No SOUND. Definite Codec Problem. Help!
  • No SOUND. Definite Codec Problem. Help!
    Windows XP. Two systems, same problem, one has a Realtek AC'97 audio driver, the other has a RealtekHD (an EEE PC). Here it is:
    So just to get this out first, EVERYTHING ELSE WORKS. The computer is "hearing" the sound, the software is sensing the signal--I know this because it seeks and shows RDS data. Everything is working up to the point where I should be able to hear it. But no...
    Additionally, and strangely, when I go into the control panel -> sounds and audio devices -> the the "voice" tab, I can do a "test hardware" for voice recording which allows me to hear the signal as if it were coming through the mic. But that's it. The only way.
    Now HERE is the biggest symptom of the issue. Even though I can select the USB Audio Codec as the recording device, when I go to volume control (playback, recording) it has no options and everything is grayed out. Same in control panel.
    Brand new. Installed everything per instructions. to troubleshoot I have already installed on two computers and the problem repeated itself.
    PLEASE HELP.
    DJ
    that is all correct.. there is NO adjustments in XP (os limitation)
    course i dont know what your are using... but lets assume BoomzBox Software
    right click, settings, enable audio engine, enable monitor, select USB Audio CODEC
    exit settings... you shoudl hear audio
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      REMEMBER 1st time you plug it in, windows thinks you want to playback your audio though this device, which of course you cant, reset your DEFAULT PLAYBACK DEVICE
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Solved. Thanks Mitch... I had not enabled the audio engine in the settings.
        Now, I should be able to use CF with a few more steps...
          great!
          CF on xp is a little tricky (cause they got a bug in thier device enumeration for the wave in devices on xp)
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            I've seen some of your other advice on that. Editing of a system file is required? I'm sure I can find the thread again. If it's easy, and you see this, you could always post the line to edit here.
            I've heard the bug is easy to fix when you have the right info to replace in the file.
              hu?
              system file no, a cf file yes...
              and i dont think its easy
              but the info is in this sub forum
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                O.K. Everything works in BoomzBox, but still not Centrafuse.
                I have changed the config file just like your instructions and the USB device just WILL NOT ENUMERATE in the record line-in list.
                Here's the thing. Everything is working. There is data from the radio station. I know the signal is being received by Centrafuse. But there is no sound.
                UPDATE: I want to clarify that I see the device in the PLAYBACK LINE IN but not the RECORD LINE IN. I don't know how to fix that.
                  you're right, it WILL NEVER enumerate in the record line-in list
                  its a bug in CF, i think i have said this 1000+ times
                  set to hd radio
                  set buffered audio on, set (on page 2) step to 100khz
                  set none for record and playback lines
                  SAVE
                  EXIT CF
                  EDIT config file...
                  restart CF
                  go to radio... do you hear it? no, edit config file again
                  most of the time is 1, but could be 2, it all depends on how many
                  wave in devices you have
                  DO NOT go back to radio config!
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Well, this will make Mitch upset, but IT DOESN'T WORK. I have followed your exact instructions.
                    <RADIOLINEIN>1|-1</RADIOLINEIN>
                    <RADIOLINEIN>2|-1</RADIOLINEIN>
                    <RADIOLINEIN>3|-1</RADIOLINEIN>
                    <RADIOLINEIN>4|-1</RADIOLINEIN>
                    <RADIOLINEIN>5|-1</RADIOLINEIN>
                    <RADIOLINEIN>6|-1</RADIOLINEIN>
                    No sound.
                      how about posting the exact path of this file
                      and attach the file
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Here it is:
                        C:\Documents and Settings\All Users\Application Data\Centrafuse\System
                        File is attached. It defaults NOT to -1|-1, by the way, but to NONE. So I have already changed it.
                          CF is so messy!!!
                          u will find another file
                          if you know where to look
                          i dont want to tell you quite yet...
                          im finalizing a automation process for this
                          cf is messy!!
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            try this....
                            (FILE IN LATER POST)
                            note where it finds the file...
                            if it cant find it automatically, it will let you do it manually
                            in this case the real settings is by user
                            let me know if it works
                            it will set for you
                            to HDRadio
                            100khz
                            and the line in you select
                            let me know for sure, that usb audio codec shows in your list
                            mitch
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              might be setting wrong index...
                              might be zero based
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
