SRCSTC's New Carputer Worklog - 00 BMW E46 323Ci
  • SRCSTC's New Carputer Worklog - 00 BMW E46 323Ci
    Current List of Parts:
    http://www.mybimmer.net
    some nice stuff your using there. How much is everything costing you?
      @ cj8501: couldn't you just go in and add it all up yourself?
      @ srcstc: what are your plans for all of this equipment? I see you're selling some other equipment? from an old install? change of plans?
      Jan Bennett
        More Pics...
          SRCSTC,
          From your choice of hardware its obvious that you know what you're doing. You made excellent selections. I do wonder why you chose such a small and slow hardrive? Have you considered getting a larger capacity, higher spindle speed, SATA hardrive? With disk being so cheap these days you may as well get a drive with at least 200 GIG.
          8" Lilli TS
          MB896F Mini-ITX MB
          2GHZ Dothan 533MHz FSB CPU
          1GB SDRAM DDR2 533
          Seagate 300GB SATA150 HD
          ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
          Pioneer Slot Load SLIM DVDRW
          Bluetooth V2 USB 2 Dongle
          3COM BKP Cam
            Originally posted by DaveB
            SRCSTC,
            I chose it for it's size. I wanted a low-power notebook drive. It does have an 8Mb buffer.
              Ah...okay, I see you're using the 120 watt Opus. I'm using the 160 watt M2-ATX. Power wasn't so much of a concern for me with that PSU. I opted to go with a 300 GIG SATA drive.
              Just in case you haven't put your PC together yet, I can let you know that Intel has a more current driver available for the 915GM chipset which gives a lot better resolution options than the driver that ships with the CD that comes with the motherboard. The Lilli TS driver needed to be updated, too.
              I have most of the drivers needed to get everything working correctly. If you're still in the process of building the PC and are interested in the drivers let me know and I'll post them for you.
              8" Lilli TS
              MB896F Mini-ITX MB
              1GB SDRAM DDR2 533
              3COM BKP Cam
                When will it be ready?
                Renault Megane...the OEM look
                  Thanks for the tip! This it?
                  http://downloadfinder.intel.com/scri...ional&lang=eng
                    It is.
                      Originally posted by srcstc
                      Yep, that be it. File name is win2k_xp141950.exe
                      I tried to attach the good touchscreen driver for your Lilli, too. Its way better than the one that ships on the mini CD with the monitor. The file is 3.62 meg zipped and the forum choked on it. If you PM me your email address I can mail it to you.
                      8" Lilli TS
                      MB896F Mini-ITX MB
                      1GB SDRAM DDR2 533
                      3COM BKP Cam
                        Thanks. I have a xenarc though.
                          Sheesh.... Sorry about the brain fart on my end. Obviously, its time for me to take a break from the PC.
                          8" Lilli TS
                          MB896F Mini-ITX MB
                          1GB SDRAM DDR2 533
                          3COM BKP Cam
                            It is.
                            Well then, show it off!
                              Pics added
