interface for this is a multi-line display with 4 membrane buttons to control it. Luckily for me the buttons are attached to the board using a common 5 pin header... soo usb-io-i will control this and that will allow me to flush mount the display screen from the gauge into my dash:
    That perfect pass system has a numeric tach and speedometer, this will allow me to delete the corresponding factory gauges, leaving me with 5 smaller gauges to graft into the cluster. fuel, engine temp, oil pressure, depth, and voltage.
    here is a mock up of how it'll all look when it's done.
    that's it so far. i have most everything i need now so i can start hacking away
    M10k
    My Car Pc Install
    My Boat Pc worklog
      started with the gauge cluster mod last night. first thing i had to do is make the gauge 'pods'
      first thing was to separate the abs trim from the gauge:
      I got four 3" abs couplers from the hardware store and cut them at a a 15 degree angle
      im not sure if i want to have them recessed at an angle or extruded like my mock up. here is what it looks like extruded:
      here is another mock up (you can see the new abs panel 'blank' at the top of the pic.. that is what i'll graft the lcd screen and gauge pods into)
      M10k
      My Car Pc Install
      My Boat Pc worklog
        a little more progress last night. The joycon exr arrived last night.
        after a very simple hook up I started to map the buttons of my transom remote.
        some cool features. besides being able to control the media/music. a long press of the 'source' button will turn on/off the perfect pass. a long press of the 'volume up' and 'volume down' buttons will fill and empty all ballast tanks respectively. a long press of the 'off' button will turn off all ballast pumps
        oh... and all of the commands have an audible confirmation. ("perfect pass enabled", "fill all ballast tanks", "empty all ballast tanks" etc..) im sure it'll get old but it puts a smile on my face whenever i hear it.
        M10k
        My Car Pc Install
        My Boat Pc worklog
          so my time has been split among a bunch of projects so this one is going a bit slower right now. The vride dash wouldn't fit so i had to scrap that idea and go back to my original dash piece
          the boat is ready for a complete rewire of the ballast pumps and future led wiring:
          here is the recessed monitor facade:
          The monitor will now sit about 1" back from the gauge panel
          here is the really rough mock up (not filled/sanded) of how it'll look in the dash
          i hit a wall with gauge placement though. im not sure if recessing the gauges will make it harder to read, yet i'm not really feeling having them surface mounted like they were originally on the boat.
          im also not sure if i want to have 3 small gauges on the left and then the perfect pass 3" gauge on the right or two small gauges on each side of the monitor and seeing if i can sneak the perfect pass multi line display below one of them.
          im leaning toward something like this (but not having the gauges pop out as much)
          if anyone has any design ideas (no matter how off the wall) please chime in. im at a stand still on this
          ---------- Post added at 07:28 PM ---------- Previous post was at 07:27 PM ----------
          got some more geek time in today.
          here is the usb-io-1's hooked up to some heavy duty relays.
          well mostly wired up at least. still need to run power and ground and need a distro block. the yellow and blue wires that are just hanging there are for a future pump if i ever decide to add a bow bag. I will be making a plastic cover for it to protect and hide all the wiring as well
          the big white wire looms on the left go to the ballast pumps. each set has four wires. the blue wires will be connected to a fused constant 12'v. the yellows are connected to the + leads that attach to the pump. the white wires go to the usb-io and will switch the relays, the black is ground
          here is another gauge cluster pic. this one shows the ultimate layout and some more of the filling/sanding of the screen:
          i decided to go with a recessed gauge, in the end i think it looks the cleanest
          still need a few more rounds with the sanders but it's getting closer.
          you're looking at the raw abs right now, the monitor's housing is made from a light gray abs and i've been sanding the crap out of the whole piece so that's why it has that dirty matte look and the different colors
          here are the stock gauges just placed in there. im contemplating installing them behind the holes instead of on top, but the way they are now allows them to be easily replaced:
          i still need to add the perfect pass multi line display and a depth finder display
          it's hard to photograph it and make it look good in this state, but up im pretty happy with the progress so far
          ---------- Post added at 07:29 PM ---------- Previous post was at 07:28 PM ----------
          haven't updated this in a little while but have made a lot of ground on the project.
          ok, so onto the good stuff
          Here is more work on the gauge cluster; im still not happy with it, the recessed screen is a !@#$! to sand in the corners.
          i also received this today:
          short youtube video of what it does
          and now the homebrew mtc will get a Power Wedge controller
          This was actually a the hardest part of the build so far. i dont want to, nor have the time to make my own ic board; yet, i need to flip the polarity in order to move the wedge up and down. Ii figured out how to do it with the usb-io and 4 additional 40amp fuses. the nice part about this; i can run low voltage wire (cat 6 or even telephone cord) from the usb-io under the dash, and have it control the relays placed close to the wedge and batteries.
          not sure if anyone will be able to make sense of my chicken scratch but here is the "schematic":
          i also have gotten into seriously modding the "elite lite" skin for our purposes:
          I'm trying to create the skin so that it'll be as painless as possible for you guys to quickly incorporate it into your own system too. should be only a few files and one folder to place in the correct spots.
          (ignore the stretching, the screen is an old 4:3 monitor, the touchscreen that will be installed in the boat is a 16:9 aspect ration and everything will resolve itself
          Main menu-
          ballast button: will bring you to the main ballast screen
          wedge button: will bring you to the power wedge control screen
          perfect pass button: will bring you to the perfect pass control screen
          lights button: will bring you to the light control screen
          power button: short press will toggle the perfect pass on/off, long press will start/stop the engine
          audio: brings you to the elite skin's audio screen. long press will bring you to the video screen
          wake preset: brings you to the wake preset screen
          Ballast-
          short press will toggle pump on/off
          long press on any of the 'FILL' buttons will turn off all empty pumps (if any are on) and turn on all fill pumps for 8 mins (or any predetermined amount of time)
          long press on any of the 'EMPTY' buttons will turn off all fill pumps (if any are on) and turn on all empty pumps for 8 mins (or any predetermined amount of time)
          Power Wedge-
          retract button: will raise the power wedge to it's stowed position
          up arrow: will manually raise the wedge (momentary switch, it will only move the wedge as long as you're pressing the button)
          down arrow: will manually lower the wedge (momentary switch, it will only move the wedge as long as you're pressing the button)
          "large" button: will reset the wedge to the lowest position, then raise it to the highest position of it's functional range (based on time)
          "medium" button: will reset the wedge to the lowest position, then raise it to the middle position of it's functional range (based on time)
          "small" button: will lower the wedge to it's lowest position
          Another forum member and I are brainstorming ways to have a position sensor so that we can turn this into a 'smart' system instead of a blind one. more to come on that in future posts.
          Perfect Pass-
          up arrow/down arrow will adjust speed setting or scroll through menu options (same as stock multi line display)
          stargazer logo will access the menu
          power button will toggle the power on and off (also accessable from the menu screen)
          gps speed will be displayed but derived from the computer's gps dongle, not the perfect pass
          Wake Preset-
          one touch control to set ballast, wedge and perfect pass speed automatically
          Audio screen-
          This is the skin's default audio browser.
          M10k
          My Car Pc Install
          My Boat Pc worklog
            I'm a boarder myself, and this is sik. I especially like the Wake Presets, awesome idea.
            Is it going to be finished in time for the summer season?
            I've always considered a split wedge, so the 2 sides can automatically work independently, to keep the boat level on the straights, I see you just bought a wedge, but something to consider anyway.
            Android Tablet In-Car Sliding Dock using hacked DVD drive
              thanks. didn't even think anyone was looking at this thread.
              I plan on having it up and running by the end of the month. at least v1.0. im sure i'll have to make some changes after real world interaction with it. the biggest hold up is the upholstery shop. they f-d up big time on my cushions and im having them redo everything. :\ they had to call in a specialist so im crossing my fingers that it'll get done sooner then later
              I decided to go with the power wedge because the foil was designed and tested by engineers; clearly, that isnt me.
              does your boat not stay level on the straights? the wedge is made to shape the wake and give it a little more size. i dont think it has any thing to do with aiding plaining of the boat. i believe what you're thinking of are trim tabs
              M10k
              My Car Pc Install
              My Boat Pc worklog
                i have been watching as well-- my families got a 1980-something ski boat(i think it's 16ft), and while we really only ski or tube behind it, i'm always interested in different applications for pc's..
                next project? subaru brz
                carpc undecided
                  It would mainly be for when people move around in the boat. Trim tabs are similar, but I'm guessing they'd disturb the wake, and lift the boat slightly out of the water, a submerged split wedge would do the trick.
                  I'm in Oz, so we're about to go into our winter season, with all the floods we had we only got about 3 weeks on the water all summer.
                    interesting idea
                    here are some videos of it in action:
                    interface:
                    http://www.youtube.com/watch?v=74w99EZpVxA
                    power wedge:
                    http://www.youtube.com/watch?v=4avDfYhNS18
                    http://www.youtube.com/watch?v=6iBffNrzTnM
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      i had some issues with the transflective screen....it was horrible. money waisted but came up with a cool setup to replace that one.
                      this setup is completely wireless,yet is still integrated into the boats controls.
                      my new setup consists of a fujitsu q550 win7 tablet, a linksys wireless hub, belkin network usb hub,usb dac and the mjs usbio1's.
                      the tablet now is fully unteathered and portable so it can be taken indoors or in the tow vehucle.
                      check it out
                      http://www.youtube.com/watch?v=CUr1l...e_gdata_player
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        havent had a lot of progress as of late (been doing a ton of boarding though )
                        my motion computing cl900 FINALLY came in and is awesome!
                        sunlight readability is pretty good you can read it in every condition except when the sun is directly reflecting off of it into your eyes.
                        linked up to the belkin hub effortlessly
                        relatively heavy for a tablet but not horrible
                        battery life...AMAZING this thing will last all day on a charge... well they spec it at 8 hours but with the use it'll see on the boat... it'll last all day.
                        it's waterproof, can handle splashes. all the ports are sealed...except the dock port. odd.
                        performance... well it's not great; after all it's a tablet pc. it runs riderunner fine.
                        it also has a nifty little dock for the digitizer pen (in case you need to do any on the fly coding?
                        It's a bit more expensive then a mobile pc but its well worth the price
                        M10k
                        My Car Pc Install
                        My Boat Pc worklog
                          so a little more progress on v02 of the project. not much but here i started the dev portion of the rotation angle sensor that im building into my new setup
                          here is a video of the proof of concept.
                          total cost of parts for this was under $5. if you look at the multimeter you'll see that it sweeps as the magnet rotates. I plan on taking this data and inputing it into the pc. this will let me know where the wedge is at all times. I'll also be able to engage the wedge when i get up to speed like malibu's set up (but mine will never lose calibration
                          the resolution is a lot better then what i had my dmm set up for, butyou get the idea
                          M10k
                          My Car Pc Install
                          My Boat Pc worklog
                            Hey guys,
                            so after not being very happy with the drawbacks of a windows based mtc system (expensive, poor visibility in sunlight, EXPENSIVE, unstable, etc...) I decided to teach myself how to code micro a n00b friendly microcontroller; the arduino. There are a lot of advantages of this system over the pc based system:
                            THE OLD:
                            price: the win7 tablet, i/o, wifi hub, usb hub cost 1k+
                            battery life: the tablet i had was great on battery life. but even in optimal conditions it would last ~7-8 hours. This would require me to be very conscious about the usage and would require me to make sure i had a full charge before each outing and to remember to charge it each night on long weekend trips
                            boot time:
                            self explanatory. not a huge issue but annoying
                            stability:
                            the old system needed wifi connectivity, usb hub connection, front end program and the win7 os to all be stable. this wasn't always the case. and the last thing i want to do is troubleshoot on a morning when the lake is glassy.
                            THE NEW:
                            price: so far i'm less then $200 in on this. I am going to integrate this with my tablet foran android control for my music/media which will raise the cost if you dont own one already. but they can be purchased for < $100.
                            battery life: this is all wired so no issues with battery life.
                            boot time: seconds
                            stability: it's a simple program. the code is tiny and purpose built.
                            my new motto for this build is to be inspired by apple. to make things quick, smart and easy to interact with. with that in mind i have the following functions implemented:
                            Power Wedge controller. to make the system as user friendly and ergonimic as possible. i decided to include a knob for manual adjustments of the wedge. There is also a menu screen that has 4 presets as well as a 'retract' button. Each preset can be set by the user if they hold down the corresponding button when the wedge is at the position you want. Right now i have just a numeric reading of the angel of the wedge. but when i get into the design phase of the UI, it'll be a visual circular bar graph to tell you where the wedge is.
                            i also plan on putting the wedge 'w' in the center
                            Ballast Control. for the most part we fill or empty all of our ballast. so i have my main ballast screen that will either fill or empty all the ballasts (based on time limits) with a simple 'flick' of the screen. 'up' will fill all ballasts. 'down' will empty all ballasts. If there was interest or I got into wakesurfing. I could split up the screen into two. one side would set the ballast for boarding, the other half would set it for surfing
                            If you want to fine tune your wake. a 'long press' of the ballast screen will take you to individual pump control.
                            Power Control: the last screen i've worked on is the power center. Since my goal is to eliminate the need for a cd player, i have an button that will turn on or off the amps. in addition this menu will control the various lights of the boat. I'm still undecided but I'm considering having the center button open a 'keypad' to enter in a code that will lock/unlock the pushbutton starter button.
                            things that i'm still working on, or plan to implement:
                            Andriod integration: music/media player as well as using the voice recognition app for voice control over all of the functions (i.e. music, wedge preset, fill ballast all through voice command)
                            if anyone here knows how to write android apps, i could use some help with this.
                            anyways.... here is the work in progress:
                            http://www.youtube.com/watch?v=jf3E6WMADiQ
                            M10k
                            My Car Pc Install
                            My Boat Pc worklog
                              a small update
                              updated gui.
                              initial tests of wedge positioning system and automatic knob system are working but need a bit of tweaking
                              streamlined the gui a bit
                              added a visual representation of approx web position (circle around the 'w')
                              improved responsiveness of the touch screen (swipe function)
                              to come:
                              ipod control
                              gps speed based wedge functions (wedge only will function at certain speeds)
                              features put on hold until possibly next revision:
                              ballast weight calculation (doing it old school for now)
                              M10k
                              My Car Pc Install
                              My Boat Pc worklog
