Ford Mondeo (reserved)
  • Ford Mondeo (reserved)
    Component list
    Bluetooth USB dongle - 6.99 purchased
    Wireless Wifi PCI card - 19.99 purchased
    Nano mini USB keyboard - 14.99 purchased
    4 Port USB 2.0 Hub with Power Adapter - 6.48 purchased
    23 in 1 ALL-in-1 Card Reader/Writer - 5.14 purchased
    DVB T digital tv/radio USB 2 - 19.99 purchased
    Bluetooth GPS receiver - 39.99 purchased
    FM transmitter 11.99 purchased
    512mb RAM DDR 533Mhz - 39.99
    Jetway J7F4K 1.5GHz C7 Mainboard - 105.00
    Noah Mini-ITX Case - 72.24
    Western Digital WD2500BB 250GB 7200RPM ATA/100 2MB Cahce - OEM - 48.87 purchased
    LinITX Plus 7" Widescreen VGA/Composite Monitor with Touchscreen - 179.00
    Spent so far: 125.56
    I have already got these titles;
    Windows XP Pro
    Autoroute 2006
    Winamp 5.3
    I need to get the following;
    Whats being purchased next
    Carpc layout
    I have got a 48x cd-rw drive already which will not fit this case. Its not a problem, i only intend to install Windows Xp pro once and any other media can be beamed through my home wireless network.
    Tested fm transmitter with ipod in current car which has 2 power inputs
    Test 1: With power input at front of car; FM transmitter also transmitted interferance from the car, clearly a poor earth.
    Test 2 : Tried second power input in the boot; No interferance from the car, transmitted clearly. Not the best sound quality but will allow easy sound input into standard car stereo.
      Hard drive
      Originally I was going to have a 40gb Seagate laptop drive which is more resistant to bumps and bangs. However the choice of case allows for a conventional 3.5" hard drive to be installed. I know that this hard drive is not going to be as resistant as the laptop unit, but at 48.87 for 250gb, its got to be done.
      I have ordered a Western Digital WD2500BB 250GB 7200RPM ATA/100 2MB Cahce - OEM. The car its going into has not got sport suspension and most of the roads I am using are in good condition.
        A big change in the hardware?
        I have got about 400 / $770 to spend on the car pc its self. I could continue with the current plan or go for a mac mini with a Carnetix CNX-P1900 V2 140W Dual Output Power Regulator which comes with all the relevant power connections. I like the look of the macmini, very tidy and very powerful for the price too.
        Mac mini
        Heres the spec :
        1.66GHz Intel Core Duo
        512MB (2x256MB) 667MHz DDR2 SDRAM (PC2-5300)
        Option: up to 2GB
        60GB Serial ATA
        Option: up to 160GB
        24x Combo Drive (DVD-ROM/CD-RW)
        Intel GMA 950 graphics processor with 64MB of DDR2 SDRAM shared with main memory
        DVI output port with support for VGA, S-video, and composite video connections via adapter4
        Connects to external display with digital resolution (DVI) up to 1920 x 1200, analog resolution (VGA) up to 2048 x 1536
        Four USB 2.0 ports, one FireWire 400
        Built-in speakers, optical digital audio output/headphone out, optical digital audio input/audio line in
        Built-in 10/100/1000BASE-T (Gigabit)
        Built-in 54-Mbps AirPort Extreme Wi-Fi (802.11g); built-in Bluetooth 2.0+EDR (Enhanced Data Rate) module
        Apple Remote
        DVI to VGA adapter
        5.08 x 16.51 x 16.51 cm
        1.31 kg
        If i did go for the above unit, the only peripherals I would have to add would be;
        *Nano keyboard
        *23in 1 card reader
        *4 port usb 2 hub
        *DVB-T usb 2 tuner
        *Centrix 1900 power supply unit
        *LinITX 7" touchscreen
        Mac Mini Layout
