2003 Durango install started
  • 2003 Durango install started
    I am onto install number 3 now. I just picked this 03 Durango up 3 weeks ago. I need to get an 8" lcd I am going to put into the center console. For now I just started mounting what was left over from my old car. I built a raised floor and ran all the cables under it. I had to relocate the tire iron and jack tools to the compartment lid to make a little more space for my home made PC case.
    2003 Durango Install
    2003 Matrix Install
    2004 Escalade Install
    I updated a few pics above. I have to run a few cables behind the trim, I plan to run everything at once.
    I have been searching and came up with a few topics that make sense to me. I need to buy a startup/shutdown controller to hook up to the power supply. Is there a clear set of instructions anyone can post for me? I plan to keep searching for now.
    2003 Matrix Install
      Here are a few pics of what I started today now that I have a project housing to start with. The sides will be done in foam to follow the contour of the center console and hide the rest of the cup holders. I plan to try my first shot at fiberglass once I have everything done. My goal is to make this removable so that I can go back to the factory look if I ever need to. This whole thing will bolt in from the bottom of the console. I still have a lot of work to do!
      2003 Matrix Install
        holy crap... this is the first install pics ive ever seen of a durango install! you're the greatest matrix
        [::::::::::] 100% - Planning
        [::::::::::] 80% - Computer
        [::::::::::] 0% - Fabbing
        CarPC:
        SP13000 / 120GB SATA 2.5" / 512MB DDR
        8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
        Slot load DVDRW / PS3 Wireless Keyboard
          My wife is off work to help with the little one tomorrow, hopefully I can make some progress tomorrow after work!
          2003 Matrix Install
            Here are a few new pics. Next is to start adding foam and sanding it.
            2003 Matrix Install
              Are you going to mold 2 cylinders and use the cup holder to retain this? I guess it would clear on the way in...
              '03 Acura 3.2TL Type S
              '04 Buick Rainier, factory nav
              '99 Honda Shadow 1100
              -8" Lilliput TS, laptop, (too) large inverter, and I'm nowhere near putting them anywhere.
              For Sale!
                That was my original plan, but the console needs to be mounted from the front too. It is impossible to mount everything, and still get the screws in. I think I am going to have to mount it on the outside by recessing the screws so it does not look bad.
                2003 Matrix Install
                  Looking good!
                  How's that USB hub? I've seen one like that the other day, and wanted to get one...what are you running of it?
                  Renault Megane...the OEM look
                    Originally posted by Cris
                    Looking good!
                    Still a lot to do, and I will get my first shot at fiberglass soon.
                    I have only used it inside to test it and it appears to have all the power requirements I need. I am running just a 4 port hub to it that is in the center console. I have a mini laptop drive that runs off USB that is the main thing I am running on it now (I like to have my music removable if needed). I mainly got it for when I add on in the future (not sure what yet).
                    2003 Matrix Install
                      Few new pics, still a lot of sanding to get the sides done evenly, but it is getting there. Anyone have any good links on how to fiberglass? I have not started looking yet, but I am sure there are a ton out there.
                      2003 Matrix Install
                        Please keep posting pictures! I just found out about carputers last night, and now plan an install in my '04 Dakota. I really like the way you install the screen and probably will copy that
                          Tomorrow it will be warm enough to start the fiberglass. I will post more pics tomorrow.
                          2003 Matrix Install
                            I only had time to start one side today. I am using Bondo Fiberglass Resin Jelly. I did a few test runs to see how well it worked and how well it sets up in the nice Chicago weather. Any comments from the Fiberglass gurus?
                            2003 Matrix Install
                              lookin good, its looks like the screen will be really usable.
