Suzuki Jimny VVT <-> Mac-in-a-Zuk
  • Suzuki Jimny VVT <-> Mac-in-a-Zuk
    Hello!
    OK here is my project:
    Suzuki Jimny VVT 2005/6 model. For those how don't know this care it is one of the smallest off road 4x4s still available
    Stuff used:
    • MacMini Intel Core Solo
      Newvision 7" touch screen (VGA)
      4 plug cigarette lighter adapter
      300W power inverter (DC->AC)
      Hercules 2.1 computer sound system (will be integrating an amp but my 2x400W amp packed up)
      Small wood box
      Matting
    Gutted the Dash and removed the original stereo unit which is by the way of the large type.
    The idea is I put the newvision 7" touch screen in place of the original stereo. for this I took the original bracket and fitted the screen to it and that way I could slot it into the same place as the stereo was. The screen is the only thing that isn't removeable (i.e. directly but it is no hacked)
    The Mac Mini will be going under the passenger's seat and everything has to be removable so I decided to fit a row of cig plugs in the front section of the center console just under the dash, in front of the gear lever.
    For this I bought a 4 plug adapter and screwed it to the plastic of the center console:
    More pics to come of the next steps... but I need to save a bit of $$$ before I go further
    Mac-in-a-Zuk
    Suzuki Jimny 1.3 VVT - Mac Mini 1.5GHz Intel Core Solo - 7" Newision NW619VT touch screen - 2x200W amp
    Ha a friend of mine had one of these and I was always trying to convince him to do this!
    Looking good, what will the Cigarette plugs be used for?
    [Insert witty comment here]
      The plugs will be used for the power inverter (I use it my other car) I have a Pocket PC that needs charging from time to time, and when my passenger is watching videos I use the PPC for sat nav with a bluetooth GPS reciever (I use Navigon 5), I also have a 12v fridge for treks...
      Of course I don't use all this stuff all the time
      Mac-in-a-Zuk
        Why don't you get a DC/DC car adapter for the mini? There's one designed to work with th MacBook, I think it should either work or be easy to modify to work with the mini...
        Car PC progress: 60%
        Pics coming soon!!!
          Yes I plan to get a DC-DC Carnetix power supply! But Where I live I cant buy these at all, I will be aquiring one over the net in a couple a weeks
          They even sell a cable package for the Mac Mini!!!
          You can find info on this in the forum...
          About to post some more pics...
          Mac-in-a-Zuk
            I there all you car PC & Mac freaks!!!
            Just finished my project (sort of as there is always room for improvment...)
            Ok here I am hacking into the original Stereo to get the speakers and power for the 2x200W amp (my 400W was out of order )
            The next step was making a good box for the Mac Mini, and as I want it to be 100% removable I made a small custom box to go uner the passenger's seat.
            I used a small wooden box I found in my local DIY store, I cut a slot out the front and made a deck so I could put the Mini on it and store the PSU under it. (I have enough space for my P1900 when I buy it)
            Ok now back to the dash, now I have finished the wiring I can fit the panel back. I must say that I am missing some sort of seal between the panel and the adges of the screen, I plan to use some flexible material to hide the sides of the screen.
            I like this one as I am reflected in the screen
            My next job was RadioShark! Well I read up all the threads in these forums and did the hack! I basically removed the inerds of the Shark and removed all the original antennas (copper wires) and then solderd the +RCA to the FM point on the printed circuit and the -RCA to the furthest AM point. And on the other end I fitted a female radio socket found in my local HiFi market.
            I fitted the unit under the central tunel just in front of the gear shift leaver. I had to shield it from the metal of the car so I used a couple of zip locks under it and a couple to secure it. Simple and efficient note the soldering points...
            Mac-in-a-Zuk
              Ok I have to many pics
              Continued from above...
              Then I refitted the tunel cover over the lot! At this time I don't use the blue Shark's LED lights but I thought I might use them as dim foot well lights
              Perfect place to put the remote controls...
              Now I have put the Mini in it's place time for booting and testing...
              Verdict: HURRAY!!! All works great! Even the FM radio (oh yes I didn't say above I removed AM completley as I never use it). These shots are of RadioShark on 107.0 FM here where I live ONE FM
              There we go folks, thats all for today ... but I still have the Carnetix PSU to fit, and an extra antenna hack... but that is a surprise...
              Hope you like it
              Mac-in-a-Zuk
                Oh almost forgot, bet you want to know what the car looks like from outside? Huh?
                Ok now your laughing... stop that
                Mac-in-a-Zuk
                  Looks good so far.
                  Since you have availibility issues with the P1900, this might not work, but take a look at the WRX housing for Lilli screens. Based on your pictures it looks about the same size. It *should* (read, you'll have to do all the measurements to know for sure ) allow you to slide the monitor forward a bit so it is less recessed or possibly flush. Then you should have less to fill in.
                  They have a FAQ for it which has a link to a drawing of it with measurements: http://www.mechatroniks.com/wrx/groupbuyfaq.htm#11
                  I used one for my install and have been really happy with it.
                  Just a thought
                  -dave
                  My pathetic worklog.
                  CarFrontEnd (now it's own sub-forum!!!!)
                    Actually I quite like the fact it is recessed that way when in strong sun light I still have a clear view of the screen... but your suggestion seems interesting none the less... I will be getting that P1900 it is just a question of time
                    Mac-in-a-Zuk
                      hows the reception wit the moded radioshark?
                        Hi,
                        Well the reception is fine so long as you are in an area with a strong signal. Needless to say that it is not as good as an original head unit. However I find it very satisfactory and only experience the odd glitch in the reception from time to time on my favorite radio stations.
                        It also depends on how much interference there is around your car, the Jimny is a rather basic car and hasn't got much in the way of interference suppression so maybe if fitted to a more sophisticated car it would be near perfect
                        Hope that helps, don't hesitate if you want extra info...
                        Maybe I should record a track while driving so you could hear the quality... hmmm have to find the time, but at the moment I am not driving the Jimny so it will have to wait...
                        See ya! And happy Shark modding
                        Mac-in-a-Zuk
                          Dude, I so want that car ... so cool looking and different. What country are you in?
                          '06 Chevy Silverado 2500HD - Just Starting | '05 Rubicon - Slightly Modded
                          Details on both: http://www.cardomain.com/id/djfriar
                            Europe... somewhere
                            Mac-in-a-Zuk
