1973 Lotus Europa Special #2936R -- Full Worklog -- BoyRacer0013
  • 1973 Lotus Europa Special #2936R -- Full Worklog -- BoyRacer0013
    The time has come for me to start a worklog as work will hopefully be starting on the lotus soon. But first a little about the car, #2936R, we Europa freaks call out cars by their numbers. Now I could trace it all the way back to its production date, but that is boring, so I will just say what I plan to do to #2936R. It will get 4 wheel disk brakes, a Ford Zetec engine with a turbocharger, MegaSquirt ECU, 5-point harness, new wheels & tires, all new rubber, probably all new glass, loads of body work, lots of cool lights, new interior, and a full computer system.
    I have divided the computers into two basic systems, the basic level and the main level. The idea in doing this is to have a setup so that if I wanted to I could drive the car without running the main level computer, but the basic level computer will likely be an always-on system.
    The main level computer system hardware will be:
    - Motherboard - ASUS F1A75-M
    - CPU - AMD A6-3650
    - RAM - Patriot Viper Xtreme Performance Desktop Memory Kit - 4GB (2 x 2GB)
    - SSD - OCZ 60G Vertex 3
    - PSU - M4-atx
    - Center console display - Lilliput FA1011-NP/C/T
    - Gauge display - Lilliput 869GL-80NP/C/T
    - Passenger display - Lilliput 869GL-80NP/C/T
    - Motorcycle amp - whatever I find cheap when I need the amp
    - Speakers - I think I have a set laying around somewhere
    - Dash mounted USB hub - ?
    - Computer bay USB hub - ?
    - Wifi - ? USB adapter
    - Bluetooth - ?
    - GPS - BU-353 Weather-proof
    Main level software:
    - Tunning software - TunerStudio
    - Front End - waiting to see what happens with OM and FreeICE
    - OS - depends on FE, preferably Ubuntu
    Basic level:
    - Primary logic board - Arduino Mega
    - Secondary logic board - Arduino Uno
    - Displays - serial 128x64 LCD - x2
    - Temp sensors - thermistor - x6
    - Heading sensor - HMC6352 Compass Module
    - Engine start button - some type of arcade style button
    Well I think this is a good start, any input or opinions?
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Planning: ::::::::::::
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
    Install: ::::::::::::
    Oh, yeah, and build the car... ::::::::::::
    Alright, pushed the car outside today and took some pre-work pictures.
    Here is #2936R
    Click image for larger version
    Here is the frunk, where the computer itself will go.
    The drivers monitor will replace the speedo and tach.
    The passanger monitor will go in the glove box opening.
    And the main 10" monitor will replace the ash tray, window switches, and radio.
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
      I'm curious to see where this goes.
      My Blog - http://brians-240sx.blogspot.com
      Carputer Progress
      Design [||||||||--] 80%
      Install [||--------] 20%
      Software [||--------] 20%
        Me too...
        Enter the LOTUS...
        (more info here)
        Pre-build thread
        Parts: ::::::::::::
        Build: ::::::::::::
        Test: ::::::::::::
          Subscribed...
