LCD retrofitted into OEM housing
  • LCD retrofitted into OEM housing
    Heres my progress so far, its taken alot of work to get it to look this OEM, with still alot of work to go, ill definitly have it in during the next month. Heres some shots so far of the LCD:
    Stock radio:
    Here is the screen sitting next to the OEM tape deck cage:
    [img]
    Here it is almost done:
    Heres a picture of my car:
    and the interior (retrofitted the whole interior with blue LEDs):
    What can I say, I love Volvos:
    Volvo 740 with 5.0 mustang conversion (totaled)
    Volvo 740 stock (sold)
    Volvo 940se (sold)
    Volvo 850 T-5R yellow (sold)
    Volvo S70 T5SE
    Volvo C70
    Volvo 850R with a long list of mods
    Forgot I should have added my car. Can someone add Volvo 850 T-5R before the words in my title.
    Volvo 940se (sold)
    Volvo S70 T5SE
    Volvo C70
      Very nice! Are you going to add a plastic bezel around it? Also, I couldn't tell how you supported the LCD. It's going to bounce around alot with car movement, plus has to support you pushing on the touchscreen.
      Gen 1: Pentium 3 1GHz - ATX - 2005
      Gen 2: Pentium M 1.6GHz - ITX - 2006
      Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
      Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
      ...it never ends
        I have plans for a bezel, but you will have to wait for that. I stuck the screen in there with double sided foam tape.
        Volvo 940se (sold)
        Volvo S70 T5SE
        Volvo C70
          Is that a 7" widescreen or an 8" widescreen? I've been debating which to get to fit into a double din setup that would also be custom.
          Nick - 08 GG Element
          Custom 3D-CAD Design, Reverse Engineering and Fabrication
            its a 7" xenarc screen
            Volvo 940se (sold)
            Volvo S70 T5SE
            Volvo C70
              Nice work. I did very much the same thing with my install I ended up making a frame for the LCD out of plywood, then moulding that to the OEM housing using plastic bond stuff to act as the front bezel. Then did a lot of sanding, painting, etc.
              As for holding the LCD in place, I screwed two wooden noggins into the top and bottom of the front of the housing (behind the bezel) and left just enough room to squeeze the LCD and touch screen inbetween the bezel and the noggins. Then I screwed the original LCD mounts (little metal things) into the noggins and they held the LCD in there nice and tight.
              Wish I had a photo to show...
              Jarrod - Holden VX S!
                Nice car! Can you stuff the whole computer in there? I would bet you could if you played your cards right.
                  mabye, im using a laptop though, so no dice.
                  Volvo 940se (sold)
                  Volvo S70 T5SE
                  Volvo C70
                    Where did you get the blue leds from, I would like to do that to mine.
                      blue LEDs are from ebay, got a pack of 100 and went to work. Its ALOT of work. Anyone want to change my title yet with my car?
                      Volvo 940se (sold)
                      Volvo S70 T5SE
                      Volvo C70
                        Don't have any left over do you?
                          you can get LEDs all over the place for cheap
                          if i was at my comp, i'd post a few links, most sites you can get 100 for like $4-$5
                          so, buy $20 worth, and ur set for life, lol
                          you should've got the multicolor leds, switch from red/green/blue whenever for the hell of it, hahah
                            http://cgi.ebay.com/50ea-matched-BLU...QQcmdZViewItem
                            thats what I bought.
                            Volvo 940se (sold)
                            Volvo S70 T5SE
                            Volvo C70
