2004 Dodge Ram 2500 Quad Cab Turbo Diesel
  • 2004 Dodge Ram 2500 Quad Cab Turbo Diesel
    I thought I would start a work log since my project is coming along nicely and will be done within the next two weeks.
    This is my dash before I started on the LCD. I didn't realize it was sitting upside down when I took the photo!
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    LCD Wood Frame
    This is the frame that I built to go around my 8" Lilli.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
      Sloped LCD Frame
      You can see that I built a 10 degree "slope" into the frame for the LCD. This is so that it angles upward a little to help with glare. When I glued it into the dash bezel, I also tipped it slightly towards the driver.
      8" Lilli TS
      MB896F Mini-ITX MB
      1GB SDRAM DDR2 533
      3COM BKP Cam
        Test fitting
        This is the LCD set into the dash bezel for a trial "fit". Here you can also see that I relocated the HVAC controls to the lower opening which used to be a cubby hole. I enlarged the cubby using a spindle sander.
        8" Lilli TS
        MB896F Mini-ITX MB
        1GB SDRAM DDR2 533
        3COM BKP Cam
          Found a case
          This is the box I'm using as a case for my motherboard. Its an old KVM switch that I had laying around.
          8" Lilli TS
          MB896F Mini-ITX MB
          1GB SDRAM DDR2 533
          3COM BKP Cam
            Back of case
            This is the back side of the KVM. You can see I will have a lot of holes to fill!
            8" Lilli TS
            MB896F Mini-ITX MB
            1GB SDRAM DDR2 533
            3COM BKP Cam
              Case getting closer
              This is a photo of the case after MUCH modifying. The motherboard stand-offs have been bonded into the bottom of the case. The "front" of the KVM is now the back of the case and I have cut out an opening for the bezel that goes around the connections on the back of the board.
              The small square opening is for a rocker style power switch.
              The back panel looks a little wavey from the fiberglass backing that I used to cover the hole cut-outs from the KVM. However, the other side of this panel looks perfect and is nice and smooth and flat. I figure its the outside that matters anyway as far as looks go.
              8" Lilli TS
              MB896F Mini-ITX MB
              1GB SDRAM DDR2 533
              3COM BKP Cam
                Case with Lid
                This photo shows the case with the motherboard and power supply.
                To the left is the lid for the case. I cut out a 3" hole to hold an 80mm 32CFM fan. I have a chrome grill which will go over the top of the hole.
                The 4 holes to the right side of the lid will hold the hard drive in place.
                8" Lilli TS
                MB896F Mini-ITX MB
                1GB SDRAM DDR2 533
                3COM BKP Cam
                  Adding a vent
                  I needed to add a vent to the case to allow fresh air inside. I found this grill that came from an old PC. It was actually a faceplate for the front of a PC case where a floppy drive could be mounted. I thought it would make a perfect vent!
                  8" Lilli TS
                  MB896F Mini-ITX MB
                  1GB SDRAM DDR2 533
                  3COM BKP Cam
                    Vent roughed in place.
                    I decided to mount the vent into the side of the lid for my case. I chose this location because when my case is located in the vehicle this "high" location on the case's lid will afford the most air flow.
                    Here the vent has been cut and bonded into the lid using epoxy.
                    8" Lilli TS
                    MB896F Mini-ITX MB
                    1GB SDRAM DDR2 533
                    3COM BKP Cam
                      Looking good so far!
                      Have you done any testing yet with your 8" Lilli? If so, what do you think. I am looking to put that exact monitor in my Durango, I just have to read some more reviews before I make a choice.
                      2003 Durango Install
                      2003 Matrix Install
                      2004 Escalade Install
