2002 Audi A4 1.8T
  • 2002 Audi A4 1.8T
    I'm going to be installing a carputer into my 2002 Audi A4 1.8T.
    Here is the purchase list:
    1. HP PIII 750 MHz Laptop [Purchased]
    2. CNX-P1900 PSU
    3. Lilliput 7" Touchscreen LCD
    4. Double Din Metra Adapter [Purchased]
    5. US Global Sat BU-353 USB port GPS Receiver [Purchased]
    6. AM/FM Tuner (undecided)
    7. USB 2.0 Hub (undecided)
    8. XM Tuner [Purchased]
    9. Bluetooth Adapter (undecided)
    10. GPS Software (undecided)
    11. Front End (undecided)
    Car Audio
    1. 5.1 Channel Amp
    2. Fuses
    3. 8 guage power wire
    4. 12 gauge speaker wire
    I'll be mounting the laptop in the trunk area.
    Any updates?
    06' Black on Black Infiniti G35 Coupe 6MT - Click this for the specs: http://honda-tech.com/garage?cmd=viewcar&id=5450
      just got back from London, time to work on my PC again.
      I'm evaluating front end packages right now. I want to find the right combination of front end / gps software since that is my main reason for building this system.
        ScAndal - how's the carputer going? I'm really interested in how its going as I have the same car.
        02 Audi A4 1.8T
        Current H/U: Clarion DRZ9255
        Fronts: Rainbow Germaniums - Upgrading to Platinums
        Front Amp: Arc Audio FD 4150 bridged
        Sub: ? (still deciding)
        Sub Amp: ? (still deciding)
        CarPC - Still in planning stage.
          Hey man, I also have the same car, now buying all the necessary for the building CarPC. Have u already done anything?
            Hey guys, sorry about the long delay. I've got almost everything I need except a screen. I'm going to start fabricating my bezel now that the weather is warming up. what screens/bezels are you guys using?
            ScAndal
              ScAndal
              Pls make pics of your bazel fabrication process )))
              I haven't started yet with my bazel fabrication, have'nt decided what screen to use 7" or 8", with 8" screen I'l have to relocate the buttons "ESP, etc..."
                Started Fabrication tonight.
                Here are some of my start pictures. I used Bondo-glass after epoxing the metra double din kit to the LCD Bezel.
                  Some more pics...
                    Should've masked off the edges of the LCD opening to keep the lines cleaner.
                    Also, I don't know how the metra kit is for 02+ A4's, but my 01 A4 double din metra kit lost its rigidity after cutting away the din slots to epoxy in my old Xenarc. During fit checks, it fit well, but once the screen was installed and ready for final integration, the metra kit just did not fit right at all.
                    GL.
                    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                      Great advice. Thanks Sal.
