Nano ITX in an Evo
  • Nano ITX in an Evo
    Well guys here we go !
    I think this is almost the first Nano ITX project
    I got most of the parts in from digitalww and mp3car stores
    Its on the bench and working from a spare car battery, the nano and m1 atx doesnt seem to use any power.
    i have had the system run for 24 hours off the battery alone and the m1 didnt detect a low voltage !!!! this was powering the board in windows, displaying only the desktop, so power consumption would be minimal, I was chuffed at that result ! means that even if the power off doesnt happen, chances of a flat battery are minimal, the longest the car stands still for is 12-14 hours, this is also good for update purposes.
    The nano heatsink has reached a high temp of 43.1 deg celsius when measured with my pyrometer, and this with the fan off, I will run it with the fan on in the car as the car environment isnt as controlled as a bench
    The nano itx is awesome, I dont find it slow at all (my laptop 2ghz celeron with 512MB ram) is slower on most tasks, my desktop a P4 3.0 with 512mb is slower on some tasks but obviously much faster on others
    What all I crammed into the box...made up by a local perspex supplier at a cost of 12USD
    The boxes dimensions are
    165mm x 210mm x 65 mm all dimensions are external
    The innards
    1 x M1 a t x power supply
    1 x Nano itx mobo with 512MB RAM
    1 x Dlink USB Fm Radio - hardwired to usb port to eliminate connections and also using the audio in of the cd on the mobo, so no external connections
    1 x Griffin airclick receiver
    1 x 60gb 2.5 hdd
    1 x notebook adapter (although if you got the right cables the nano supports this natively
    1 x a t x power adapter
    1 x 60mm case fan
    1 x slot load cd/cdrw/dvd
    all it needs is power (+ and - and ign +)
    and then the usb from the creative usb sound card to work 100%
    here are a few pictures !
    please comment and also please let me know if you are aware of anyone with a good obd interface for the Evo8 ?
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Pictures??
    Tidder
    Try RevFE
      no pics?
      Progress [I will seriously never be done!]
      Via EPIA MII
      512MB RAM
      OEM GPS (embedded)
      nLite WinXP pro on
      1GB Extreme III CF card
      Carnetix 1260 startup/ DC-DC regulator
      Software: Still, re-Writing my existing front end in .Net
        mobo and case pictures
        some mobo and case pics
          cheesh
          you guys are fast
            Where's the mobo?
            Renault Megane...the OEM look
              more pics
              more pics
                the mobo is so small its invisible
                coming in a sec
                I can only post one message every 45 seconds
                  more pics
                    more pics2
                      more pics3
                        more pics4
                          and some of the car and a few friends
                            Nice Job! Where do you plan on putting the computer in the car?
                            Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
                            GET PAID TO SURF THE INTERNET
                              the pc will be located under the steering column
                              with the slot load accesible through the gap between the steering column and other plastic bits
                              the screen (motorised 1 din) will go in the normal radio location
