2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
  • 2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
    ALL DONE!!!! http://www.mp3car.com/vbulletin/showthread.php?t=63433
    I plan on having this completed by the end of the coming week, but probably will be done sooner! I spent about 6 hours today on relocating the head unit. Step 2 will be moving the AC Controls to the lower center console, Step 3 will be the 8" Lilliput 809GL monitor and PC installation.
    Step 1: Complete
    This turned out better than I thought it would. It required no real fabrication (read: no bondo, fiberglass, etc). I used a heat gun to slowly mold the front fascia of the clock pod and a dremel to dremel it out so the radio would fit from the rear. I also dremeled the hell out of the original clock pod and center speaker mounting brackets so the radio would fit. The clock pod cover was originally so rounded that the stereo face itself wouldn't even fit where it is now just setting it there from the front. The heat gun worked wonders! As usual, looks way better in person.
    Everything works including the motorized detachable face.
    Project 1: 2002 Dodge Ram 1500 w/ 15" LCD (finished)
    Project 2: 2000 Mitsubishi Eclipse w/ 8" LCD (finished)
    Project 3: 2000 Pontiac Grand Prix GTP w/ 8" LCD (finished)
    Project 4: Dodge Ram Repair
    Lets see a pic from a little further back
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
      Nice! Where are you going to relocate the AC controls?
      Renault Megane...the OEM look
        I would suspect in the din opening below the stock location (can be seen from the first picture). At least that is where I would put them...
        2005 Black Chevy Impala
          hu looks good, what model is the pioneer hu?
            I plan on putting the AC controls into the lower center console in front of the shifter. The screen will fill up most of the area where the current radio/pocket/ac are located and should leave me enough room for a media card reader. The screen doesn't get here til tomorrow so I'm not for sure on space there.
            Pioneer DEHP8600MP
              instead of a media card reader why dont you put a slot load slim drive or maybe even a slot load fullsize dvd drive? that would look sweeeet
              i got dat ***** sittin on 22s! SUPERMAN EDITION!
                I measured it just now and according to the size of the 809gl it may even be hard to fit a media card reader in the space I have, I guess I'll find out tomorrow.
                I had considered putting a DVD drive in the center console lid facing forward. My car is the RS, it came with no center console lid, so I made one.. I'd just have to redo it a bit to fit a drive in it, not a big deal. I don't want to put one in the front cause I'd use the media drive more often and I don't want to wait to order one
                WooHoo! Just got the manual push/pull heater cables extended! They work great. I used ring terminals for connection points and positron bicycle gear cable with reinforced bicycle sheating.
                  looks good so far. keep us updated.
                    This is taking a lot longer than I wanted it to! But doesn't it always?
                    The fiberglassing of the lower dash took a lot of time but tonight I finally started priming it. I've got 4 coats of the finish coat on the upper piece with the screen and 2 coats of primer on the lower dash piece (for the heater controls). The textured black spray paint I got from Home Depot looks like a match to the factory interior, tomorrow I'll spray some matte clear and hopefully have time to finish it.
                    I have lots of pictures I'll be posting along with the finals either thursday or friday!
