F150 Center Console Build W/Questions
  • F150 Center Console Build W/Questions
    Hello, I finally started my first build and thought I would post Some Pics, I also have some questions if anyone could possibly help, thanks.
    Specs:
    Screen: Lilliput 12.1" SDK Touch Screen
    Computer:
    Abit IP35Pro
    Q6600 QuadCore
    Corsair 128mb SSD
    WD Scorpio 320gb
    Power Supply/Power Unit: Undetermined
    Bluetooth: Undetermined
    Peripherals:
    Atheros Wifi
    Shuttle Contour
    Backup Camera
    Scantool USB ODBII Interface
    Audio:
    10"JL W3
    Some older amp - cant remember
    OS:
    Thinking Centrafuse?
    Here are some pics of the console so far, Still need to finish fiberglass and paint, also intergration of Iphone Dock into console.
    Input is appreciated good or bad.
    QUESTIONS: (May edit with further questions later)
    I am looking to intergrate my iphone into the project--Any recommendation on best way bluetooth/cable intergration?
    I would like to connect my backup camera to my vehicles reverse lights <--so simply shifting into reverse switches the monitors input. Unfortunately my lilliput screen does not appear to have a 12v input switch connection,
    any idea on how I could achieve this.
    Here are some pictures of the build thus far, I should have some finished pictures up towards the middle/end of next week.
    Update 5/6
    Haven't had a lot of time to work on this but school is almost over.
    I have almost completed the console. I had to redesign the iPhone dock because I ran into
    a couple of issues. I will post some pics with explanation in a few days.
    For now, I completed final assembly, everything is glued and ready for paint. The recessed portion next to the cup holders
    is for a Shuttle contour. If anyone has any recommendations before I paint it let me know. Always open to new ideas.
    Can't see the pictures for some reason..?? Would be interesting to see how you plan on fitting that monster (monitor) in the dash. Threre seemd to be ways of enabling the autoswitch on some monitors. Search "lilliput autoswitch" and you'll see a bunch of posts on the subject.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      Pictures are showing up for me. It appears the monitor is going in console, not the dash. I gotta feeling glare will be an issue with the angle it's on but maybe you can shield it. Greta looking consoile though, I will be following the progress of this build for sure!!
        I had a feeling the job's firewall is blocking the pictures. Will see em when i get home then..
        EDIT: Now i can see it - Very nice!
        OLD SYSTEM (DEAD)
        M2-ATX Power Supply
        Windows XP SP3
          Glare was an issue with the way I first mounted the screen. (as seen in the 1st couple pics) I later parked the truck in the sun and calculated the best viewing angle of the screen relative to my position in the truck and glare does not seem to be affected.
          Thanks for the info on the lilliput autoswitch, I will be sure to do some research.
          edit:: Looks like this monitor is not setup to autoswitch<--only thing i can think of is to make a controller of some sorts and have and solder it to (input) switch from screen. I think this is going to be a pain in the ***.
            Little Update: I had some difficulty finding a good location to mount my iphone into the console. After searching for phone docks that would work without removing the phones case, I decided to just build my own.
            I finally decided on having the dock retract using an xbox disc drive and some drawer slides into the console. <--It sounded simple and easy but has proved to be more work than planned. None the less almost done.
            Here is a couple of pics of the build so far. I am just waiting for my shuttle contour to show up, then I can finish routing into the console and start the final fiber-glassing.
            Xbox Drive Disassembled.
            Iphone Dock
            Closed Dock
            Mid Dock
            Open Dock
              Pop-up dock is sexy!
                Wow the dock looks awsome! & so does the screen placement! Got any other goodies that your integrating on the console itself?
                  That dock setup is awesome. Anymore pictures and details on how you used the drive. I have an old drive that would be perfect for something like this.
