10.4 screen install, pics, need opinions
  • 10.4 screen install, pics, need opinions
    *** Update : added more install pics
    This is my first attempt, so please feel free to laugh, but also feel free to comment, I have no pride to bruise.
    Here is a few shots of what I have got so far. What I am looking for are opinions on the overall layout of the frame before I start filling and fiberglassing.
    The size of the screen leaves just about no space on the sides. I initially wanted to have the sides slope at more of a angle back down to the dash but it does not look like this is going to happen here is a closer view of what little room I have on the sides with the current setup.
    So what do you guys think? Am I on the right track?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    oh, and I forgot, I also was looking to get ideas and suggestions on what to do with the vents above the screen the screen blocks about a 1/3 of the space that the vents once occupied, I would like to keep them opperable if possible. I was thinking of just cutting some slots in a piece of wood above the screen.. anyone else try something different?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
      Wow thats an awfully ambitious project but it looks like it should work. You still have a ton of work in front of you though. I think it would still have been easier to start with the stock part. If nothing else you could still reuse the vent portion of it. Good luck and keep us posted.
      Fabricator
        big *** screen. i don't have the balls to tear that much of my dash board out
        Carputer pics
        PC box under passenger seat - xenarc 7" 16:9 touchscreen
        dash screen 1
        dash screen 2
        dash screen 3
        computer box pic 1
        computer box pic 2
          not bad! I like it. Can't wait to see it finished.
          CAR:2001 Ford Crown Victoria
          PC: Acer EEE 900HA with Win7 with CF 2.0.
          Memory:1G
          Drives:160gig
          WI-FI:Cingular
          GPS:IG2k9
          Screen:Xenarc 700TSV
          The Florida Meets Thread
            I was going to use the stock center piece, but the screen was so wide that I would have been cuting trough the clips on the side and the screen is rather thick because of the backlighting needs at least an inch and a 1/2 clearence, I thought that it would petrude to far. I still am concidering trying it again with the stock piece as a base, but I think I am going to go this route first and see how it goes.
            My Install
            Software:
            CFiG v1
            CarShell
            StopWatch
              ah it is really no different from what you have to take out to but yours in, just looks worse cause the design of my dask is slightly differnt and takeing the center piece off exposes the whole center.
              I have had it off for over 5 months now, no stereo for the last couple of weeks, I have kinda gotten used to a big hole in the center of my dash.
              Your screen look real good!
              My Install
              Software:
              CFiG v1
              CarShell
              StopWatch
                You should mold the original vents into your new housing...I think that would look and function badass!
                  I like it, ballsy but cool.. As far as the vents.. could you get some from a junkyard and incorperate them into your design ?? (near the top of the screen, that big open space)
                  edit: oh a few more things:
                  you should consider tilting the screen backwards increasing the angle to your eyes... it looks to flat and you might have trouble seeing some portions of the screen....
                  Also, the two side rounded wood pieces stick out a little bit and when you cover this it's going to create an awkward ridge...
                  Progress [I will seriously never be done!]
                  Via EPIA MII
                  512MB RAM
                  OEM GPS (embedded)
                  nLite WinXP pro on
                  1GB Extreme III CF card
                  Carnetix 1260 startup/ DC-DC regulator
                  Software: Still, re-Writing my existing front end in .Net
                    All I can say is great start. My Sentra has a similar center console setup, so you're giving my lazy *** ideas again
                    "I'm a dick!"
                    "I must seek knowledge and it's bastard son truth" - The State
                      Ya I am actually working on that right now, hopefully I can get somehting sorted out and I throw up the pics
                      I am thinking of makeing it pivot up and down for that reason, but that might be overkill, I have not glued it yet so that angle was just a guess.
                      Ya that was my major delema, the few people I have had look at it think once it painted it will look ok, but I am unsure myself. That is the part I keep struggleing with tring to figgure out a better way to do it.
                      Thanks for the comments
                      My Install
                      Software:
                      CFiG v1
                      CarShell
                      StopWatch
                        wow, the 10.4 inch screen should be awesome....good luck with the fiberglass, i cant wait to see it when its done.
                        Current Progress:
                        [▓▓▓▓▓▓▓---]80%
                        Final Assembly
                        Ramline P3 PC
                        10.4 inch Touchscreen
                        Windows XP Embedded
                        Road Runner
                        http://www.projektnepa.com
                        Electrical Engineer / Mobile DJ
                          I just went out side and cut up a piece to show what I had in mind, the cut was ruff and Would box in the vents but this is just to show how high up the vent will now be
                          you can see in that pic just how much of an angle the vents will now be at
                          And this one will give an overall idea of what i might look like in the front.
                          My Install
                          Software:
                          CFiG v1
                          CarShell
                          StopWatch
                            WOW thats nice, I dont see why the vent wont work like that.
                            1990 Jeep Cherokee
                            2000 VW Golf TDI 4dr
                            2005 VW GTI MKIV - SOLD
                              I'd put some insulation around it though so when you run the heater your not heating your screen.
                              2.4 celeron
                              150 watt OPUS
                              micro atx
                              xp pro
                              tv/radio tuner card
                              audigy
                              Dual monitor Radeon
                              802.11G Mimo
                              xm pcr
                              dvd
                              gps
                              8" Lilliput touch screen
                              IGuidance
                              dual optimas
                              battery isolator
                              15" screen
                              My Truck
