'97 VW Passat Install
  • '97 VW Passat Install
    Hi, been working on this for a few weeks now and just got it in the car. I've still got the main loom to install along the sill and a few PC bits to sort out along with an anoying audio whine. More pictures will be posted when I've time.
    Ben G
    '97 VW Passat
    VIA M10000, 256Mb RAM, 40Gb HDD, Win XP
    Lilliput 7" Touch Screen, GPS, IR Steering Wheel Remote
    http://www.gibbsdesign.co.uk
    http://www.matesmotors.org.uk
    97!?
    In the US, the body style didn't change until 1998's model year (purchases after September usually are named for the next year). My 1997 Passat doesn't look like yours, it's a B4, yours looks like a B5... and I got REALLY excited when I saw this thread.
    BTW: NICE job! I really like how you've put a USB port on the dash!
    Car: 1997 VW Passat TDI moving to
    1985 Mercedes-Benz 300D
    CPU: HP ePC 1gig/256meg/250 gig
    Status: Ghetto Install w/Inverter,
    Xenarc & GPS & RadioShark
    ToGo: DC-to-DC conversion, Grease conversion
      Nice!!! Why didn't you move the AC control down? I think you woud've got a better viewing angle. I like the usb too.
      Renault Megane...the OEM look
        Hi, Yea mines an early B5 (June 97), they changed between '96 - '97 in Europe.
        Thanks, I plan to find some black countersunk screws to neaten up the USB port a bit.
        I thought about moving the heater controls down but that may happen in the future. It was going to be more hassle than I wanted at the mo with making fixing brackets etc..
        Ben G
        '97 VW Passat
          If you'd tighten things up a little in there do you think you'd have enough space for a slim slot in? You could mount a tray slim vertically, but that's not that great looking, is it...
            Probably not, I've already cut the buttons off the bottom of the tft to fit it in.
            I'm not to fussed about a CD up front as I don't think I will really be using it to watch DVD's etc.. but hey you never know.
            Ben G
            '97 VW Passat
              Where's it currently located?
                Its all in a Morex case in the boot. At some point I may make a custom install in the boot and fit a drive up front.
                Ben G
                '97 VW Passat
                  Hey Ben! Do you have any updated pictures of install? Would be good to see as I have a friend with a Passat who is considering doing something similar...
                  My '84 Austin Mini Carputer Project : http://www.mp3car.com/vbulletin/showthread.php?p=541067
                    Hi, not at the moment as I have taken it out of my car.
                    I've been looking into using a different mobo and mounting it all in the glove box.
                    I'm looking to use a single board computer I use at work and hopefully the on board sound will be better than the Via M board. I had to use a PCI sound card to get it to sound half decent.
                    I should be getting something together this week to test the sound quality.
                    When I do that I'll have to put the screen back in so I will take some pictures and post them up here.
                    Ben G
                    '97 VW Passat
                      New Pictures
                      I have been busy working on a new case and finding somewhere to put it.
                      It all fits into a box I had lying around at work and its behind the glove box between the bulkhead and the blower motor.
                      Ben G
                      '97 VW Passat
                        That's one awesome case .
                          Screen Moved
                          The screen has now been moved as it was too low to use safely.
                          Just got to make a box for the PC as I'm probably going back to the M1000 Mobo as I can't afford to spend the money on a new one at the mo.
                          Ben G
                          '97 VW Passat
                            Catputer Install - Continued
                            Car: VW Passat 1.6 S 1997 (P)
                            PC:
                            Motherboard: VIA M10000 Mini ITX
                            CPU: 1 GHz
                            Memory: 256Mb PC2100 DDR
                            HDD: 40Gb Western Digital
                            LAN: 10/100 & WiFi
                            Case: Custom with 2 40mm Fans
                            Sound: USB 5.1 Sound Card
                            PSU: M1 ATX operating as a standard PC power supply
                            Screen: Lilliput 7" Touchscreen
                            GPS: Jupiter GPS board with home made RS232 converter PCB
                            Software: Win XP Pro, stripped down with XPLite. Road Runner, Mappoint Europe, VAG-COM OBD-II.
                            Audio: Aux input to a Pioneer DEH-P3500MP, Standard speakers in front, Kenwood mids and tweeters added to the rear doors.
                            Some build pictures:
                            Rear of the screen
                            Inside the GPS box
                            Inside the PC case
                            More pictures and info to come.....
                            Ben G
                            '97 VW Passat
                              I love how you flush the screen than the recent setup. You should move the AC down and place the old screen setup above the AC controls. That would look sick.
