2002 Mitsubishi Magna VR-X - 15.4" ultrabright LCD, fabricating...
  • 2002 Mitsubishi Magna VR-X - 15.4" ultrabright LCD, fabricating...
    ____________________________________________
    Thread Breakdown
    Original LCD fab starts at Page 1 - Post#11
    Original computer casing/mounting starts Page 2 - Post#23
    Sound starts Page 3 - Post#35
    LCD upgrade starts Page 3 - Post#40
    Fiberglass bezel work starts Page 4 - Post#46
    WiFi upgrade starts Page 4 - Post#53
    Skin work starts Page 4 - Post#57
    LED case fabrication starts Page 5 - Post#72
    Bezel molding starts Page 5 - Post#73
    The Car:
    After many hours of reading and thinking (and saving $$). Ive decided to start my carputer project. I live in Australia about 30 minutes drive north of Sydney. My car is an 02' model magna vr-x with a 3.5L V6 under the hood. This is an Australian made car.
    The Computer:
    Components:
    I was originally wanted to go with the new mini-itx Pentium 4 boards, but changed my mind because of the high power they use, the more heat they produce and the price. I didn’t need the crazy processing power anyway.
    VIA MII-12000 is the board for me, 1.2GHZ is plenty to run XP and a few apps. Inbuilt CPU means another component I don’t have to worry about. Board is 170x170mm, should fit nicely behind my dash. Purchased from a local dealer auspcmarkets.com.au for AU$302.50 delivered and is on its way.
    The screen was a hard choice, I wanted to get a Lilly manly for the support for it on these forums (like detailed tutorial on how to dismantle it), but my dash wouldn’t allow it. I only had 110mm tall gab to work with and the smallest lilliput was 125mm (I want the buttons). With my low knowledge of fabrication and experience in this sort of thing I decided to look for a smaller one with less modding. I found a 7"er on eBay by an Ex-Audio importer that will work. It is only 115mm tall which means I only have to cut 5mm to make it fit nicely. Also I like the buttons being on the right hand side close to the driver. 200:1 contrast and 400 nit brightness which is same as lilliput. This screen was AU$270 delivered from Hong Kong and is on its way.
    M2-ATX Power supply seams like the best option. Lots of power to play with, regulator and shutdown controller inbuilt. I always enjoy Plug and play, it’s the story of my life. I had a hard time trying to get this item within Australia. I ended up buying from eBay from an american dude, only US$9 shipping to AUS, not bad for an american postage price. Total prices AU$123 delivered and is on its way.
    Gear:
    I wrote out a shopping list and went to my local hardware store (Bunnings). I got a bunch of little things that ill need like soldering iron, solder, shrink wrap, dust mask, hot glue, tape, more dremal bits, sanding blocks ETC. For the fibo filler I bought somthing called Plasti-Bond. Comes with plenty of hardener and a nice big informative directions on the back. This tub was AU$50 and is 2Kg, amazingly it was only 2$ more then the 900g one. I had allot of brands to choose from, it was about second from the top in price. I also got some white primer, and some black paint, both aerosols. I got a little tube of bondo cream incase I need to touch anything up, prolly wont use it though.
    The screen will be fabricated into the double DIN spot of my car. The computer will squeeze in a flexiglass casing behind the screen (or so I hope). This mean the only cable coming out from the dash will be a USB for peripherals and sound. I found a spot to mount the computer case. But it mean I have to cut some metal out, which i dont mind doing.
    So the idea is to undo the bolts at the top, 2 each bar, then cut where i have marked. If I do this it will give me about a 300x200x200mm gab to work in, and will also give me a place to mount the case to those top bolts. Only worry is that the metal is supporting something that need that much strength. These bars are connected to so many different things down below, including the chassis, that I think it will be ok to cut them.
    Day 1:
    Received my mobo today, very nicely packaged and arrived within 30 hours of me placing the order. Included was an IDE cable, floppy cable, face plate, driver cd and instruction booklet. No mobo risers or screws, I have plenty of those anyway. Still waiting on the power supply and the TS, expected to take longer considering they are coming from out of Aus.
    A shot before I took the dash out completely, its 'loose' but gives you an idea what it looks like beforehand.
    Took the dash peace ill be working on completely out of the car today. Notice how little room there is to work with top and bottom, but some good space on the sides.
    For the hard drive and ram ill be buying locally. 512 RAM seams plenty for this motherboard. I haven’t decided which hard drive to go with. 2.5" is low power, but for the same price as an 80GB 2.5" I can get a 250GB 3.5". I have the spare power I think, but would the VIA bios recognise a 250GB? Would like to hear feedback on this one! Thanx for all your comments so far.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    That vehicle isnt Aussie made... its the same as the American Diamante VR-X... just a differant bumper.
    Looks like a good project, the interior in those cars are pretty good looking, great for a carputer.
    ~Kris
    [1995 Nissan 240sx]
    Planning.........[::::::::::] 90%
    Parts.............[::::::::::] 60%
    Construction...[::::::::::] 10%
    Software........[::::::::::] 50%
    [1994 Mazda RX-7]
      Good luck to you!
      I've seen that Ex-audio screen on ebay, I'm very curious to hear what you think of it when you get it.
      I am an American soldier. If you will not stand behind me, feel free to stand in front of me.
        Great post. Looking forward to seeing how it turns out.
        My Worklog
          i always liked the vr-x. Car had so much promise. To bad the engine wasnt up to par.
          Live mp3Car Facebook Chat
            Mitsu Aust has been exporting Magnas/Veradas to the USA since the 2nd gen was introduced.
              Also to prove it I found an American car company eBay ad showing the manufactures label. Look at the last picture, the white label.
              http://cgi.ebay.com/ebaymotors/Mitsu...09298144QQrdZ1
                cant wait to see more of this install
                2005 Nissan Xtrail
                DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
                worklog
                  Touche'
                  Why that uglified the front-end in 2004 I dont know....
                  ~Kris
                  [1995 Nissan 240sx]
                  [1994 Mazda RX-7]
                    Touche'
                    Yeah, I dont really like it either. Looks like a fake Kia front end.
                      update
                      **UPDATE**
                      Screen arrived today, packaged nice and tight. First thing that caught my attention was lilliput logo all over the parts. The driver cd had it, the remote and the instruction book had lilliput all over it. This screen is a re badged lilliput with a different case and repositioned buttons. Because of this, all the ribbon cables etc are very easy to remove and I had it open in a mater of minutes.
                      I didnt waste any time. Got everything set up outside, got the rotary out and started measuring. I taped the points where I cant cut beyond and began hacking. After I cut to the tape, I used a sanding bit to get a nice smooth fit for the bezel. Hot glued the bezel in place. Then went over the top with some epoxy glue. Little tip when using epoxy glue, mix the stuff in little bits at a time, this stuff sets in less then a minute, also make sure you have all the tools you need to apply it before you mix. Over the top of the epoxy, I put some clear bonding agent.
                      Now I wait 16 hours for the glues to completely set hard. Tomorrow I will attempt the front bondo.
                        I have a magna too that i'm workin on
                        Final Touches
                        Car: 2002 Mitsubishi Magna EI
                        CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
                        Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
                          Awsome, got a worklog link or somthing?
                          Check out the au magna club. Hope to see some of your pics soon -
                            yeah i'm there on aussiemagna. still didn't start on a workblog.
                            I have the stuff (check my sig), but still workin on the PC at home. will post pics soon. good luck with ur project.
                            Final Touches
                              **UPDATE**
                              First layer of bondo applied, filling all the gaps and cracks. Waited 30 minutes to dry rock hard.
                              Second layer. So chunky, I think I put a bit to much on. Waited a few hours.
                              Sanded it back using 80 paper. The bondo cut back very easy, im suprised. Made it into this in just 10-15 minutes of soft sanding.
                              3rd layer to fill the gaps and holes.
                              Tommorow, more sanding and then the spraying
