2002 Jetta
  • 2002 Jetta
    I'd like to thank the site for providing all sorts of helpful information to a first-timer like me.
    Inspiration for the layout: ppgt94 (ID on here... awesome work)
    First, Take the car apart (almost... slight exaggeration) to get the center console out.
    I took the zenarc apart and cut the edges down a little so the case fit like this:
    I started off working with fiberglass, and it went smoothly until I started sanding and the fiberglass lifted off... So I started over with bondo.
    I've never worked with any of this stuff before so it was definitely a learning experience.
    Here's some of the bondo progress (and yes, I learned I should have made it smoother when it was still wet...later):
    Here's the sanding progress... The goal was to keep the line in the xenarc casing so it wouldn't be completely flat... I thought it would look nice to keep some of the lines. Sanding goes on for two weekends... sanding it down with 400, 800 and 1600 grit... then the sandable primer with wet sanding.
    Here's adding more bondo to the middle 'cause it wasn't flat:
    Here's how much bondo got under my nails! My gloves were too big, so I didn't use them all the time...
    I can't find the rest of the sanding pics, but basically, I sanded A LOT. Then my friend Greg (the perfectionist) took over with primer (used a can of sandable primer), wet sanding, painting and wet sanding and gave it back to me looking like this:
    I put the screen itself back in and also the slimline DVD (I don't think there are pics above of this, but I'll add more pics later... I cut out a slot for the DVD drive).
    So I am off to start installing the console back in the Jetta and running wires to the trunk.
    And, if you are interested, here's a pic of my car (with my friend, Eugene doing something to his camera):
    My complete install:http://edition719.com/modules.php?na...460&highlight=
    Wow....very nice job on the Bezel fabrication
    Motherboard: Epox MATX
    Power: M2-ATX
    Storage: 120gb 3.5"
    Optical: Slim Slot cdrw/dvd
    Audio: SB Audigy 2
    GPS: BU-353 & iGuidance 4
    OS: Win FLP (Fundamentals)
    Frontend: Roadrunner (DFX 3 & 4)
      Thanks!
      BTW, the problem I'm currently working on is how to go from the laptop DVD drive to USB. Originally my plan was to use a 10 ft round IDE cable... use the adaptor from 40 pin to IDE then run the IDE cable back to the trunk (well that doesn't exist). So now I'm looking for laptop DVD drive to USB. I've seen it somewhat explained in here, but I honestly just don't see it.
      Do I need to get the adaptor to go to IDE from the laptop DVD drive and then an IDE to USB adaptor? And, do all IDE to USB adaptors require a separate power source?
        Bezel looks sic, grats!
        This should fix your notebook dvd problem:
        http://www.mp3car.com/store/product_...products_id=92
        06 GTI MKV
        Car Info, Pics, and Mod List
        Carputer Progress
        Planning
        [== 12% ]
        Parts
        [= 0% ]
        Testing
        [= 0% ]
        Install
        [= 0% ]
          WOW nice job I love the look that makes me wish I bought the Jetta I was looking at a while ago
          [B]Car Computer 98%[|||||||||-]
          Install Plan 100%[||||||||||]
          Styling 20%[||--------]
          Install 0%[----------]
            I use that one too. Use firewire if you can. It'll save you a lot of headaches with bootup. And, you won't need a seperate power souce.
            ...No IDE connection required...
            -ZtH01
            -ZtH01
            "It's my belief that my big balls should be held every night"
              Sweeeeet, thanks for the suggestion - I've been searching these threads all day for what others did.
              Thanks for the "looks good too" this is gonna be awesome.
                Looking nice. Thats gonna look completely stock once its in the car.
                Civiputer: Dont have one anymore, but here is what is used to be!
                  I really like how that turned out. You did a great job at showing the step-by-step processes through the pics.
                    looks really good!
                    New System in progress:
                    M10k
                    Phaze TD1500 ~> Seas g18rnx/p
                    Zapco Ref 500.1 ~ 12" tc-9
                    Transflective Xenarc
                    My Car Pc Install
                    My Boat Pc worklog
                      -ZtH01
                      Any other suggestions? I can't fit the enclosure in the console....
                        Can you take it apart and just use the interface?
                        06 GTI MKV
                        Carputer Progress
                        Planning
                        [== 12% ]
                        Parts
                        [= 0% ]
                        Testing
                        [= 0% ]
                        Install
                        [= 0% ]
                          Good idea, I shall cut the thing apart!
                          And, I love your name on here... AWESOME. LOVE IT.
                            Beautiful job. I hope mine will turn out as well.
                            P.S. No Euroswitch yet??
                              I have the euroswitch for my headlights... which are you asking about?
                              I can post the full mod list if you would like to see it.
