2000 Jeep Grand Cherokee - CarPc and 7" touch monitor
  • 2000 Jeep Grand Cherokee - CarPc and 7" touch monitor
    Project:
    Out with original stereo, in with 7" touch monitor and CarPc with Win7 and Centrafuse
    Use original Infinity 180w amplifier
    Rear view camera
    OBDII connect
    Movie server for iPad
    GPS
    DAB
    (plus many other ideas)
    1st step was to mount the 7" Lilliput UM-70 USB Touch monitor
    Dremmel is a lovely tool
    To be able to fit the monitor I had to cut out as much as I could over and under the monitor.
    Then filling the gap on each side of the monitor.
    Preparing for the last step...
    Sanding and sanding...
    Painted and with the monitor in place.
    Before and After
    images arent working for me. anyone else?
    I too have a 2000 GC so I will be paying close attention to your build. Keep it up.
      Pics look fine here. And nice job on the build btw.
        Restarted and now I can see them. That's a great setup man! Where are you mounting the computer and ipad?
          Next step...
          Hi!
          It has been a while since I started this project, but I'm still working on it
          From the battery I have a 4,5 mm2 power cable back to the 12 to 230v unit in the trunk.
          In with the power cable and 2x USB cables.
          60 Amp fuse, primary for short cut problems.
          The Laptop with USB Audio, USB hub with LAN, Video capture (rear camera), Bluetooth, GPS and 2,4 Ghz connection to keyboard/mouse pad.
          I "added" new line in and power connection on the amplifier.
          And of course a fuse
          This i much better!
          About the iPad question...:
          I'm not mounting it, but the kids can view movies from a Video server on the computer.
          More info about it later
            were you able to provide low level audio input directly to the infinity amp and it worked? i thought it was expecting speaker-level inputs coming form the headunit. thanks!
              Originally posted by theksmith View Post
              Were you able to provide low level audio input directly to the infinity amp and it worked?
              Yes, it worked very good. The connection is direct from the headphone output on the laptop and to the audio input on the Infinity amp.
              I thought it was expecting speaker-level inputs coming form the headunit. thanks!
              No, I'm pretty sure that the output from the head unit is low-level.
