4th Gen Maxima Carputer Log *56K beware*
  • 4th Gen Maxima Carputer Log *56K beware*
    Hey there,
    I've been doing this project for the past month and it's almost time to install. I have pictures and videos.
    Here's my setup:
    (Hardware)
    Epia M10000 OverClocked to 1.2ghz
    Tview 700TS monitor (thing's a dream)
    512 Ram
    Dvd-Slot load pioneer rom
    160gb IDE HD
    holux 210m GPS
    Sound blaster Live! external 24bit
    Ikea Karbo Keybox Case
    (Software)
    Windows XP Pro SP2 stripped down to level 3(tweakhound)
    RoadRunner with BMV2.1 Brush Alum Skin
    Winamp lite with tripex vis
    Iguidance 2.1 GPS software
    So far I've cut the case and drilled the holes for the screws/washers, installed the mobo, installed the OS and got RR running to my likes. Here's a video of the touchscreen in action (26mb)
    http://www.petah.org/maxima/carputer/MOV02511.MPG
    Here are some pics of me taking apart the monitor and test fitting it into my spare bezel.
      mkay - that's a lot of pics of the same thing!
      I'm sure someone with that kind of screen will be interested in those pics though. Some people are rather nervous about taking apart their screen because they are worried that they might damage something back there....
      I'd love to see pics of where you are going to put everything if you have them!
      Jan Bennett
        Pics have got to be 800X600 max. It's in the rules.
        Peace,
        Rafster
        Post # 3000
          thats alot of foto's
          is overcloaking a good idea. considering these mobo's will get hotter than normal?
          View My Blog
          Click for 2GB FREE on-line storage!
            Peace,
            Rafster
            wouldn't it be wise then to have a plug in that automatically resizes them for the board and links them to the full size pic?
            a few boards I'm on do that
            Jan Bennett
              wariow, If I were you I would frab the original bezel because if you don't your going to have problems mount the screen into place.
                Yeah, that would be really great. I know it would save a lot of time/forum bandwith reminding people to
                Peace,
                Rafster
                Post # 3000
                  I'll resize em tonight, was just too excited/lazy to change the reso. Also I'm gonna update with new pictures and a video
                    I have made some cuts around the edges of the bezel of the screen and test fitted with the bezel and test mounted on my center console.
                    With back bezel on as well
                    test fit with lcd panel reassembled
                    It's alive!!!
                    Miss hamasaki posing for us
                    some jbquik to secure the lcd bezel to center console bezel
                    A couple of more shots
                    Will start bondo over the weekend, it shoudn't be too hard. i'll start the wire work while i wait for the bondo to cure, then it' off to sand and more sanding.
                    For paint, i'm gonna try to keep it flat black but wiht a thin layer of clear and a quick 1000+ grit sand to match that oem matt look.
                    Any comments/suggestions welcome!
                      progress of my monitor, I did some bondoing and some machine sanding to fill in the gaps to smooth out the edges.
                      first coat of prime
                      more sanding
                      a few sprays of flat black/next to oem bezel
                      more sanding with 1000 grit and final results
                      better closeup, i think it matches pretty well
                      back into the frame
                      it works! (also changed the green led to white)
                        That led got bright.
                          how to iron your own damn shirt eh? lmao. nice install - so so clean... well done!
                          http://www.digital-car.co.uk
                            yes the girlfriend got it for as a "present" I don't think i'm gonna ever touch that book.
                              Hey, nice work so far. What year is your Maxima?
                              Peace,
                              Rafster
                              Post # 3000
