2007 Ford Falcon XR6 Turbo UTE
  • 2007 Ford Falcon XR6 Turbo UTE
    I thought i would start a new work log as the old one was getting messy.
    The Car
    View My Blog
    Click for 2GB FREE on-line storage!
    The Sceen
    View My Blog
      The PC Box
      Updated 2-June-07
      View My Blog
        The Sub Box
        Updated 2-June-07
        View My Blog
          Amp Box
          View My Blog
            In The Car
            Test Fit 2-June-07
            View My Blog
              Originally posted by djmickyg View Post
              Reserved for screen
              Reserved for PC box
              Reserved for Sub Box
              Reserved for Amp box
              Reserved for misc
              Reserved for my comment
              New System in progress:
              M10k
              Phaze TD1500 ~> Seas g18rnx/p
              Zapco Ref 500.1 ~ 12" tc-9
              Transflective Xenarc
              My Car Pc Install
              My Boat Pc worklog
                reserved for lol
                  Good going,
                  Planning a similar setup for my F6 Tornado.
                  Will send you a link, Caruter complete, have Xenarc screen, but also converting the stock Prestige Sound over to Premium, and changing the manual MCC (like yours) to the DualZone Climate Control unit, with Color LCD.
                  Keep it going, cannot wait for the end result.
                  Br,
                  MrBean
                  F6 Tornado Project Log ; HP Blackbird Watercooled Server
                  Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
                    I'm regretting not getting climate control.
                    is it expensive to change it all over?
                    I eventually plan on moving the screen to where the stock ICC is and moving the ICC to where me screen is.
                    a mates already done it and it looks really good. but I wait till i get everything running first.
                    I'm making the sub box the same size as the PC and then in the center of the 2 boxes i will make another box for the amp.
                    and then with all the covers ontop of the boxes, the back shelf will be flat like it is now, only 130mm higher.
                    where have u got your Xenarc?
                    View My Blog
                      Heya,
                      Got my Xenarc off ebay, around $370- odd to my place in Doncaster East, Vic.
                      700 TSV model, which is quite good.
                      Just a little work involved, and some knowledge, and money of course.
                      I have all w/s manuals, etc, so no problem, just some additional temp sensors, one solenoid for the airbox, and some wiring to be done. External temp sensor part of passenger side mirror though, so you need to get that, and loom.
                      BEM needs to be re-programmed, as well as your current HIM, to allow proper control of dualzones.
                      I will mount my ICC LCD down where your TFT is mounted now, and Xenarc where LCD originally was located - same as your plan
                      We should hook up, if you need advice give me a shout - maybe I can help.
                      edit: Before I forget, I have a brandnew ICC plastic bezel lying here, if you want to mod yours - same color, picked it up from ASL, $110-, you can have it for $80 if you need it. Otherwise no prob - soz for off-topic!
                      Best regards,
                      MrBean.
                        Interested Onlooker
                        G'day DJMickyG (and others),
                        Having been hooked on MP3Car forums for over 6 months now, I'm hoping to bite the bullet and challenge myself to a 2007 carpc project.
                        I've recently bought a Ford Territory, and also live in Melbourne (Australia). As such, given the dashboard similarities of our cars, I keenly followed your other thread, and have now subscribed to this one.
                        As far as the screens go, my initial desire would be to relocate the Stock ICC down and fab a new Touchscreen into it's place. Therefore, I'd be pumped to see any photos from your mates car.
                        Also keen to hear where your putting the PC etc ? Is that behind the front seats ?
                        Keep the photos coming if you can.
                        Well done, good luck, and I will follow with interest.
                        Cheers,
                        Long.1
                        Worklog: 2006 Ford Territory Ghia (Melbourne, Australia)
                        Mounting Components in Custom Carputer Box
                        Attention Aussie's - Say G'day Here
                          Hey Long.1,
                          Which ICC you have? Probably prestige sound with color LCD? Do you have the little slits next to your LCD, on the right-hand side?
                          I find it may be significantly easier to mod the mono-LCD setup, especially wrt space for fitting a 7" screen.
                          With a DualZone ICC, I would say max tft touchscreen that will fit would be 6"
                          Keep us posted, I need to start a Project Log too.
                          Will do so tonight, and then we can share ideas.
                          edit: Here is a link to my Project Log if you want to see what I am up too
                          Regards,
                          Beanie.
                            Originally posted by mrbean_phillip View Post
                            Hey Long.1,
                            Regards,
                            Beanie.
                            G'day Beanie,
                            Thanks for the welcome. Being careful not to sabotage DJMickyG's thread, I'll keep this brief. I've definitely checked out your worklog as well, and will make some further comments under there.
                            As far as car goes, yes it's a Ghia so it has:
                            - The Premium ICC (with dual climate control, large colour screen and trip computer), and
                            - Premium audio system (with colour screen & 6-disc in-dash CD, 150 watt amplifier & sub-woofer).
                            Even so, given the dash similarities, it would be pretty foolish to ignore your threads. Still, life will be pretty interesting if and when I'm able to start the venture. Only time will tell.
                            Cheers,
                            Long.1
                            PS. If you're interested, here's my car.
                              looks good so far, but....
                              Can you really see that screen down there? It looks like its hidden to anyone and everyone, including you
                              2006 Mazda 3
                              Behringer DCX-2496
                              JL500/1 JL10w6v2
