BMW Carputer..yet unique..NEED HELP! :)
  • BMW Carputer..yet unique..NEED HELP! :)
    hey guys, ive decided to build myself a carputer. Just about to order my computer parts, got my software all set (frodo player). My cousin is gonna build me a bad *** comp so that side of the project is taken care of. On the other hand the wiring is gonna be tough. i got some questions about this installation before i start. Some may think its odd, but ive decided to mount my touch screen..either lillput or xenarc above my stock cd player..infront of my middle vents. yea i know it will be blocking the vents partially but ive seen some pics of other peoples setups and they say enough air gets in. Ive decided that im just going to mount the carputer in the trunk, not sure where yet. Ive decided to go this way because i dont wanna start molding a new dash and i dont mind having my stock system in there. Who knows i may upgrade to an M3 in a year or too so i guess this is just to get my feet wet. Plus if i mount the LCd above the stock headunit it will be more visible for me to see and use. I'd like all of your comments and questions and as much help as you guys can give me as i start this project. Im going to buy the shutdown controllor aswell. It looks to me that this piece should be built into the computer tower..or am i wrong..where should this be mounted? Also im keeping my headunit in place....so what do i need to buy to split my headunit harness into two pieces..so i can get sound to my computer and to my headunit. I plan on building a switch board in front so i can turn off the sound from one to the other. I believe my car is prewired for a cd changer so hopefully cables are there, unless i can buy some kinda piece that i can connect my harness too, and then feed it to the headunit and my computer..let me know if i lost anyone there or am i talking out of my *** lol...basically just wanna be able to use my headunit sometimes, but also be able to use the LCD and switch back and forth. So for now let me know what you guys think. I will post pics as i go of course
    thanks
    Jason
    Check to see if your HU has AUX input..
    Then it's only a matter of finding the pins to connect your CarPC to on the HU..
    After that you get it amplified first through the HU and any amps you have connected to it..
    Cheers
    /p
      k thanks guys...i dont have the HK headunit so it does not have aux..i have looked at there installation pages..however they are taking out their headunits...so they can just use those harnesses...i plan to keep my headunit in so my project is somewhat different from theres.
        I'm sorry i was under the impression this was the place to post pics of your completed setup...am I wrong??
        Dell C600 laptop
        Dell C dock II
        7" Lilliput VGA TS
        JVC Mp3 Headunit
        Holux GPS
        ...Its all working now in the car but far from complete.
        [|||............] 35%
          yea i ment to puit this under worklog but i guess i didnt click on the subcategory..how do i move it over
            would this work
            http://cgi.ebay.com/ws/eBayISAPI.dll...787673974&rd=1
            and then i plug rca's from my desktop into there, and then just splice those wires and make a switch??
              You dont actually need those, you can go directly from your soundcard to RCA
              with a 3.5mm->2xRCA cable bought at all wellstocked audio stores
              (All non-wellstocked aswell.. One of the most common cables to be sold)
              It's what's used to connect i.e a mp3-player or portable cd-player to your
              home stereo..
              Cheers
              /p
                yea but what do i do with the rcas lol...im buying the blitzsafe adaptor and using it as aux
                  alright i bought a USA Spec Aux interface for the bmw from crutchfield....now im a lil stuck on what to do. Originally i was going to buy a carputer with a 200watt power supply and then buy a power invertor and wire it to my battery. then i was gonna buy a shutdown controllor. then i started reading things about the 90 watt atx power supply with a built in shutodwn controller but it only had 90 watts and wouldnt be enough for all the devices i chose. What should i do. Id rather use the parts im going to buy which are basically for a normal desktop..then use the invertor and the shutdown controller if that works just aswell as the mini atx power supply and motherboard. please let me know what everyone thinks.
                  thanks
                  Jason
                    Try this? http://www.mp3car.com/show-off-your-...n-display.html
                      Is there another Navigation panel PC thread?
