problem will not find radio
  • problem will not find radio
    i installed all the drivers and everything and no matter what i do i use centerfuse and it just sits there when i try to use the radio so i downloaded the stand alone app and then the app search for the radio and says not found when auto is selected then when u point it to the comm number it just sits there and does nothing it say searching im stumped any help on this would be good thanks
    does the radio show up in the ports section of device manager
    did you connect 12volts?
    not to mention os would be nice too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      It shows up in device manager the port is 25
      the 12 volt power is connected
      My os is windows 7
        if all is well, boomzboxhd software should be able to find it on AUTO
        if not.. 1st try another pc
        check 8 pin minidin for broken/bent pins
        there is a small fuse inside the box (right by a notch, label pf1) measure 12v there
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Any resolution to this problem? I'm having the same issue with BoomzBox program.
          Thanks.
            his posts are from 3 months ago... most likely solved his problem...
            and just forgot to post his solution
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
