2001 tacoma install
  • 2001 tacoma install
    12/1: Please note that updates to the original post are in red *CLICK HERE FOR NEW PICS*
    1/27: UPDATED PICS ON PAGE 2 (OR CLICK HERE) WITH THE P1900 INSTALLED AND THE MAC MINI MOUNTED UNDER THE PASSENGER SEAT
    3/28: In case nobody read that far, my truck was broken into on valentines day. All my stuff was stolen out of it and it's been in the shop until TODAY (see this post for more details). So my new car pc project begins tomorrow.
    Ok, so I've been working for about a week or so, and I've gotten part of the way along with my install, so I thought I'd start a worklog. Also, since I'm having a bit of a problem with the screen install, I thought this would be a good place to ask a question.
    First, description and pics of what my setup will be and what I've done so far.
    carpc: a 3year old hp ze4500 lappy (celeron 2.3, 256mb ram, 40gig hdd dvd/cdrw)
    Since replaced because I killed it (see below). New PC is Actually a 1.5 core solo mac mini. 512mb ram 60gig hdd and dvd/cdrw
    touchscreen: ex-audio (lilliput) 7"
    sound blaster 24bit external usb sound card (works great)
    MA Audio M489i 4 channel amp *shrugs* I got it for $75, the guy said it was an okay amp so we'll see Actually, this amp is great and seems to put out way more power than my stock speakers can handle, which means I may have to upgrade to better speakers
    netgear usb external G wireless (thank you woot.com) Replaced by internal wireless and bluetooth of the mac mini
    gyration mouse and keyboard (also works great...except sometimes the mouse has to be retrained ($35 refurb from woot.com)
    holux gr231 external usb/bt gps
    Replaced with delorme POS USB mouse GPS after I lost the Holux when i moved
    So far, I've got a slipstreamaed xpsp2 reinstall on the hp done
    the screen attached to the oem bezel thing from my truck done
    The monitor is now totally in and the mac mini is "installed" and working, though not mounted and i still haven't got the p1900 power supply I've been meaning to buy for almost 6 months, so I just use a $30 inverter from FRY's which gets the job done more or less. All that is now done too
    and that's about it lol
    now then, pics! Look down to the bottom of the page for updated/better pics showing the mac mini installed, and page 2 showing it installed under the seat with the p1900
    here's the screen on that day it arrived via ups
    here's the "done" shots of the bezel after being sanded and painted to accomodate the bigger than double din size of the screen
    I sanded with 150 dry, 400 and 600 wet sandpaper, used bulldog adhesive promoter (makes paint stick better to the plastic) and a flat enamel rustoleum spraypaint. the result is almost exactly OEM, but not quite. With one or two more coats closer to the bezel, it could have been perfect, but it was close enough and I didn't want to have to strip it off and start over had I messed it up.
    here's the shots of the two together in their final preinstall state. i used some sort of "plastic concrete" I think it was called. Dries like solid plastic in 5-10 minutes. excellent as a glue or as filler since it's easily sanded and grinded, yet very strong.
    and here's the plastic concrete stuff holding the screen to the bezel. i was really suprised to see how strong the bond is.
    now, the reason I did it this way instead of fabricating the screen into the bezel itself are twofold:
    1. it was easier
    2. if I need to replace the screen, it's going to be alot easier this way
    so, basically, it was easier
    big props to my dad for all the help he's been giving me with this project. (yeah, I'm 26 and I still need my dad's help sometimes)
    if anyone is still reading this far, on to my problem. Today, I tried to wire up the screen to one of my power ports (my taco has 3 including the cig lighter). the problem is that it works fine if I use the included adapter (cig style), but when I cut the wire and tried to wire it directly to the leads coming out of the power jack, it blew the fuse in the little box on the power cord. This happened twice with 2 different (but identical) fuses. I have no idea why this is happening, anyone who could shed some light on this would be my new best friend. Fixed
    Okay, that's it for now, flame/praise away
    Nice install! It always looks nice when you can fit a screen behind the dash if you are not going to fabricate it in. I have seen very few I like where they are mounted to or in front of the dash. Let me be the first to ask if you have wired it correctly when you are trying to hard wire it into the cig lighter. I am sure you have thought of that, but I do not see why it would not work if wired correctly.
    2003 Durango Install
    2003 Matrix Install
    2004 Escalade Install
      thx man, I think it looks pretty good. Not as good as some others I've seen on here, but it didn't take me nearly as long either.
      As far as the wiring, I wired the positive wire from the screen's power cord to the positive prong. one thing that is wierd though, my power cord (the truck's cords) all have 2 white wires going into the positive end and 1 red wire going into the neg end. I assumed the extra wire was a ground, but then why does it connect to the positive plug.......
        I took out my headunit and 8CD changer today, and gave them to my pops whose '99 4Runner's CD player died
        I think I have the wiring problem figured out. It seems that the other white wire is an ACC wire, and the1st wire comes from the ignition for the ON position, or else if port was wired directly to the battery, the port would draw power all the time and it does not.
        I guess I'm either going to cut the plug and goto the power wires directly, or I'm going to have to take the guts of the port out and plug the cig adapter into the power port behind the dash. I'm not sure which one I'm going to do yet though.
        Anyway, tomorrow (5/4) I'm going to install the amp (already got the wire through the firewall to the battery fused right before the battery with an inline fuse (per the directions that came with the amp). Also tomorrow, I'm hopefully going to get the rest of it set up except the mount for the laptop which I'm going to solve later as i don't have the button for the laptop power button wired to it yet
          Nice work!
          Beautiful work! Love how you didnt have to mutilate the screen and made it tons easier upon yourself. I took a similar approach of making things easier and keeping things clean and sandwhiched the screen onto the dash... in other words I opened up the screens frame and put the front of the screens frame onto the front of the dash din and the back of the screens frame in back of the dash and voila! I put the screws back in and sandwhiched the frame onto the dash while keeping the screen perfectly new and not using anything to mold on the screen. My main intention was taht I wanted to keep the screen new and factory in case I wanna take out the screen one day or sell it or if I sell the car off. while still keeping the screen pretty much factory it just made things so much easier.
          about the wiring, does the adapter for the power that came with the screen have any circuit boards or anything inside of it? some stuff that you can power in the car has a board or resistor built into the small plug in order to regulate the power properly. That could be why you kept blowing the fuse. As I said I tried to keep my screen factory I did the same to the plug and just bought an extra outlet from the local car place and tap into the wire of the cig lighter/outlet in the car using one of those wire taps that you can clamp on. This way I just plug in the screens adapter and go. You can see it in my worklog if you get a chance.
          sorry for the long post I tend to do that... Everything looks good though! hehe and my dad helped me with mine too, he was actually the one that helped with the sandwhiched screen idea.
          Car: Nissan Maxima 1997 5-SPD
          Current carputer status: 92%
          my carputer worklog: click here
            by the way that plastic concrete stuff that you used to hold the screen in place, do you happen to know if it holds good on exterior things? like under different weather conditions? The reason I'm asking is because a city bus hit my side mirror and the plastic of the mirror holder is cracked and weak now so it shakes a lot on the highway...
            Thanks in advance!
              Thanks, I'm so pumped cause it looks like this is gonna be done by sunday
              I would assume the plastic concrete (the name on the tubes is plastic welding system) would hold that just fine. i picked it up at one of those "pro" hardware stores, the kind that are in industrial areas and not residential places. It's some kind of epoxy that dries to hard plastic within like 5 minutes. I forgot the name of it, because the tube itself doesn't really have a name on it. it's 2 seperate tubes that you have to mix together (like the bombs in die hard 3).
              The screen has an inline fuse with what looks like a small circuit on it, like what I used for the amp's power but more complicated. Other than that I haven't taken the screen's casing apart so i don't know
                Ok, no new pics cause my camera died and I can't seem to find the charger...sigh...
                Anyways, I have the screen installed now, looks nice works great and all but I have a problem I'm still working through. My door speakers seem to have a bad connection to the amp, and I'm trying to get them connected up all nice before I put everything back together. Also I'm having trouble finding a powered USB hub that I can splice into my car's power (I don't have an inverter or a power supply or anything). I may have to get something like a 2 outlet inverter for the USB hub and have one open for expandibility. The laptop I'm using is going into and coming out of hibernation preyy well, but I still have to wire up a power button of some kind as my current ghetto solution of actually pushing the button on the laptop is not gonna get it done in the long term. Any advice on that would be welcome. Also, I haver my ipod (old 3g style) going into to the line out of my sound blaster, so anything I have been to lazy to sync to my carpc hard drive I can just play right through the ipod.
                I think that's about it for now, everything (except the above) seems to be working really well, and music actually sounds better now (with the amp and no headunit) than it did before which is cool.
                OK pics to come as soon as I find the charger for my camera
                  ok, well it took a little longer than I expected to get my act together and finally take some pics of it installed (it's been like over a month)
                  but, better late than never, so here we go.
                  Hopefully, I'll get my truck detailed soon, and then I won't be embarassed to show you all pics of the rest of the interior
                  BTW, thanks to everyone on the forum and the forum itself. My drive to and from work has never been enjoyable (over an hour a day)....until I installed my carpc. I could've never done it without this place
                    I do not Understand why you had to paint the bezel? How much did you take off? It doesn't look like it was much trimming...
                    I am thinking of doing exactly the same thing.
                    Where do you have your PC mounted? any pics?
                      I used this type of "concrete" too. it is soo hard, it spoilt my pair of pants.
                      Final Touches
                      Car: 2002 Mitsubishi Magna EI
                      CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
                      Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
                        wow guys, I feel bad for having not replied to your posts, I haven't been to the site in a while.
                        Anyway, to answer flyingwil I had to paint it cause I sanded quite a bit of the OEM opening to get the screen to fit in there with the buttons and all. Underneath the black, the bezel is some kind of bondo like color and so I had to paint it. I suppose I could have chosen to only touch up the affected area, but I doubt I would have been able to do that without making it look obvious and bad.
                        I had the hp lappy mounted under the passanger seat with the dvd drive facing the passenger door and basically only accessible if you opened the passenger door and bent over from an outside position.
                        Anyway, that worked for about 3 months or so (until about the end of July), and I didn't take any pics sorry. the hp was awesome because the auto hibernate feature meant i could just cut the engine and get out of the car no problem, and a $3 button wired to where the cigarette lighter used to be worked great for those 3 months, but it ended up being the un doing of the whole thing. See I had to soulder the wires from the power button onto the main board of the lappy (which i did). But then being the lazy *** I am, I never properly sealed it back up the way i should have, and i eventually left the windows down on a muggy night, and when i went to work the next morning, i pushed the power button without even thinking about it (as i had done for like 90 days in a row) and I heard a bzzzt and the hp was dead.
                        It was a rookie mistake, and I definately learned my lesson about exposed wires and moisture in the air. they don't mix
                        So, that sucked for about 2 weeks while I decided what to do. I ended up getting a mac mini and installed windows on it using bootcamp pending a mac frontend as easy to use and feature filled as centrifuse or roadrunner
                        Anyway, The Mac for right now (since august lol) sits on my cebter console covering two of the cupholders. This is temporary until I get the carnetix power supply?shutdown controller for it and then I will mount it under the passenger seat like the hp was. I don;t have any pics of it right now, but I'll see if I can hook some up this weekend.
                          you got a worklog or a finished project page I can check out?
                            sorry not yet, it's still not finalized, but i'll have one soon.
                            Final Touches
                              well, the guys that wash cars came by my office complex today, and I had them detail up my truck, so I can post the pics I promised since my taco is no longer totally dirty.
                              anyway, here's my temp ghetto install as it stands now.
                              first, the obligatory exterior shots
                              now for some interior photos
                              these pics were taken at night with my gf's Nikon D50. As you can see, I've changed my frontend from roadrunner to centrafuse.
                              I like roadrunner's skinability and customizations, but right now I just want something that looks nice and does what I want without having to super tweak it. That's the mood I've been in for a few months anyways.
                              Who knows, maybe in a couple of months I'll be back into roadrunner or that new flash one I saw the other day (I forget the name of it). That's one of the best features of a car pc. I'm not locked into how pioneer or alpine or anyone else thinks my software should look or what it can do. I can change and change and change until I find something I like, and then change again just for the hell of it. Anyways, good times. I'll update the thread when I got the 1900 power supply/controller and mount the mini under the seat (surprisingly, it doesn't fit in the glove box)
