'95 Tahoe Center Console (Pics)
  • '95 Tahoe Center Console (Pics)
    It will house the computer and the headunit. Pretty basic besides that.
    Mounting Plate
    Cardboard Mockup
    Transfered Template to 1/2" MDF
    Quick jig I made
    Tray that was fabbed in
      that looks GREAT! i think you should extend the ac wires and put the ac controls in the upper area over the radio lol wow that sweet dude.
      i got dat ***** sittin on 22s! SUPERMAN EDITION!
        Grr, youve already convinced me it would be easier to just move them down in the upper console.
          Fiberglassed the Front Today
          I took weather striping and put it on the front parts the touched the dash, then I wraped the front in fabric, brushed on some resin, and pushed it firmly against the taped off dash. When it dried, I had an almost perfect mold of the dash. Then I reinforced the back with 1.5oz matte. I still have a lot of sanding and filling to do.
            looks to be coming along quite nicely!!
            RIP 1993 civic sedan
            RIP 1993 civic Del Sol
            Hello! VW Golf 1.8t
              hehe sorry. i change my mind alot. mine is actually going to be start sanding tomorrow. ill post pics when i start
                Isn't there a handbrake in your car? And how about a gear shift (an automatic transmission?)?
                  E-Brake is a pedal on the left side. Automatic transmission shifter is on the column.
                    Good to know . Nice work!
                      Flattened the top. Filled the holes.
                        LOOKS CLEANNNNNNNNNNNNNN keep up the good work!
                          I did some routing with a 1/4" roundover bit today. Also did a bunch of sanding and made the lower shelf (the one that will hold the computer.)
                            I used Rage Gold for the first time today. I highly recommend this stuff. Ready to sand in less than 10 mins, sands very easily, and its green. I also mounted the L brackets. They are only held on by one screw right now, but will be fiberglassed in in the next few days.
                            Then I made half of the extended wiring harness. The other end will have the connecter that is in the dash on all 88-02 GMs. Its about three feet long. I used 18 awg for the speaker wires, illumination, and remote, and then 12 awg for the power, ground, and ignition. I will probably end up grounding the headunit down on the floor though.
                              Primed the front.
                              Made the top with flush mount hinges
