2003 Dodge Caravan
  • 2003 Dodge Caravan
    Aloha...
    I have been keeping an eye on the www.mp3car.com site for years (probably since the site first started) and I have been dreaming and planning a carputer since then. Now 3 cars since then...I finally am getting there. Right now I don't have a lot to say but I finally wanted to get my work log up so I can start posting pictures and info. Let me start with this
    The stock radio has been removed and replaced with a Kenwood 4x100 RMS amp
    The rear Speakers have been replaced with 2 4-way 6x9 Rockford Speakers
    The front speakers are still stock 6x9 but I want to replace them the component speakers and put the tweeters in the dash where 2 5 inch rounds are supposed to be but are not hooked up
    I have a Visteon HD/FM/AM tuner hooked up but waiting the install of a set of EQ's to control the volume
    I purchased a Clarion 7 band EQ but just got it and haven't put it in yet
    I also have a Rockford Mono 1000 watt sub amp with 2 10 punch 3 subs
    Right now I just have pictures of the van to share. Enjoy. More later
    Click image for larger version
ID:	2310898Click image for larger version
ID:	2310899Click image for larger version
ID:	2310900Click image for larger version
ID:	2310901Click image for larger version
ID:	2288111Click image for larger version
ID:	2288112Click image for larger version
ID:	2288113Click image for larger version
    Here are so0me non-stereo related pictures. I had everything nice and organized...well I don't want to get into it. This just happened to be the first folder I got straightened out. Sorry for not being tech related but to me a build involves everything.
ID:	2288115Click image for larger version
ID:	2288116Click image for larger version
ID:	2288117Click image for larger version
ID:	2288118Click image for larger version
ID:	2288119Click image for larger version
ID:	2288120Click image for larger version
ID:	2288121Click image for larger version
ID:	2288122Click image for larger version
ID:	2288123Click image for larger version
      One of my project also s to replace the carpet which is stained some and just needs to be replaced. The previous owner took good care of the van but after I owned it for a while I just wanted to update the carpet and I have decided to make it modular so I can replace pieces if need be. I also have decided to use this rubber mat instead of carpet. It is durable and I can basically just wipe it clean. HEre you can see some of the pieces as I am putting them together. I wrapped the wood and put an edge on it to keep it down as well as assist in just protecting it. Next I will show you what I came up with for my wiring.
      I hope thee all get posted because though they are all related together in the long run.
        I am sorting through my wiring pictures I will post those today and the story behind the van
ID:	2288129Click image for larger version
ID:	2288130Click image for larger version
ID:	2288131Click image for larger version
ID:	2288132Click image for larger version
ID:	2288133Click image for larger version
ID:	2288134Click image for larger version
ID:	2288135Click image for larger version
ID:	2288136Click image for larger version
ID:	2288137Click image for larger version
ID:	2288138Click image for larger version
ID:	2288139Click image for larger version
          In my build I have to make everything functional. I am a father of twins ad we take long drives sometimes, plus when we do vacations we take enough stuff we look like we are invading the area more than vacationing. So as I design everything it ahs to be durable and removable. I have painted the sides of the cargo area with black truck bed liner. I am in the process of replacing the carpet with rubber matting. The subs are set up the same way. So its more of a "ruggedized" build.
          More pictures and some stories coming tomorrow.
            Here are some pictures of the new speaker covers I made form other cars speaker covers. I combined a set from a Caravan and a Grand Caravan to make these. I had to do it because the 4ways center hit on the ones that came with the van. So I had to make these so they wouldn't hit.Click image for larger version
ID:	2288145Click image for larger version
ID:	2288146Click image for larger version
ID:	2288147Click image for larger version
ID:	2288148Click image for larger version
ID:	2288149Click image for larger version
ID:	2288150Click image for larger version
ID:	2288151Click image for larger version
              Why should stick shifts be the only cars that get custom shifters? No reason...So I did mine.
ID:	2288153Click image for larger version
ID:	2288154Click image for larger version
ID:	2288155Click image for larger version
ID:	2288156Click image for larger version
ID:	2288157Click image for larger version
                I wanted to replace the stock lock pulls. I found these skulls but the post for the pulls were too small for the door panels holes. SO I modified the stock pulls by cutting the tops off and gluing the posts for the skulls inside the stock pulls. Honest I am getting to the wires. Still a couple things to go. I want to share every aspect.
ID:	2288159Click image for larger version
ID:	2288160Click image for larger version
ID:	2288161Click image for larger version
ID:	2288162Click image for larger version
ID:	2288163Click image for larger version
ID:	2288164Click image for larger version
                  Finally to the area where I a running my wires. I tried to run the 2 and 0 gauge under the door jams but there wasn't really enough room so I decided to make this center alley as I call it for my power runs. It makes tons of room for wires and cables.
ID:	2288166Click image for larger version
ID:	2288167Click image for larger version
ID:	2288168Click image for larger version
ID:	2288169Click image for larger version
ID:	2288170Click image for larger version
ID:	2288171Click image for larger version
ID:	2288172Click image for larger version
ID:	2288173Click image for larger version
ID:	2288174Click image for larger version
ID:	2288175Click image for larger version
ID:	2288176Click image for larger version
ID:	2288177Click image for larger version
ID:	2288178Click image for larger version
ID:	2288179Click image for larger version
ID:	2288180Click image for larger version
                    Nice solution to a major problem! Your getting close to finishing Good Luck SNO
                      Thankyou - I have a lot of pictures to put up. and more work to put into it also.
                        Wires and RCA cables I have used for my install...Note That I recently replaced the blue RCA cables that are in the one picture because I have installed a Clarion EQ and the 2 channel RCA cables just don't cut it anymore. I have a 2 gauge to my distribution block which splits to 4 gauge to each amp. Then I have 0/1 gauge for the ground which goes from the battery to a distribution block also. I am woring on replacing the front speaker wire but the rear has been replaced already. Click image for larger version
ID:	2288182Click image for larger version
ID:	2288183Click image for larger version
ID:	2288184Click image for larger version
ID:	2288185Click image for larger version
ID:	2288186Click image for larger version
ID:	2288187Click image for larger version
ID:	2288188Click image for larger version
