Power Antenna mod?
  • Power Antenna mod?
    Hey guys,
    I was wondering if anyone attempted to control their power antenna only when the radio is on, similar to this mod. In case you are wondering, this is for a system running Windows 7 and Centrafuse.
    Thanks,
    0l33l
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
    radio is on is vague...
    example, in RideRunner and Centrafuse, the radio is ALWAYS ON
    its a question of is it ACTIVE, then you would want to raise/lower your antenna
    (if you actually have an electric telescoping antenna, cars dont have them anymore)
    so if its a non telescoping power antenna, ie AMPLIFIED, just power it when pc is on, or when key is in accessory... no need to overcomplicate
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Thank you for the reply Mitch,
      For some reason I could have sworn that Centrafuse 3.1 turns the radio on when I press the radio button (I thought I could hear the relay).
      The power telescoping antenna in question is for a MKIV Toyota Supra.
      Thanks,
      0l33l
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        yes...it does.. but it wont turn it off, till app closes or suspend or such
        once on, stays on, and if radio was last source... it should start up with it on
        hmm, since u got a telescoping ant, yea.. u need some sort of relay, triggered by the CF, when radio is "ACTIVE" not sure how to do that in CF
        need a usb...relay
        like
        http://cgi.ebay.com/USB-One-Relay-Co...item1c133f482d
        prob could make a simple plugin to CF3.1 to do it
        simple serial port commands
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Well, I could, if I knew C#. The plugin does sound easy, select a COMM port and register an even trigger for the radio state.
          need a usb...relay
          like
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            oh, man its easy in c#
            (i could/would do it in like 5 mins)
            (since i already have plugin for my UAS4 for cf3.1
            you know, this guy, in blugaria(sp) has something else i want...
            if you want to toss $34 at it let me know
            ill get it and code it...
            pm me
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
