02 Vaxuhall Corsa SXI Worklog
  • 02 Vaxuhall Corsa SXI Worklog
    The Car: 2002 Vauxhall Corsa SXI 1.2I
    <<Image to follow>>
    The parts:
    Motherboard
    Gigabyte 7vkmp & Mobile Duron 1Ghz
    Video Card
    ATI Rage Mobility - with tv out
    Radio
    Dlink DU-R100
    GPS
    BU-303
    Second Screen
    5" lilliput - tv in
    still waiting for PSU & Xenarc.
    also USB hub, Bluetooth & misc wires.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Have been running my BU-303 in the corner of the dash for a few months now, Normally get 8 sats, lowest ive noticed is 7.
    software im going to be running:
    either 2k or XP - leaning towards XP for min logon and a few other things
    will be using Road runner as a front end, have also played with FrodoPlayer but for me the menus are a bit busy to use while driving.
    for GPS i will be using freedrive.
    my power cables have been run and hooked up so im ready to start the install, xenarc is going to go where the double din HU was, PC will sit in the glovebox and the amp will sit above it.
    the motherboard juts perfectly into the glovebox, but i cant quite fit in a pci card, going to have to cut the glovebox up so waiting for a spare.
    Type-R Mini
      sounds like a nice little project there mate! Keep us all updated with how things go - it's cool to see carputer installs in UK cars now and again - puts things more into perspective for me somehow
      cheers!
      My '84 Austin Mini Carputer Project : http://www.mp3car.com/vbulletin/showthread.php?p=541067
        The PC is going to mouted in the glovebox.
        Glovebox with Opus mounted
        a few shots of the indise
        govebox closed with pc all hiden away.
        powr cables were in place so decided to try it out, nervousley put the key in the ignition.......Wait for PC to start....... NOTHING...... just as im about to take the key out it fires up
        i had a few problems, i orignaly mounted the opus at the bottom of the glovebox, but it got in the way of the ports, so moved it to the top but had to turn it round because of the fan, ATX connector was too far away, so had to change the direction it was in, its ok now though
        you cant realy see it in this pic but there is a lof of space behing the opening in all directions, so im going to mount my amp behind there (its only a 120W to power the stock speakers so its not v big) and the xenarc.
        Type-R Mini
          Just be careful with heat behind the screen if mounting an amp there as well.
            already thaught about that, there is quite a bit of room behid there and vents into the footwells, but theres also an air intake behind there to draw hot air away
            Type-R Mini
