2003 Cavalier - First Carputer - Planning and Gathering
  • 2003 Cavalier - First Carputer - Planning and Gathering
    Ive got a 2003 cavalier and Im going to install my first carputer, here's some pictures on what I plan to do!
    Im taking out the stock stereo putting in a new panel with 2 usb connectors, a power on/off switch and my cd/dvd rom drive. Im mounting the touchscreen on the visor and running the cable along the left top side.
    Custom fabricating my console to mount my mobo and other parts in there and running the cables under the console up to the dash.
    Do you guys think this setup will work?
    Car: 2003 Chevy Cavalier
    Cpu: 800mhz, 512mb ram, 133mhz fsb, 40gig hd.
    Install Progress[|||||||||||||||||||||||||] 95%
    Fixing Sound System
    Plans have changed, Im installing the 7inch touchscreen where my Stereo use to be Ive got the dash and my console all ripped out now. Today im gona start fabricating my console to mount the mobo. Then I need to find out how to get my powersupply wired to my car. I'll take pictures when I get off work.
    Fixing Sound System
      Cool, will be awaiting updates. I had an install in my 96 Cavalier, was my first one.
      Zen Fat Loss
        I was going to take pictures last night but the lighting was horrible and my camera phone pictures came out horrible, so I I'll take some today. Update news, aquired an AMP, and 2 subs working on putting them in, cut out my console to fit my mobo and my disk drive/usb ports. Still working on a way to power my carputer with the PSU I have, might have to just break down and buy an Opus Does an Opus require a 12 volt regulator, or does it do that its self?
        Fixing Sound System
          Watch for high temps.
          I take it that the computer itself is going behind the gear stick??
          Just a caution, is the exhaust which sometimes runs next to the tail shaft near there insulated, as it would get dam hot, in my RX7, temps of 50C + isn't uncommon, worse on a hot day.
          I would have thought that there is lots of room behind the glove box, and easier to keep cool with modding the aircon.
          waiting for updates.
          Mazda RX7 12AT with all the spoils, EFI computer, remote keyless entry, 1000W Kenwood sound system, PIII 1GHz car PC running XP pro, wireless options, 14in LCD screen, ME 2.1 for MP3, movies etc.
            Ya its going to be inside of my console, and for the heat problem, im running a tube from my AC down into the console box where the computer is. I think that's what you were asking?
            Fixing Sound System
              Yer, i think that would fix the problem of overheating.
                Looks like you want to do nearly the same thing as me with you center dash.
                Are you planning on fabricating the plastic to go around the DVD player, usb hub, and button?
                2002 Grand Am progress :
                [] - 80%
                ...complete setup, but still need to make the install cleaner
                  Sure am, Just got my subs/amp installed and am working on mounting my computer.
                  Fixing Sound System
                    one thing to keep in mind about that A/c vent is when you use the heat....a lot of people think that the A/C vent is an easy fix, until someone bring heaters into the equation!
                    glad to see you decided to mount hte screen in the center of the dash, it's a much easier location to work with and allows more room (those screens can get fairly hot)
                    looks like a pretty good install thus far!
                    Jan Bennett
                      Alllright, I got my Speakers and Subs Hooked up to my amp and now have my carputer Mounted in my console. But I need a fusetap for the Control Line on the amp, Ive looked at all the Car Audio/Car Parts stores around here and checked ebay, anyone got any sites that sell Fusetaps for the Smaller fuses? OR have any ideas on a way to make one?
                      Fixing Sound System
                        Allright, The install is complete and everything worked the first time around! I'll have pictures up later!
                        Fixing Sound System
